#2026 |
Re: Kabwe's aka Bam's build
ha ha, thats a good one, get rid of some stuff. I have a bunch of stuff stored at a daughters garage. wife knows there is some stuff but no way she knows how much, lol.
trying to consolidate a few things myself so less mess seen out the kitchen window. working on getting the box on the frame and building mounts. then get the floor jacked up to clear the frame bump. did you use a steel trailer fender for the inner edge of the tub? |
#2027 |
no I am using the stock 58-59 Fleetside tubs. I thought I would save time going stock, but they needed to be widened anyway.lol
#2028 |
Due to my narrowed rearend I had to widen the new wheel tubs for the fleetside bed. I had some sheet metal laying around that I cut into long 2 inch wide stripes.
![]() ![]() ![]() ![]() Very simple mod but someone may be interested in how I widened them so I posted it. I will post another pic of them as soon as I finish the welding and metal finishing. |
#2029 |
Looks good, as always.
#2030 |
The truck is moving along slowly, but its moving along.
First a mod I did to the inner fenders. I welded up one of the valleys in the inner fender to use a s a wire loom for the electrical wire going to the front of the truck. ![]() Here is the other side that will hold the wires. ![]() Filler, primer, block sanded, and painted ![]() ![]() Front Fenders ![]() ![]() ![]() ![]() ![]() ![]() New Radiator ![]() |
#2031 |
It looks great!
#2032 |
looking GOOD! So Smooth and I'm Lovin that Color
#2033 |
![]() Join Date: Mar 2011
Bam, great work as always. Nice detail an looks super...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 05-07-2018 at 11:16 PM. |
#2034 |
Thanks guys. I appreciate all the comments.
#2035 |
![]() ![]() Join Date: Nov 2008
Hi Bam!
As usual, your work looks great, well thought out and pro performed. Question: Have you had any issue making the paint match when you paint at different times due to...I don't know, humidity, drying times, etc? Once again, the truck is looking SO good!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#2036 | |
#2037 |
Great color and the right shade
If you were going to but an accent/pinstripe what color(s) would you chose?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 05-08-2018 at 08:39 AM. |
#2038 | |
My painter painted my interior and interior steps before later painting the entire exterior. There is a very slight - but unacceptable to me - color difference just on the strip below the doors. He will repaint that and the difference from interior to exterior is so slight you can't see it UNLESS it's directly adjacent like that area. He says it al came from the same but I suspect it's like you are saying. two gallons that were not co-mixed before using.
#2039 |
Fandamntastic X 10
Keep on keepin on NC
Been there, wrecked that ![]() |
#2040 |
Been following this build for a while and as usual the work is flawless. Great job and can’t wait to see it done.
#2041 |
Looks great.
Kim |
#2042 |
A320 Pilot/USAF Retired
Color looks great!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#2043 |
great work as usual sir !
#2044 |
anybody know what that triangle shaped piece is for on the back side of the inner fender? just curious.
nice work Bam. gonna be great looking at the shine from those fenders while cruising this summer. |
#2045 |
As far as I know it is just the factory's way of reinforcing the sheet metal inner fender so it wouldn't tear over the years. I could be wrong but that's what I have always assumed.
#2046 |
ya, same here. it's "compromised" on mine now.....
#2047 |
Love that color BAM!
Cheers, Jim |
#2049 |
Thanks for the compliments guys.
#2050 |
I assume the triangle piece is a reinforcement as well. When you got a V8, the radiator was moved rearward and the core support was bolted further back in the recess. Picture the core support just being slid back. Looks like on these inner fenders the rear holes have been filled. You would need something more than some thin sheet metal to hold it all in place. The forward position has a lot of items converging at the top corner to supply the support.
