"Junkyard Dog"
![]() Join Date: Jan 2008
Parting out 72 Suburban C10 402 TH400
Parting out 72 Suburban 402, TH400, aftermarket AC, 3.07 rear, and upper-lower tail gate. Also have a 72 K10 350 AT and a 72 C10 350 AT to part out after this one so many parts are duplicated. The 402 P/S pump assy, Alt brackets, and motor mounts are already sold. All parts are plus shipping. Payment by MO or check. Please reply in the thread. Thanks, Tom
"I'll take...." puts your name on it. Once total cost and or Q's answered is posted please respond with in 24 hours. After that is goes to second in line. If it's a pass please post so. Thanks 402 engine...needs rebuilt, runs ok but rings are bad. Priced as pictured less carb, dist, exhaust, valve covers, oil line, flywheel, temp senders, and other trinkets. All original never been apart. 400.00 TH400 also original never been apart. nice fluid clean in the pan. Not road tested but works fine to move around. 250.00 3.07 open coil spring rear end. looks nice inside. 250.00 Aftermarket AC specifically for our trucks with 402 brackets. Was not charged and untested. Pump turns nice and pulley is quiet and smooth. Complete less the condenser. 150.00 5 lug disc conversion: spindles, steering linkage, calipers (rebuilt), hard lines, dust shields, lower control arms, and rotors if wanted. Will need new upper ball joints. 225.00 Upper molding kit. VERY NICE, some oxidation as all have. Every mounting clip good and with the 4 original screws. Will not separate. 200.00 Rear side interior panels. see pics, cardboard warped. 50.00 Spare cover, cardboard bad. 15.00 Spare wing nut and retainer (dipped and media blasted) 12.50 Soft Ray M75 tinted glass. RH rear door glass has short deep scratch and RH front has typical vertical scratches otherwise very nice. Wings are glass only. 240.00 for all. Will separate. Std firewall heater box with replaced rust free (dipped) tins. Nice color. 45.00 High hump with no holes tunnel cover. 50.00 Parchment visors. nice but not perfect. 22.50 each or 40.00 pair 72 only door panel foam seals fronts and RH rear. Nice 5.00 each TH400-TH350 trans x-member (hot tanked). 25.00 71-72 turn lens. One has chip one nice. 5.00 and 10.00 71-72 turn lens housing. 10.00 each RH armrest needs painted. 12.00 LH outside door handle. Very nice driver. 25.00 RH outside door handles. Both pitted. 7.50 each 69-72 black horn button. Very nice. 20.00 RH lower molding sub only. Between RR door and wheel opening. Very minor small ding. 10.00 LH front fender nice needs repainted. 12.00 LH fender rear molding. Minor ding. 8.00 RH fender rear molding. Minor ding. 8.00 Window cranks and inner door handles 2.00 each. 402 starter heat shield. Solenoid mounting tab is split. 25.00 Wiper motor. looks very nice. 17.50 71-72 gas pedal assy with TH400 switch and wiring to engine harness. 40.00 Outside rear view mirrors with original screws. Original and VERY NICE. I had the RH glass replaced at local glass shop. 75.00 Sub spare tire wheel tub. Some rust. 52.00 Parchment seat belts. LH re tractor is lazy, pitted male buckles, NICE covers. 52.00 Wiper arms with original blades. 12.50 each Deluxe stainless door panel trim. RH and LH. Pair 25.00 Coil spring trailing arms. Hot tanked and acid dipped. No dings or dents Very nice. Ready for paint. 175.00 Interior headliner bows. Chrome in decent condition. 10.00 each Bench seat tracks. Nice knob and in nice condition. 25.00 Dash cut for radio hole replacement. 15.00 Rear tail lamp housings 7.50 each Rear tail lamp lens. Both bright one nice and one has crack in center. 12.50 and 5.00. Reverse light housings. 5.00 each Reverse lens. bright 6.00 LH rear side panel upper chrome trim. was a little rusty been acid dipped and rust free. Has pits. 9.00 RH rear door latch catch. Dipped and media blasted. 7.50 Rear side interior trim panel mounting hardware complete. 45.00 Lower gate latches and rods. 29.00 Lower gate support straps. 12.00 each 20.00 pair Lower gate inner latch mech (key cylinder and button mounts to this) Key cylinder and button assy with key. 18.00 key cylinder outer bezel has scuff with gasket. 6.00 upper gate outside handle. pitted 11.00 upper gate center latch. 12.50 upper gate supports. 38.00 pair upper-lower gate latch striker plates. Three of them 5.00 each 4 little stops for lower gate. 8.00 Fuel tank straps. 25.00 Chevrolet emblem broke between the H and E nice chrome. 8.00 cover plates 5 of them 10.00 Upper horizontal window felts 2 short and one long. nice condition considering 8.00 each Rear door vertical window felts with out frame (front of glass) 10.00 each Rear door vertical window frames RH and LH, felt bad. 12.00 each RH rear door lock linkage. 12.50 RH rear sill plate. looks very nice was rusty on botton side I have dipped this and now rust free. 22.00 Under dash wiring Very nice. 65.00 Back glass rubber (no bead). nice no cracks. 22.00 71-72 Grill very nice. no cracks or damage. Repainted in correct color. 125.00 Upper control arms. Hot tanked. 25.00 each Windsheild rubber with stainless steel moldings. nice rubber and moldings. 65.00 Extra set of w/s moldings only. 40.00 Dipped and media blasted parts. Ready for paint and refinishing of your choice. RH and LH rear window regulators. Rollers are stuck. 20.00 each RH rear door hindges. 29.00 RH front door hinges. 35.00 Upper gate hinges. needs bushings. 8.00 each lower gate hinges. needs bushings. 8.00 each RH door latches. Like new. 30.00 each LH door latch. Like new. 35.00 RH front door sub only stricker plate. 7.00 RH rear door or pu front stricker plate with back bracket. 12.50 LH door stricker plate. 7.00 RH door vertical felt channel. 12.00 LH rear vertical felt channel. 12.00 E-brake ratchet assy. like new. 35.00 Spare tire wing nut and retaining plate. 20.00 Wiper transmissions. 25.00 pair Vent pull rods with detent and clips. Rh or LH. 5.00 each Core support-fender triangle. 7.00 TH400 e-brake guides mounts to trans cross member. 4.00 each 7.50 pair Dual exhaust hangers complete as pictured. 110.00 Rear coil springs. 40.00 Front springs (402 truck) 40.00 on hold may keep Carrier bearing support bracket. 10.00 Track bar typical bushings. 22.00 C10 coil spring u-bolts nice threads. 15.00 pair U-bolt - shock plates. 20.00 pair 3 core rad mounts with rubbers. 25.00 Hood latch 69-72 chevy. 22.50 Steering intermediate shaft. 25.00 Steering gear rag joint. 15.00 71-72 Charcol canister bracket. 17.00 402 RH exhaust shield. 25.00 402 crank and water pump pullyes. 50.00 RH inner door handle mounts. 5.00 each TH400 complete shift linkage. 45.00 Coil spring over loads complete. 75.00
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw Last edited by tll74; 03-24-2012 at 03:33 PM. Reason: added items |
