05-03-2021, 07:18 PM | #1 |
Repop window regulators?
When I reassembled my doors with new felts, etc., I picked through several regulators I had for the best ones. Still my drivers window comes down just a bit as I'm driving and then it rattles inside the door. Are the repop regulators any good? Does the quality vary with different vendors?
05-03-2021, 11:11 PM | #2 |
Re: Repop window regulators?
I can't help on the repop stuff, but I do have a question for you. Did you adjust the window stop? I have a really loose regulator on my passenger side (almost a 1/4 turn loose) but it doesn't go down any farther than the stop. I think the factory assembly manual shows that stop
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-04-2021, 07:27 AM | #3 | |
05-04-2021, 07:37 AM | #4 |
Moderator
I bought mine at the Truck Shop in Orange, CA seem to work as normal, strong feeling installed, easy to roll up and down.
05-04-2021, 11:18 PM | #5 |
Same for me. Truck Shop, no problems.
1963 C10 short-wide Turbocharged 454, T56, 4.11 posi http://67-72chevytrucks.com/vboard/s...d.php?t=605408 1963 C10 suburban Unknown, unknown, 3.73 open http://67-72chevytrucks.com/vboard/s...d.php?t=622037 |
05-05-2021, 04:45 PM | #6 |
The repop I bought from LMC lasted one use before it stripped out at the handle splines. They refunded my money and told me to keep it. The originals are milled steel, the repops are cast pot metal.
05-05-2021, 07:53 PM | #7 |
I had heard some repops were poor quality.
So far LMC no, Truck Shop yes. Others? |
05-06-2021, 06:31 AM | #8 |
Moderator
Ya I have no pop metal on my window regulators from the truck shop.
04-10-2022, 07:45 PM | #9 |
Well my truck is still tucked away for winter but should come home in the next few weeks. I ended up with two different brands. The gold one is WAI Global. The black one is off ebay and I don't know the brand. The gold one is slightly heavier metal and the teeth have more meat. The gold one is a bit stiff at the X of the arms but moves smoothly while the black one is plenty loose at the X.
And what is with the rollers on the gold one? They don't roll, they're fixed. They have a slight taper. Only thing that looks stronger on the black one is the spring is heavier. |
04-10-2022, 10:47 PM | #10 |
Moderator
Remove the black caps there are rollers underneath.
04-11-2022, 09:47 AM | #11 |
04-11-2022, 11:51 AM | #12 |
Moderator
The reason I know is that it has been a question in the past.
04-14-2022, 12:51 AM | #13 |
I'm rebuilding mine. I first cleaned them up by soaking in CLR for a few days. I didn't want to use my blast cabinet because I didn't want to get glass dust in the mechanisms. I bought new rollers and new regulator kits from Classic Parts. The rollers came with new rivets and regulators are very well made and also came with new rivets. The splines for the handles look nicer than the originals.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
04-14-2022, 03:46 PM | #14 |
I got one from Brothers, seems pretty good.
