View Poll Results: 13" Brakes: Any Interest? | |||
Yes, interested |
195 | 95.59% |
No thanks |
9 | 4.41% |
Voters: 204. You may not vote on this poll |
#201 |
Re: How Much Interest: 13" Big Brake Upgrade
I've used CPP stuff & would again. I just wonder where were they when we started this quest?
![]() The engineer that I've worked with only stepped up to the plate because everyone on this site & 73-87chevytrucks got involved. I really, really hope to provide those pics you all have patiently been waiting for by this weekend if ma' nature cooperates. It might be hard to see the big brakes.... you'll have to get past the freakin sweet Dropmember & those 20" Coys first ![]()
#202 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Looking forward to the pics! Thanks again for doing ALL the legwork.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 03-30-2008 at 07:29 AM. |
#203 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I am all for competition, but you just hijacked this thread, and you aren't a supporting Vendor.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#204 |
I got some pics yesterday & will get them up tonight. Some of you requested pics of what the kit came with so I wanted to mention the cool thing about this is if you have the resources, you can get stuff used/cheaper than what I did & cut costs if necessary.
The pics will be of the 'kit' I opted for, everything going together, & one or two of the assembly w/a wheel/tire installed to get an idea on clearances.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-02-2008 at 01:22 AM. |
#205 |
Catchy title goes here..
![]() Join Date: Mar 2002
wow you guys are amazing.... cpp is a site supporting vendor.. ie someone who pays to keep this place going so folks like 68laydout have somewhere to ***** about them.
I can not believe the replies in this post.. DKN I personally apologize for the flaming you have received and hope you do not get a bad taste for the site due to this.. it is fully against the rules and just plain hateful. The reason DKNs name was not red was a miscommunication between us and cpp.. even so the replies are shocking.. With that said I am going to speak on the level those bashing will understand cut the sh!t, act right or accounts will be suspended. Review the rules, use the review forum for reviews and if you feel the need to go off on someone for posting shut the thread and report your concerns to a staff member. |
#206 |
I'm following this thread just to get info on "ANY" big brake kit that won't break the bank. Thanks to anyone providing such info. I'm sure I speak for most people here. No need to close this thread, thanks Liz for clarifying why we are here.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
#207 |
its just $$$$$
apperently Liz hasnt bought many parts from CPP and dealt with their stellar customer service. the way he was treated here was no worse than the way they treat their paying customers............suspend me if you must, but thats the way i see it
#208 |
He's got mean nasty FANGS!
If you have a problem with a company, there is a REVIEW area of the site for such issues. Hijacking a thread and using inappropriate language and behavior is not the proper way to get the word out. If you have an issue please use the review forums or bad deals forums instead of cluttering up threads with it.
Also one last thing, please drop the attitude and respect the staff. We work harder than y'all will ever know to keep this place available for you all and dropping us attitude for enforcing the rules isn't appreciated.
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
#209 |
I didn't know DKN was a supporting Vendor. I sincerely apologize to Danny Nix and the Staff for the misunderstanding on my part.
#210 |
Better late than never right?
The 'kit' I used w/a semi close-up of the rotor dimension . . .....
#211 |
The stock spindle 'carved-up' a little bit & the C5/6 PBR caliper adapter bracket w/the
supplied hardware . . . ......
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-02-2008 at 07:32 AM. |
#212 |
The PBR twin 40mm piston caliper in good ol' basic black . . .....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-02-2008 at 07:43 AM. |
#213 |
Billet alum hub w/the correct C10 bearings & ARP screw-in studs . . .....
#214 |
Spindle + adapter bracket.
Spindle + bracket + hub. Spindle, bracket, hub + 13.4" rotor. Spindle, bracket, hub, rotor + C5/6 caliper. C5/6 13.4" brakes in a 20x8.5" Coys C-5 wheel . . .....
#215 |
Close-up of the Coys 20" wheel & how much stem to caliper clearance there is. These are a little bigger than the 12" HD C10 brake option
#216 |
Out of the carpool lane.
That's SWEET SCOTI!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... Last edited by Brad; 04-02-2008 at 09:26 AM. |
#217 |
My set-up was $1300 delivered. That included the larger aftermarket rotors vs. the GM C5 rotor which added $360 to the cost.
#218 |
Phat
#219 | |
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#220 | |
#221 |
its just $$$$$
its amazing how much that looks like my baer kit. Its almost an exact match. My kit is disassembled now, so i will post some pics this weekend for comparison. These are DEFINITELY a more economical option than baer.
#222 | |
You can even go w/a 14" rotor & C5/6 caliper if you can find a wheel that would allow it.
#223 | |
I think my 24's will clear that no problem ![]()
1973 C10 "Chain Reaction" Street Trucks cover Feb 2012 2013 Silverado 1964 Cadillac |
#224 |
Maybe I'll upgrade the calipers and rotors on my vette, and swap them over to the truck! (2 for 1 deal!)
when you say C5/C6 caliper do you mean that either caliper will work? Or are they the same? What was involved in modifying the spinde? Just a little grinding to let the caliper bracket sit flat, or did you have to drill new holes? Are these kits available now? Or when will they be available.
Project Bruiser: 68 Pro-Touring C-10 5.3L / 4L60E Project Ironhide: 97 GMC Crew Cab 4x4 Cummins SOLD: '69 GMC 1/2T SWB TBI'd: Project No Buck Assembly Manual Index Sign up Thread!!! Factory Service Manual Index Last edited by Ackattack; 04-05-2008 at 07:57 AM. |
#225 | |
Spindle mods included cutting the original caliper ears off, drilling out 2 of the splash shield holes to a larger size (.500"), re-tapping the 'new' larger holes, & clearance grinding for the adapter bracket bolts. Also, the original spindles required removing more material when clearancing for the adapter bracket bolts vs. the dropped spindle. I'll see if I can find out what their production status is. I haven't mentioned their name or supplied any contact info/links because I feel it might be construed as 'semi-advertising' for the manufacturer. I'm hoping they'll become site supporters once they're ready to start promoting the product line.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-05-2008 at 05:12 PM. |
