Old 06-09-2015, 12:38 AM   #201
Captainfab
60-66 Nut
Re: My suburban's Twisted Little Sister
Interesting....a 409 with dual TBI....is this in the red Suburban?
Originally Posted by 65sub View Post
We took a break from the project today to change the valve seals on the 409 in my daily driver plus a couple of other small repairs.
Old 06-10-2015, 09:08 PM   #202
65sub
65sub's Avatar
Hi Captain. Yes that's the motor in my red suburban. The motor has Isky roller cam with 510/252 intake and 510/257 exhaust, 1.7 to 1 roller rockers, 11 to 1 Ross pistons and two FAST 4 barrel throttle body injectors. It is my daily driver. I have included a couple of new pictures of it for anyone interested.
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 06-10-2015, 09:13 PM   #203
65sub
65sub's Avatar
Today we fit the drivers side B and C pillars. There's only two pictures but that was 8 hours of fitting and tacking.
Dale
Old 06-11-2015, 01:06 AM   #204
Captainfab
60-66 Nut
Thanks for the extra pics and the info. It sounds like a sweet running engine.
Every time I see a 409, I have to once again kick myself for passing up an original 425/409 dual quad engine for $500
Old 06-11-2015, 08:35 AM   #205
Advanced Design
Advanced Design's Avatar
Wow, very nice 409 set up! Nice work on the B and C pillars.
Advanced Design is offline   Reply With Quote
Old 06-11-2015, 08:58 AM   #206
1963c-10
1963c-10's Avatar
65sub....very glad to see another "w" engine truck. I'm in the middle of two projects, but my 2nd is a 63 short fleet with a 348. What exhaust manifolds and mounts did you use on your 409?
I've got plenty of clearance with the engine mocked in. Will be using the POL mounts like I used on my other big block build, but interested to see what you did on your build. Thanks in advance. Jon.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-11-2015, 09:25 PM   #207
65sub
65sub's Avatar
Thumbs up Re: My suburban's Twisted Little Sister
I think we all have stories like that. Mine was a 68 RS/SS Camaro for $300.
Thanks A.D.
Hi Jon. I used stock hi horse 409 manifolds on mine. They are ceramic coated which has held up really well. They are a tight fit between the frame rails. My motor mounts are mid 80's clam shell style only because I had a urethane set left over. The frame perches I made myself. I see by your picture you moved your motor forward, I did the same. One issue I ran into was clearance at the front. Picture 2 is the battery to ac compressor and picture 3 is water pump pulley to electric fan. They are close but they clear.
Dale
Old 06-11-2015, 09:33 PM   #208
65sub
65sub's Avatar
Todays we worked on the A pillars. We got them fit and tacked and some of the out side welded.
Dale
Old 06-11-2015, 10:53 PM   #209
Free Candy Inside
Love this thing. Are you planning a giant door like Bomp or it looks like to me maybe a regular door with a small suicide door like a modern cab? Either way it'll be cool
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 06-12-2015, 08:27 AM   #210
1963c-10
1963c-10's Avatar
Thanks A.D.
Thanks for the response and pics. I have the factory 348 manifolds which are 2" manifolds. At some point someone did some work on my engine. Block was cast in 58 @250hp, but the heads are 61 @315hp, so its nice to have the upgraded heads. The 348-409 forum guys recommend that I go with the 2.5" manifolds from the 409 which I've been watching for a year on ebay and they are not cheap.
I'll continue to keep my eyes peeled though.
I have test fit with a fan blade and full shroud in place and it looks like I'm ok on clearance. I'll let you know how it goes once I get back into it. I'm on the down side to getting my stepside done right now, but I'm sure I'll have more questions down the road.
Great job on your builds....caught up on the whole thread yesterday. Outstanding work!!!!
Be sure to check out the 348/409 truck thread we have going also. Link: http://67-72chevytrucks.com/vboard/s...d.php?t=630055
Old 06-12-2015, 12:59 PM   #211
RustyBurb
That's an unbelievable build! I can't wait to see the finished product.
