12-22-2015, 03:12 PM | #201 |
Re: 1956 Chevy Pro-Street Build
The engine building process seems like such a mind boggle with so many choices of things and directions to go..... and if you change one thing you have to look at all the other specs because they dont make this to fit that... WTH????
Just going BIGGER is not always better..... Im learning that "Combination is King".... There are so many applications for just pistons and matching them to the rod length to get the right compression ratio and going bigger bore I found gets me LESS!!! again WTH!!!! back to the drawing board....
My Build: 57 Chevy Pro-Street |
12-22-2015, 03:17 PM | #202 | |
Anthony |
12-23-2015, 06:23 PM | #203 | |
I think Im gonna look back at going with a supercharger, because with all the added costs of pistons, rods, etc. I can just use what I have and just bolt on some BIG HP.....
My Build: 57 Chevy Pro-Street Last edited by ptc; 02-04-2016 at 03:51 PM. |
12-23-2015, 06:26 PM | #204 |
Contact Race tech. They are cheaper than most and are mostly custom pistons. They are made In the USA as far as I know. I know it's a sbc but I paid $600 for custom spec pistons and metric rings for a 406 I was doing. SRP shelf pistons alone were more than that.
Anthony |
12-24-2015, 02:58 AM | #205 |
Are you losing one nugget or both nuggets. I have almost fainted getting prices for my BBC. Oh what the hell I never use em anymore. Nut Case
Been there, wrecked that |
12-24-2015, 08:48 AM | #206 |
Get a short block at oriellys, some good heads, intake, carb, ignition and a shot or two of nitrous....lol
SHAKE N BAKE BABY, SHAKE N BAKE.... http://67-72chevytrucks.com/vboard/s...d.php?t=686729 |
12-28-2015, 01:57 PM | #207 | |||
We got a plan now I think, so we will work the plan. The 700 club should be good enough....
My Build: 57 Chevy Pro-Street Last edited by ptc; 02-04-2016 at 03:52 PM. |
12-29-2015, 11:47 AM | #208 |
Subscribed.
"In an insane world a sane man must appear insane" ~Spock~ |
12-29-2015, 12:43 PM | #209 | |
Well I sold the WELD WHEELS and BIG tires.... but Pro-Street is NOT dead, it will still be a WIDE tire truck....
12-31-2015, 02:00 PM | #210 |
Hi Guys - I saw in very well produced build thread by "99 to Life" that he was putting costs and places where he buys things. So in an effort to put together a supplier list of people that are out to 'support our hobby' and not just their own wallets I will also post my costs and where I got them. (I hope this isn't against any forum rules).... I am all about capitalism at its finest, but there is a line at which consumers are just being taken advantage of.
We all do alot of shopping and time spent finding the best prices, why not share them? I'll start that list soon!
01-04-2016, 02:11 AM | #211 |
PTC Let me know the cost for a copy, I can use the list. Thanks Nut Case
01-04-2016, 03:54 PM | #212 |
No cost, no obligation just free information
Restoration Parts Source, Hayward CA - Rear Step Fenders 318.72 - Tailgate plain 152.32 - Fender Patch Panel 31.50 - Door patch int 64.39 - Shortbed Step 85.80 - Floor shift Cover 43.84 - F Fender Extension 43.84 - Battery Cover 53.43 Fix My Rust Restoration - Lower Door Skin 41.46 Montana Glass (AL 406-490-0085) Clear, Green, Tinted, Solex, - Door Glass 4 pieces 130.00 Locar Performance –Wilwood Brakes, - Big Ford Rear 140-2115 547.00 - Front 4 piston 140-8582 700.00 Each kit included parts for 2 wheels; rotors, hats, calipers, pads, mounting hardware, shims, instructions. Ledfoot Racing - Champion Radiators - 3 row cross flow Radiator 209.00 - Twin fan kit 74.98 Mar-K (They are very expensive and do not give any breaks on shipping costs. I would not buy from them again unless absolutely only supplier of parts needed, they charged separate shipping to me for the bolt set instead of throwing them into same box with hinges) - Hidden hinge set 60.00 - Sill mount