02-02-2021, 12:40 PM | #576 |
Re: Used Parts Build
Those little lights work good. I might have to get me some for under the Jeep.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
02-02-2021, 05:09 PM | #577 |
I'm just glad to be here!
How well has that Krylon coating on the exhaust holding up?
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-23-2021, 02:41 PM | #578 | |
I haven't driven it much but it seems to be holding up. The exhaust turbine is painted with the same stuff and under a blanket and its held up the same. While it scratched easily pre cured it seems to be okay now. Id try it again.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
02-23-2021, 03:10 PM | #579 |
My transmission was making a howling noise while in gear and stopped. It would go away in park and once driving though. After some research I figured the torque converter was bad. Bought a new one but hurt my back so it took a lot longer to get it in.
My wife got me this sticker. Hope it works through the computer so you can see it.
02-23-2021, 04:03 PM | #580 |
02-23-2021, 06:33 PM | #581 |
hahahahah yep. Figured people would get a good laugh thinking it was something truck related when it is really a Rick roll.
02-24-2021, 09:50 AM | #582 |
You can make your own custom ones so I was thinking maybe a link to your build here or something... This was better.
02-24-2021, 02:14 PM | #583 |
I'm glad someone appreciates it! I picked it for the recessional song at our wedding. She got to pick the processional song so I figured it was my time to shine.
03-08-2021, 02:01 PM | #584 |
Replaced the leaking output shaft seal. Seems to be leaking a tiny bit still though from the yoke though. Any thoughts?
I have been driving it around my neighborhood a bit to get some shake down miles on it and not be to far from home if I don't make it. Cut part of the bed mounts I made off so I can have them slotted for adjustment. Adding a bit more tube as well. I would like to say I planned on removing the bed gap but I set my rear end to be centered at ride height and not when laid out. So I pushed the bed forward a bit to make up the difference. The black strip is primer that I need to rattle can white or something for the mean time. The bedside isnt mounted or anything since I need to tweak a few things first. [url=https://flic.kr/p/2kJbn9C]
03-08-2021, 03:31 PM | #585 |
Looking good.....finally comes together.....you might check the yoke center plug....knowned to leak ...several methods of repair but the most common one is JB weld coated...just a thought
Joe |
03-09-2021, 09:33 AM | #586 |
Did you put rtv under that yoke nut? I'm not sure if it is necessary there as I don't have any 2wd stuff myself. I know I needed it on my transfer case output.
04-06-2021, 05:29 PM | #587 | ||
I got the bed on and have been driving it a bit. Lots of little things to do. I need to run my airlines and valves next.
04-06-2021, 10:59 PM | #588 |
Congrats...this is a big achievement......hard work and great results....inspiring to follow you through this and I'm looking forward to the future work...it's just the beginning lol
Joe |
04-07-2021, 11:51 AM | #589 |
Looks good out there on the street... Congrats
04-28-2021, 02:40 PM | #590 |
Thanks guys. I appreciate it. Been taking care of all the little things while I drive it around.
Added a second tab to the exhaust to keep it from pivoting. The bushing came apart since the exhaust was twisting on it. The blinkers wouldnt cancel and it felt funky when I went to signal so I replaced the cam. Been driving it a few times a week to try to find all the bugs and break the rear end in before I get it turned and try to turn it up.
04-28-2021, 03:14 PM | #591 |
That last pic! Truck looks really good. Honestly giving me more motivation to finish mine.
04-28-2021, 04:04 PM | #592 |
Looks great. Glad you are putting miles on it.
05-13-2021, 01:28 PM | #593 |
Took way to long to get this done. Finally finished welding, stripped, and painted my raised bed floor.
Had to cut off my shock mount and move it down a quarter inch since my initial measurements were off and it hit the bed floor. Finally got to play around with CAD and used Send Cut Send to make some tabs and brackets I needed. I bought line lock because Amazon told me too... and drew up the bracket in CAD. Need to plumb and wire it
05-13-2021, 07:37 PM | #594 |
Great skills.....enjoying your build
05-17-2021, 01:44 PM | #595 |
Thanks Joe.
Got my truck back together so I could take it to a few meet ups. Did my first wash is like 8 years. Now I need to figure out how to cover this all up. Here is my idea. I plan on having the pivot on the forwardmost tube which means I have to pull the floor away from the cabside a bit before pivoting. I plan to run a wood floor and have maybe 3ish feet in the center that pivots. I saw this thread: https://67-72chevytrucks.com/vboard/...d.php?t=819450 and started playing with cardboard. This is roughly what I ended up with. You can click on it for the video. I drew it up in QCAD (free software) and sent it over to Send Cut Send. Hopefully it works...I'll be out of town for the next week so hopefully I return to cool parts!
05-18-2021, 09:41 AM | #596 |
I drew it up in QCAD (free software) and sent it over to Send Cut Send. Hopefully it works...I'll be out of town for the next week so hopefully I return to cool parts![/QUOTE]
I see big things happening with "Send cut Send". Didn't know they existed? Thanks for the info. |
05-18-2021, 11:49 AM | #597 |
I heard about Send Cut Send from another you tube account I follow. I see it as a great way for a lot of builders to step up their builds from the old methods of doing things with a cut off wheel and a drill.
From the pictures you shared, the parts looks great and come all deburred and looks like they used a surface belt sander on the face of the parts.
05-18-2021, 02:36 PM | #598 | ||
I hope to start learning the 3D program so I can really make cool stuff!
05-18-2021, 02:49 PM | #599 |
A machine cut bracket is hands down better for repeatability vs. hand made. I go that route as much as I can when building things now.
06-03-2021, 02:10 AM | #600 | |
Drew up the brackets. Had them cut. Here is a video of them in action. I think I would do them a bit different next time but they will work well enough (I hope). Picked up this little fixture table off a company on Instagram (Dayton CNC). Was really cheap ($125) and seems to be high quality. Its small 6''x12'' but I figure Ill put it to good use some how. Went to drive it tonight after being out of town and decided to look it all over first... Universal coolant apparently doesnt work with dexcool. I didnt flush the engine before I hooked it all up. The rest of the system is new. I spend an hour or so flushing it with the hose. I ordered some radiator flush and will start again tomorrow. Ugh.