RustyBurb is offline   Reply With Quote
Old 06-13-2015, 09:16 PM   #212
65sub
65sub's Avatar
Thanks Free Candy. It's going to be one big door but not the way Bomp is doing his. I'm not going to reveal the plan yet but it will be obvious in the next couple of weeks.Unless someone guesses right.
Thanks Jon. I'm always happy to help. I look forward to seeing your progress when you have time.
Thanks Rusty
Dale
Old 06-14-2015, 08:16 PM   #213
65sub
65sub's Avatar
Finished welding the A pillars today. Then we started filling the gaps in the front piece above the windshield and the top of the rear door frame.
Dale
Old 06-15-2015, 08:08 PM   #214
65sub
65sub's Avatar
Weld grind weld grind weld grind. That was all we did all day today. There will probably be several more days of that. Here's a couple of pictures of the progress.
Dale
Old 06-20-2015, 03:42 PM   #215
65sub
65sub's Avatar
Here's some progress from friday. A couple of shots of more welding and grinding on the inside of the upper window frame. Plus the replacement panel for above the windshield arrived.
Dale
Old 06-20-2015, 03:45 PM   #216
65sub
65sub's Avatar
We also cut off the upper door frame at the B pillar and started at the A pillar
Dale
Old 06-20-2015, 05:23 PM   #217
notsolo
notsolo's Avatar
Gull Wing doors? Awesome build, Mad skills all the way around, Very cool... Carry On.
notsolo is offline   Reply With Quote
Old 06-20-2015, 07:48 PM   #218
Advanced Design
Nice work 65sub. Looking forward to what you are going to do with the doors.
Old 06-21-2015, 08:00 PM   #219
65sub
65sub's Avatar
Thanks notsolo. Good guess. Yes it will be gull wing doors like a Deloren.
Thanks A.D. I look forward to seeing progress on your 'burb as well.
Dale
Old 06-22-2015, 09:40 PM   #220
65sub
65sub's Avatar
We got a little por15 on the top of the side panels where the roof attaches. Then we started measuring to cut the roof. We decided on 50 inches from the back so we would have a bit of room for adjustment. Then we fired up the cut off wheel and started cutting. Now we have a two piece roof.
Dale
Old 06-22-2015, 09:59 PM   #221
65sub
65sub's Avatar
After cutting the roof in half we needed to remove the roof skin from the structure under it so we can widen the structure. Since we don't need the drip rail we cut it off and lifted off the skin. Then we cut the cross pieces of the roof structure and clamped them onto the truck.
Dale
Old 06-25-2015, 07:59 PM   #222
65sub
65sub's Avatar
Here's the progress from yesterday. First we cut some pieces from a spare cross brace so we can extend the roof braces. After tacking them in place we we set the roof on to see how it looks. It leaves about 5/8 of an inch gap on each side. Then we took the roof bracing off to finish welding it. We also replaced so rusty sections on the side.
Dale
Old 06-25-2015, 08:11 PM   #223
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
love the progress. lots of rust repair, think how nice it would be if you didn't have to do rust repair and could just focus on customizing!
every time I have to do rust repair I wish I didn't
Old 06-25-2015, 08:45 PM   #224
65sub
65sub's Avatar
Today we decided to work on the alignment problems on the C pillar. The first two photos show the back of the drivers side C pillar showing the diagonal body line. We worked on the passenger side first by cutting out the section that needed to be moved. Then we cut a patch and put a bend in it. After some shaping and trimming we tacked it in place.
Dale
Old 06-25-2015, 09:42 PM   #225
Free Candy Inside
Looks killer. There were a guy who had a panel truck that offered it to me for $200 a couple weeks ago. It was really rough but this build has me thinking I should go get it and start chopping the **** out of it!! Lol
Instagram: jaked937
