Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-03-2009, 11:47 PM   #201
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: LFD's 4dr Tahoe Build
Originally Posted by Rokcrln View Post
My WB is 2" longer than FF's and the over Tahoe is only 1/4" longer than FF's. Funny how a few small changes make big differences.
Kevin
LFD Inc.
Ah, tricky. The proportions make it seem shorter. Or because his is laying down on air bags, giving it a bit longer look.
Never the less, I'm diggin' it.
texanidiot25 is offline   Reply With Quote
Old 01-04-2009, 12:55 AM   #202
Rokcrln
Rokcrln's Avatar
Originally Posted by Frizzle Fry View Post
I love it man! Looks awesome!!!
From the Artist (FF) to the Forger (LFD), thanks it means allot.
Sure rub in the fact that he has suspension and not flat plate welded between the diff and frame in the rear and fully collapsed heated springs in front
Well I got just a bit of time out in the shop tonight. My wife came home sick from her parents so I had two kids to take care of
I started Tigging up the pass quarter and got to the point were I needed to start hammering the welds so I came in for the night instead of waking the neighbors. Here's a shot of the two small spots of damage that I guess required a tub of filler to make it go away. Aside from those few spots it is a really striate Tahoe for a starting point.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-04-2009, 11:16 AM   #203
BlueJeep
BlueJeep's Avatar
What are you using to strip it, just a DA? Is this quicker then chemical stripper (Aircraft, etc.)?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 01-04-2009, 11:54 AM   #204
Retro68
Hey Kevin, That is some very creative work you have going. The transformation will be incredible when you get to paint. I follow your builds all the time. Good luck with your business growth in 2009. Scott N.
Retro68 is offline   Reply With Quote
Old 01-04-2009, 12:03 PM   #205
Rokcrln
Rokcrln's Avatar
I use a DA after I go over it with a 3" right angle air grinder with a woven disk. It removes paint quick and does not dig into the metal. They do not work good on filler so if I have much to remove I will use a 36 grit disk disk on the air grinder until I can see shadows of the metal under it then swap back to the woven disk and finish it off with 180 grit on the DA. I don't know if it is faster or not then stripper but way less toxic and I can start a panel and just stop for the night. If you use stripper you can not stop until you finish that area, wash it and clean up all the mess.
Thanks Scott
Kevin
LFD Inc.
Old 01-04-2009, 05:19 PM   #206
Rokcrln
Rokcrln's Avatar
Since I have had allot of people ask me "Whats that blue stuff" on other builds I thought I would show a quick 5 step answer. It is called bluing die or layout die and it is used for many different things. I use it for two main things, one being panel layout. It sprays on and when you use a scribe or just any sharp point it comes off leaving a very visible line to follow. Then I also use it for getting panels as striate as I can when doing body work or metal finishing. Let me be the first to say I am not that great at metal finishing but everything I practice I get a very small amount better. So after welding the seam and working it with a hammer and dolly every step of the way I feel it is almost done but needs a little touch up here and there. So I spray the die on the panel and let it dry for about 10 mins then go over it with a body file to show thew highs and lows.
Then I use the hammer and dolly on the real lows and some on the real highs then I hit it with a long board with 40grit. After that I hammer and dolly more on the low spots and hit again with the long board. I keep repeating this process until I am happy with the results. In this case I would say my lows are only about a 1/6" to 3/32" in the bad spots so I will leave it here and finish it off with lead later this week after I get the other side in the same shape.
In these pics the very front and back of the seam are not complete but it gives you the idea anyways.
Kevin
LFD Inc.
Old 01-04-2009, 09:25 PM   #207
woodwright
Enjoying left field
woodwright's Avatar
Where do you get the spray blueing?
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 01-04-2009, 09:47 PM   #208
Rokcrln
Rokcrln's Avatar
I got this stuff at a Good Guys show last year, I will get a pic of it so you can find some.
Kevin
LFD Inc.
Old 01-04-2009, 10:54 PM   #209
gregfull
gregfull's Avatar
Kevin
LFD Inc.
Kevin, you must have some machinist blood in you. Layout dye is widely used in the machine shop industry, the most popular brand is Dykem. It should be readily available at any industrial supply.
My Suburban Project
72 Suburban
68 SWB
57 Belair
55 Cameo
06 Chevy 1/2 ton crew
09 Suburban
gregfull is offline   Reply With Quote
Old 01-04-2009, 11:05 PM   #210
Rokcrln
Rokcrln's Avatar
Like this old stuff
Kevin
LFD Inc.