hdwe 6.00 Classic Parts of America - Hidden Latch set 49.95 - Running board bolts 5.99 - Tailgate trunion set 8.95 - Roll pan 99.99 - Bed bolt kit 19.95 - Bed to Frame kit 11.95 - H/L Resto Kit 17.92 Classic Industries - Bed end teardrops 15.99 - Front panel hdwe 8.99 Pirate Jacks Hotrod Restoration - Brake Prop Valve 28.95 - Res Prop valves 9.50 Summit Racing - QA1 Front Coil Over 430.97 - QA1 Tube Arms Upper 349.97 - QA1 Tube Arms Lower 488.97 - QA1 Tie Rod Sleeves 58.59 - Trans mount 29.97 - BBC Motor Mount kit 69.97 Art Morrison - Panhard Bar kit 9”Ford 150.00 Ecklers Camaro/Truck Parts - Control Arm hdwe 39.98 - Brake line clamp kit 11.24 - Control arm shaft hdwe 18.59 - Steering box hdwe 15.99 - Cab to Frame hdwe 22.49 Rock Valley Auto Parts - 6x6 floor access cover 55.00 - 8x8 floor access cover 55.00
01-04-2016, 07:06 PM | #213 |
Whatcha gonna do for wheels?
01-05-2016, 01:38 AM | #214 |
PTC Thanks Nut Case
01-05-2016, 01:20 PM | #215 |
Ive got some in mind, working with a local wheel shop that Im trading some electrical work for to hopefully get the pricing down to where I can afford them! Its an MHT product (Foose).... and may be a first on these trucks.... not ready to choose yet.
01-05-2016, 02:59 PM | #216 |
Quite a list PTC, wish we could choose at that many overhere in Holland....
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
01-18-2016, 08:15 PM | #217 |
Well I got a few more new parts to be playing with but no wheres to get them on yet. Got a CHAMPION CROSS FLOW type radiator and an MESIERE electric water pump to play with the engine placement, found out where it needs to be. I want to do a custom radiator support that will include mounts for new inner panels Ill be making too. Something that looks like this:
The radiator is a little wider than the original support sheetmetal so I think Im going to remove all the original steel stuff and replace it with aluminum anyway. It is lower than the support top and thats what I was looking for in order to put a surround over the top of it and blend it into the inner panels. So heres the latest pics
My Build: 57 Chevy Pro-Street Last edited by ptc; 02-04-2016 at 05:49 PM. |
01-18-2016, 08:18 PM | #218 |
With the radiator set and the pump, now I know where the motor needs to be so Im making new motor mounting plates to move the block forward 1.5" and that will give me the room behind the motor to not have to cut the firewall.
The old "V" is the original mount and the larger one moves it forward. Ill post up more when I get everything welded up and ready to go in.
01-18-2016, 10:58 PM | #219 |
Looking good.
Kim |
01-19-2016, 01:01 PM | #220 |
So Im thinking either way I go I need to solid mount this motor as tight as possible, which way should I Go????? :
ChassisWorks Billet Mounts or Typical urethane Mounts
My Build: 57 Chevy Pro-Street Last edited by ptc; 02-04-2016 at 03:59 PM. |
01-19-2016, 07:51 PM | #221 |
Those billet ones sure look nice but probably cost a pretty penny.
Kim |
01-19-2016, 10:27 PM | #222 |
The billet ones are real nice but as mentioned they cost a lot more for something you won't see at all.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
01-20-2016, 12:54 PM | #223 | |
Ok Energy Suspension Systems it is.....
My Build: 57 Chevy Pro-Street Last edited by ptc; 02-04-2016 at 06:05 PM. |
01-20-2016, 09:03 PM | #224 |
That is why I like when I get to build for a few high ends I deal with, they want the best and done right which feels pretty nice but for the rest of us or my low $ customers then we think about how important each parts is..all still fun though especially when it all comes together..
01-21-2016, 04:14 PM | #225 | |
The Chris Alston stuff just takes it all to another "BLING" level ( I LOVE BLING!!! ) that the Richys like to show off to their Garage Drinkin' buddys.... or at a car show after its taken off a TRAILER!
