Old 10-15-2021, 05:33 PM   #76
dagnabbitt
dagnabbitt's Avatar
Re: Small Block Crate Engine Advice
Ok one last question, I am past the break-in period for the engine and need to do its first oil change.
I was planning on using 15/40 T4 Rotella. Engine is a roller cam (not flat tappet), so I think a good quality oil with no additives would be fine. But should I use a 10/30 instead?
I asked Blueprint this question last week, but - you guessed it - no response from them, just crickets.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-15-2021, 06:22 PM   #77
Rickysnickers
Considering your climate, 5w30
Old 10-15-2021, 08:29 PM   #78
AcampoDave
AcampoDave's Avatar
Why desil engine oil?
AcampoDave is offline   Reply With Quote
Old 10-16-2021, 07:20 AM   #79
dagnabbitt
dagnabbitt's Avatar
Blueprint recommends T4 for their flat tappet engines - not sure why, probably it has some sort of ingredient that usually appears only in additives - just not sure if it the correct application for a roller or not. Just generally speaking, I am wondering if a 400 hp 355 with a roller should get 10/30. And if answer is yes, what is the best brand of oil. I have never had an engine that didn't burn or leak so my preferred oil in the past has always just been whatever was on sale.
As to the climate here, that is relevant of course, but I will be parking it for the winter soon, this is a summer ride only.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-16-2021, 11:05 AM   #80
MySons68C20
MySons68C20's Avatar
VR1 10W-30 I believe would be best. We have to order it online here because the local shop only carries the 20W-50 in stock.
https://sharena21.springcm.com/Publi...2-ac162d889bd1
MySons68C20 is offline   Reply With Quote
Old 10-16-2021, 06:31 PM   #81
burnin oil
Since you are willing to run diesel oil why not just pick up a lighter wieght. Both Walmart and the farm supply stores stock it down here. I personally run diesel oil in my flat tappet motors without issue. I maintain way more diesels so I have it by the bucket. Its light years better than standard gas oil but probably not as good as the high doller race oils. Been keeping my 400sb with a solid cam going for 6 years now and I am far from nice to it.
burnin oil is offline   Reply With Quote
Old 10-16-2021, 09:39 PM   #82
The Rocknrod
Moderator
The Rocknrod's Avatar
When I got my engine from BP they gave me a large envelope with all info needed including types of oils recomended.
Old 10-17-2021, 04:44 PM   #83
dagnabbitt
dagnabbitt's Avatar
Thanks Rocknrod, I was on their website and couldn't find what I was looking for, but it was indeed in the package.
It simply says that Roller cams engines can use any conventional 10w30 oil, so I guess that they are not picky. I was going to use the T4 Rotella but I guess I will just look for a high quality 10w30.
Since it is going to get one oil change a year I might as well use the best. Should I go with the zinc additive oils, even though the specs don't call for it, or is that an incorrect assumption/a waste of money.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-17-2021, 05:50 PM   #84
The Rocknrod
Moderator
I used the Blueprint Break In Oil and will change it pretty soon (after 500 miles) to a quality 10-W30.
Old 10-17-2021, 07:54 PM   #85
dagnabbitt
dagnabbitt's Avatar
What 10w30 do you plan to use?
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-17-2021, 08:50 PM   #86
The Rocknrod
Moderator
Dont know, havnt gotten there yet.
Old 10-20-2021, 12:13 PM   #87
dagnabbitt
dagnabbitt's Avatar
I went with regular old Shell 10w30 for my first change. I expected my oil pressure to drop a bit with the straight 30 weight out of it, but its at 80 all the time. That high volume oil pump is sure doing its job.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 11-06-2021, 04:27 PM   #88
garyd1961
Deleted
garyd1961 is offline   Reply With Quote
Old 11-07-2021, 11:11 AM   #89
vince1
If you are using it in the winter I'd go synthetic 5-30. Apparently it flows a lot better in the cold than conventional.
But since you've already changed it maybe plug it in first before starting in the cold. I am using the Boss Oil cam oil in the truck now which is a conventional oil with more zinc or whatever in it. I try plugging it in first for an hour or two before starting in the cold. It makes quite a difference. Once all my conventional oil is used up I think I'll go synthetic in everything, truck and Rambler included.
vince1 is offline   Reply With Quote
Old 11-07-2021, 11:29 AM   #90
tdangle
tdangle's Avatar
in my new GM roller crate engine I run synthetic 10-30w mobil one as recommended.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-09-2021, 10:41 PM   #91
The Rocknrod
Moderator
If you own a Blueprint engine follow their instruction on oil. Syn cant be used until so many miles.
