Old 04-15-2002, 10:19 PM   #1
Brian19692
Post Electrical Question
Last week my under dash and headlight harnesses burnt. I replaced with used ones yesterday. Now I have no headlights, dash lights, or dome light. I replaced the switch and still nothing. I have power in and out of the dimmer switch. Any ideas? Thanks.
69 short box 4x4
72 long box
69 Camaro 327 4-speed
71 4x4 suburban, soon to be crew cab short box
87 S-10 V-8 FOR SALE
Des Moines, Iowa
67 short 2wd. FOR SALE
69 long box w/72 grill
Des Moines, Iowa
Brian19692 is offline   Reply With Quote
Old 04-15-2002, 10:54 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Post
You should have one red hot wire going directly to the headlight switch that is hot straight from the battery. If you don't have that, you won't have nothing. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer New project
1995 K1500 Sub(Mommas car)
1989 VW Golf(Beater)
Will be the daughters car if she will pay her insurance! Ha!
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 04-16-2002, 08:46 AM   #3
HuggerCST
HuggerCST's Avatar
Post
Do you have power at the red wire on the switch? Tailights? I assume you do if you have power through the dimmer. If you have power at the green or the tan wire (hi and low beam) at the dimmer then you should have power at the headlights, unless the wires are burnt, because they go straight to the headlights. As for the dome and others, have you got power at the fuse? Hope this helps.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 04-16-2002, 05:55 PM   #4
Brian19692
Post
I have power at the switch and the dimmer switch, but not at the headlights. I have taillights and side marker lights. Maybe it didn't make a good conection at the fire wall. I'll check that tomarrow. The dash harness is a 69 and the headlight harness is a 72. That shouldn't make a difference should it?
69 short box 4x4
72 long box
Des Moines, Iowa
Des Moines, Iowa
Old 04-17-2002, 10:36 AM   #5
HuggerCST
HuggerCST's Avatar
Post
I wouldn't think so, but not positive. Did you hook up the headlight ground wires at each side of the rad. support when you changed the headlight harness?
Wynne
Build thread
53 Chevy shortbed
69 Camaro
Old 04-17-2002, 03:25 PM   #6
68 Stepside
huh?
68 Stepside's Avatar
Post
Make sure all of your grounds are good, and you said the dimmer switch is ok? If you're not sure on that, try running a jumper wire across it, just to check.....
68
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
