12-17-2006, 06:52 PM | #1 |
Keep On Keepin' On
3 in Drop Spindles...
I have not heard anything about Belltechs 3in drop spindles...I assume my 15in rims arent going to work...Would like to get a 3/5 drop
12-17-2006, 07:44 PM | #2 |
67-72 parts collector,…
Re: 3 in Drop Spindles...
15's will work,... but you WILL have to grind a little clearence on the lower control arm just below the lower ball joint. I've done it a 1/2 dozen times or more. No big deal. When you are done,... put the wheels on and check clearences when you turn the wheels lock to lock. Make sure the truck is on the ground not on the jack stands.
