Old 07-22-2021, 08:02 AM   #526
SCOTI
SCOTI's Avatar
Re: New 64 Stepper Project
Nice touch.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-22-2021, 08:05 AM   #527
The Rocknrod
Moderator
The Rocknrod's Avatar
Originally Posted by SCOTI View Post
Nice touch.
Thanks Scoti.
Old 07-22-2021, 08:13 AM   #528
Joe Pass
Joe Pass's Avatar
love the striping....
Joe Pass is offline   Reply With Quote
Old 07-22-2021, 11:21 AM   #529
realvc
realvc's Avatar
Pinstriping
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 07-22-2021, 11:34 AM   #530
The Rocknrod
Moderator
Thanks Joe
Originally Posted by realvc View Post
Pinstriping
Thank you.
Old 07-22-2021, 03:29 PM   #531
cwcarpenter98
cwcarpenter98's Avatar
So, when are you going to wash the truck and give us some full beauty shots? These teasers are killing me
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 07-22-2021, 05:54 PM   #532
The Rocknrod
Moderator
Post 491 has them.
Old 07-22-2021, 10:02 PM   #533
cwcarpenter98
Originally Posted by The Rocknrod View Post
Post 491 has them.
Good point, but I meant with all the pinstriping on it too. Pinstriping or no pinstriping, your truck has turned out great!
Christian Carpenter
Old 07-22-2021, 10:08 PM   #534
The Rocknrod
Moderator
Thank you.
Old 07-29-2021, 09:00 PM   #535
justa dumb hick
justa dumb hick's Avatar
Perfect. Absolutely perfect.
The pinstriping really finishes pulling it all together.
A long trip indeed, I really enjoy seeing them completed. Lotta hours into this one.
Outstanding, Chief!
-JDH
Insomnia is a terrible thing to waste
https://www.youtube.com/watch?v=jWYVs7widI0
(Misanthropic curmudgeon attempts starting old truck in house at 2AM)
justa dumb hick is offline   Reply With Quote
Old 07-29-2021, 09:19 PM   #536
The Rocknrod
Moderator
Thank you
Old 07-29-2021, 10:40 PM   #537
forestb
forestb's Avatar
Not bad for a step side
forestb is offline   Reply With Quote
Old 07-30-2021, 07:07 AM   #538
The Rocknrod
Moderator
Thanks forest.
Old 07-30-2021, 09:23 AM   #539
aggie91
I'm just glad to be here!
aggie91's Avatar
Pinstriping is just enough on this truck. I like the one to separate the white and the red. Nice touch!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-30-2021, 09:35 AM   #540
The Rocknrod
Moderator
Thank you aggie91.
Old 08-10-2021, 03:35 PM   #541
The Rocknrod
Moderator
Drove it into Waco to get a tank of gas, about 15 miles each way. Up and down hills back-roads, stop lights etc. from 25 to 65 MPH.
Came home and used a laser temp meter and found these temps on the engine. I dont know if thats good or bad?
Top of radiator - 120 degrees
Top of Thermostat Housing - 191
Under the Thermo housing - 171
Head between first 2 exhaust ports driver side - 192
Front of head - 191
Block - 191
Temp Gauge reading (Lectric Limited sender for year model gauges):
So what do you think?
Old 08-10-2021, 04:35 PM   #542
SCOTI
SCOTI's Avatar
Front of head - 191
Block - 191
That all looks very acceptable. Head's will be the hottest so those areas @ the 190° range is good.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2021, 05:05 PM   #543
The Rocknrod
Moderator
Thanks for your help, wasnt sure.
Old 08-10-2021, 05:20 PM   #544
SCOTI
SCOTI's Avatar
What temp range thermostat are you running?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2021, 05:25 PM   #545
The Rocknrod
Moderator
180
Old 08-10-2021, 05:39 PM   #546
Joe Pass
Joe Pass's Avatar
I have the same exact readings.....I feel better too...lol...
Old 08-10-2021, 07:26 PM   #547
SCOTI
SCOTI's Avatar
180
I would expect around/within 15° of the thermostat opening point.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-10-2021, 07:55 PM   #548
The Rocknrod
Moderator
So 11 degrees is good huh?
Old 08-10-2021, 11:31 PM   #549
cwcarpenter98
My 63 gauge runs about that same degree on the sweep with my 180 thermostat and letric limited sender unless I'm running in 95+ weather when I've been going for a few hour At that point it will sit about in the middle. When I had a 195 thermostat in it, the gauge was almost pegged constantly
Christian Carpenter
Old 08-11-2021, 12:26 AM   #550
MT65
Front of head - 191
Block - 191
Those temps look fine, if a person could maintain a temp of 190 degrees, that would be a good fuel burn and easy on the engine, key word is maintain.
Question, is that still an amp gauge, or has it been mod to a volt meter? With what I saw in your engine compartment, I would be using a 100 amp alternator at minimum, if that is an amp gauge, it won’t handle it well….
MT65 is offline   Reply With Quote
