Old 11-20-2020, 10:33 AM   #1
DonP67
67 C10 Longbed to Shortbed Conversion
Hi all,
New to the forum and a long time lurker. I purchased a 67c10 long bed a couple of years ago with the intention of shortening it from a LWB to a SWB truck (LWB will not fit in my garage). I was looking to have this done professionally at a shop and haven't had much luck in the Central Ohio area finding someone to do it.
I did find a shop that agreed to do it and being a little over zealous contracted them to do it last year without doing research on them. No progress has been made on the truck and I'm getting the run around from the owner... Live and learn I guess. My plan now is to get the truck back and explore alternative options, hence coming to the forum and seeing if I can drum up something here?
Any help or shop recommendations would be very much appreciated!
I did try the search function but didn't find much in regards to shops. A ton of threads about DIY which I am open to but would like someone with experience doing it to guide and assist.
Thanks,
Don
DonP67 is offline   Reply With Quote
Old 11-20-2020, 12:19 PM   #2
SCOTI
SCOTI's Avatar
Re: 67 C10 Longbed to Shortbed Conversion
Originally Posted by DonP67 View Post
Hi all,
Thanks,
Don
One of the best little shops out there is Boris @ StreetMachinery in Euclid OH
https://streetmachinery.com/
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-20-2020, 03:08 PM   #3
tim_mc
tim_mc's Avatar
HotRod Garage did a LWB to SWB in one of their episodes using the Brothers kit. Seeing the video might change your mind on doing it yourself. If you're not a welder, I believe the kit's c-channel will allow you to bolt it up so that you can trailer it to a shop to have the shortened frame welded together.
Welcome from a fellow long time lurker!
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 11-20-2020, 04:16 PM   #4
gmc684x4
I would feel comfortable putting my kids in my truck that was cut and welded to make a shorted
I would not feel comfortable with a cut and bolted frame
gmc684x4 is offline   Reply With Quote
Old 11-20-2020, 05:04 PM   #5
hevy_chevy67
hevy_chevy67's Avatar
The Brothers kit still require welding. The bolt in part just allows you to move it if needed.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is offline   Reply With Quote
Old 11-21-2020, 09:45 AM   #6
DonP67
I've looked into the DIY kits a good bit, the brothers one is pretty well documented on YouTube between their channel and a couple of others. Seems like it would be simple enough to have a couple of buddies over and see if we can't figure it out. I'll also look into that Street machine shop SCOTI mentioned. Thanks all!
Old 11-21-2020, 02:29 PM   #7
SCOTI
SCOTI's Avatar
Boris is a member here (way2lo2).
They sell: Truck-Arm suspension lowering blocks; budget air-ride kits, & big brake kits.
The shop is known for classic car sales that get the famous "Stop, Drop, & Roll" treatment:
* Big brake kits
* Lowering/Air-ride/Coil-Overs
* Wheels/tires/exhaust
* Late model engine & EFI conversions
* Nip & Tuck LWB to SWB conversions (w/blended patina/OG paint matching if desired).
His paint guy is one of the best patina guys in the business. The exhaust work on their builds is quite impressive as well as the EFI engine swaps.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-21-2020, 03:50 PM   #8
BigBird05
I just shortened mine. I took the dimensions from the shortening forum and just z chopped the frame. The hardest part was trusting my welding. I also made frame reinforcements to cover the chopped up section. I first bolted the frame reinforcement brackets in before I started welding. I saved the $450.00 that Brothers wants for there kit.
BigBird05 is offline   Reply With Quote
Old 11-21-2020, 03:54 PM   #9
gmc684x4
Here is a YouTube of Stacy David cutting down a long box to shortbox 67 72 truck and a thread how to do it
https://m.youtube.com/watch?v=PjlxpF8RL9Q
https://67-72chevytrucks.com/vboard/...d.php?t=123624
Old 11-21-2020, 07:15 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
I bought this kit pretty much because I wanted to see what the quality was.
https://www.longshotfab.com/products...bed-conversion
I have an extra C10 frame I'm going to try it on. I haven't installed it yet because of other priorities that came up but it looks pretty good. Comes with decent instructions.