Wanted to add this just for kicks, here's the next LFD build. It is a 41 Chevy street rod pick up. I will be building a new chassis for it with IFS and IRS and get it ready for the road after a 15yr slumber.
Old 01-05-2009, 12:00 AM   #211
gringoloco
A guy with a truck
gringoloco's Avatar
What about the Blazer?! A little birdie told me there was some cool stuff in store...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-05-2009, 12:01 AM   #212
nuke1
nuke1's Avatar
i use dykem also kevin, works great, and that is one fine 41!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-05-2009, 12:11 AM   #213
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Dykem is good, also I use some stuff that is made by krylon, it is pretty good as well, I actually like it better because it is darker.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 01-05-2009, 09:14 AM   #214
Rokcrln
Rokcrln's Avatar
We made a business decision and decided the Tahoe would be a better place to put the time and money so the Blazer will be going down the road cheap! I just need to get the parts together for pic's so I can post it.
How does the other stuff clean up. A little brake kleen and the Dykem wipes right off. Also what is the name of the Krylon stuff $ ?
Kevin
LFD Inc.
Old 01-05-2009, 09:38 AM   #215
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
great work as usual.. looks great...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 01-06-2009, 10:14 PM   #216
Rokcrln
Rokcrln's Avatar
We decided to go with PT Cruiser door handles but it is a little more work than just bolting them up. The PT's are a flat mount and out trucks are not so the PT handles have a gap that needs to be dealt with. I first made a hammer form so I could make stand offs that were all the same for all 5 doors but they dint sit right. The handles are angled up hill and don't look right. So I will cut out some larger blanks for the hammer form so they stand off about 7/8" at the top and will be flush at the bottom. Here are a few pics to show what I have tried to give you an idea of were I am going with this.
Kevin
LFD Inc.
Old 01-06-2009, 11:32 PM   #217
LEEVON
LEEVON's Avatar
Wow those look great.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-07-2009, 12:20 AM   #218
XXL
Seņor Member
XXL's Avatar
We decided to go with PT Cruiser door handles...
Er, eh... interesting choice.
From a design perspective, I'm curious how you see the integration of the ovoid shape of the PT handles, buttons, and your standoffs with the generally "square" lines of the truck. It's not a typical combination.
/2 cents
//or less
XXL is offline   Reply With Quote
Old 01-07-2009, 12:34 AM   #219
Rokcrln
Rokcrln's Avatar
/2 cents
//or less
Well I see these trucks as having some striate lines but still mainly being a very curvy truck.
Kevin
LFD Inc.
Old 01-07-2009, 12:46 AM   #220
Rokcrln
Rokcrln's Avatar
Here is the second go round, they are now just about were they should be but I am not a 100% sold.
Kevin
LFD Inc.
Old 01-07-2009, 12:58 AM   #221
Rokcrln
Rokcrln's Avatar
Another possible direction would be the 60-66 truck handles and door pockets. I just checked the body curve with a contour tool and they are almost exactly the same. The Handle if I remember correctly they operate the same and would be easy to do.
Kevin
LFD Inc.
Old 01-07-2009, 01:12 AM   #222
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
I like the look of the 60-66 truck handles better. Plus you can even get rid of the stock lock's. Would be better and easier to mount.
Daren
04 Chevy Extend cab 2500HD 6.0 Liter 4x4
71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY
Rip El Jay
RIP BOBBO'S MOM
88JRFAN is offline   Reply With Quote
Old 01-07-2009, 01:32 AM   #223
woodwright
Enjoying left field
woodwright's Avatar
Yeah I'm not so sure about the P.T. handles either. I'm all for making things custom, but I think it looks cool when you can make it look like it came that way. IMHO, the amount of standoff that you have to make them sit right, doesn't look right. You do awesome work though.
Clint
Old 01-07-2009, 01:49 AM   #224
vk_chevy
vk_chevy's Avatar
good job on figuring out how to mount the handles, however,
if it was me, I'd go with truck handle, the PT handle is kind of bulbous on the standoff and seems to stick out too far
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 01-07-2009, 02:12 AM   #225
VA72C10
VA72C10
VA72C10's Avatar
I would also vote for either the truck handles or a custom flush option. I admire your work to get the PT handles to sit right, but think that it takes away from the truck.
it's your truck and the rest of your modifications have been spot on so maybe this will work with a little massaging.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