LockDoc
Leon
Old 11-21-2020, 07:55 PM   #11
tutone
tutone's Avatar
I would trust my own work if I was proficient at welding. I don't know your skill level, but if you can read a tape measure and drill a hole, you are 90 percent there. Check out my build thread in my signature, and you can search an earlier thread of mine. I have documented 2 different methods. The last one Stacy David style. His way is easier with the cab off. Good luck to you.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1971 c10 swb/1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71
tutone is offline   Reply With Quote
Old 11-22-2020, 12:17 AM   #12
FRCvette
I see you are from Ohio as I am too. These guys specialize in shortening down c10's but they are in Knoxville Tn. Rusbuilt Street Rods. At least that is what I read.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 11-23-2020, 12:51 AM   #13
Peanut74
I used the Brothers kit to shorten my long bed. Could I have done it by copying David Stanceys method, yes. However, I also wanted to get it right the first time and make sure I had everything covered. IE: Shorten the frame, moving the rear cab mount, etc.
As stated above it is a C-channel that is bolted to your frame. Slots are in the channels to make sure your cuts are good and correct. You will need to get the frame welded but the bolts will hold everything together to get there. Overall I thought it was worth the money to make sure it was done right.
1967 C10 "Snowball" (Currently in a million pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
2012 Jeep JKU "Crush"
1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer)
1971 Chevy Blazer (Sold it)
Peanut74 is offline   Reply With Quote
Old 11-23-2020, 09:12 AM   #14
dagnabbitt
dagnabbitt's Avatar
LockDoc
That looks really interesting, let us know how it goes when you get around to it!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 11-23-2020, 11:33 AM   #15
LockDoc
LockDoc's Avatar
It may be a while now unless we have more mild weather. I will have to put one of my finished cars outside to have a warm place to work on it.
LockDoc
Leon
Old 11-23-2020, 01:54 PM   #16
jsprengeler
jsprengeler's Avatar
Has anyone had this done by a body shop utilizing one of these kits? If so, what did they charge you? I'm considering this, but I don't have the space, tools, and not comfortable with my abilities to do this right.
Incapable of not thinking about my truck at least every other minute
jsprengeler is offline   Reply With Quote
Old 11-23-2020, 02:08 PM   #17
SCOTI
SCOTI's Avatar
I don't know about the 'how much' question but I know of @ least 2 guys here in TX that did a LWB to SWB frame shortening in apartment complex parking lots by hiring local certified mobile welding guys to weld their frames. This was w/o kits like these; these type of kits would only make it easier to ensure proper cuts & alignment.
A corporate body shop chain probably wouldn't do it but a local independent body shop or welding shop would be the better choice. It won't get done on the cheap though. I would expect a minimum of 3hrs time charged @ >$100/hr labor rate (shop space, the experienced guy doing the labor, consumables, validating fit, equipment set-up + their profit margin).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-23-2020, 02:20 PM   #18
EagleChief
EagleChief's Avatar
LockDoc
This guy is local to me. I have also "saved" them to use in the future. They'll usually run a "Black Friday" deal - at least in the past, they have. It looks pretty simple, and at half the cost of the Brother's template.
He also is working on a lot of other "projects" that seem to be future offerings. He 3D models suspensions, frames, and several other custom jobs for a few different projects. Makes some racecar stuff too.
I got a quote from a guy in my area to do the conversion. $1900 and about 2 weeks, or so. Shorten the frame, the bed, the driveshaft (and balance), breaklines, wiring, etc. Basically, drop it off, he does it, you drive it home. Didn't seem like a bad deal, to me.
1971 C10 - Hugger Orange/White
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197
LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460
EagleChief is offline   Reply With Quote
Old 11-23-2020, 05:18 PM   #19
jsprengeler
Thumbs up Re: 67 C10 Longbed to Shortbed Conversion
$1900.00 seems like a steel!
Old 11-23-2020, 09:41 PM   #20
Peanut74
x2
$1900 is a good deal and well worth it. If I had found someone to do it for that price it would have saved me a bunch of money just changing the bed.
