09-01-2007, 01:14 AM | #1 |
Project "Shell Game"
Well just like the title says! I will be taking three projects that I have laying around and mixing them all up untill I come out with a few different directions. I have way to many projects of my own right now and I want to cut down on a few and make room for an English well, Power bead roller, 5' Shear and break.
The first one is known as "Slow Build" because it has be an ongoing project for over 9yrs now and I am just burned out and want to go in different directions but I am in to this project way to deep to just sell it for $0.25 on the dollar. Then I have Low Buck that I am hapy with but still want to change it up abit since it will be my only truck soon. Last but not least in my 70 Factory 2WD Blazer that needs everything. So I will be tearing Slow Build apart and using the 92 vett LT1 and custom built 700R4 with Sanderson Headers and painless's Perfect RPM harness and computer kit into Low Buck. I have over 8k in this motor/tranny combo and if I tried to sell it I would get maybe 2-4k for it so I decided to keep it around. It is pushing about 360+hp and should get me in the low 20's for gas milage. The tranny was built by ATO in Northern Ca. to handle 700hp out of a small block and has a fully welded 2400rpm converter. I also have a full Vintage Air kit sitting in boxes that I will drop into Low Buck for these nice 100+ days in Winters I will drop the current 350/350 combo from Low Buck into the Blazer, it's a new crate motor that will make for a great power plant for cruising the streets. Then I will take the full air ride kit and all the suspension out of Slow Build and swap it into the Blazer. It is 5lug, 3" drop spindles up front and out back is a 12bolt stuffed with 3.43's, eaton posi, ECE adjustable panhard bar and shock relocator kit. The rear arms have been cleaned, por15'd and have new bushing's. Then all the stock parts from the blazer will find their way into the Slow Build truck. Then I was going to put the 68 front end from Slow Build on to Low Buck but my wife really likes the 67 hood I have on their now so I will pu the 68 front end on the blazer and with the tilt hood it should make for alot of head turning. Once this is all done I will sell off Slow build. It has had all the normal rusted areas fixed, been body dropped 2", the bed floor was sectioned 6" to allow the truck to almost lay rockers. It was tubbed 7" and has a 35 gal SS fuel tank that is set up for an LT1 typ motor. Today my Father in-law has been itching to turn a wrench for awhile now. He was a large truck machanic but the last 15yrs has been behind a desk so he came over and gave me a hand today on a few projects around the house as well on the tear down of Slow Build. We got pulled the front sheet metal, motor/trans, front cross member fully loaded and the rear suspension. If I get a chance this week end I will start pulling the motor out of Low Buck as well as the heat/AC system. Kevin LFD Inc. |
09-01-2007, 01:42 AM | #2 |
Re: Project "Shell Game"
Sounds like half the battle with these trucks was coming up with a plan. I bet you feel good now!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
09-01-2007, 02:29 AM | #3 |
blood type; Retumbo
I say you should keep things in their original state and find somewhere else to put the new tools. living rooms are over rated anyway.
09-01-2007, 04:56 AM | #4 |
Life, Be In It.....
I read your other post about switching things around and like what you came up with. I hope it all works out for you. Let me know if you a hand with moving things around. Good Luck
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
09-01-2007, 03:44 PM | #5 |
Tool Addiction=Money Shortage
Re: *SHELL GAME*
Sounds like a lot work but should be rewarding to get both the blazer and low-buck on the road. I love watching your builds, but I have a couple questions. Is low buck still going to be the "LFD Shop Truck" after the transformation and is a 2400stall converter a good choice for a truck that will see a lot of towing and hauling?
1967 K20 400TBI SM465/NP205 posi front, Detroit locker 4.56 rear |
09-01-2007, 04:16 PM | #6 | |
Re: *SHELL GAME*
Here are a few pics of todays work so far. The engine is bolted in and it is time to start the fuel system. Kevin LFD inc. |
09-01-2007, 11:24 PM | #7 |
Re: *SHELL GAME*
Not to bad for one days work. The LT1 is bolted into its new home, the fuel lines are all built and installed I just need to order one fitting for the return line. I made the power steering PSI hose out of the vett hose and flaired a new end onto it for my PS box. I also bent up a return line that goes from the pump over the cross member to the resevoir that is on the passenger side. All my guage's are hooked up and I pulled out the old A/C unit from inside the cab so I can start getting the new unit mocked up. I will be ordering a few items tonight if I get a chance and that should do it for the day.
Kevin LFD Inc. |
09-02-2007, 08:37 AM | #8 |
Re: *SHELL GAME*
Nice!
09-02-2007, 12:47 PM | #9 |
PROJECT 7DEUCE
Re: *SHELL GAME*
Seems like selling off one of those fords would help ya too.... I have been in the same scenerio and it sucks but a mans gotta do what a mans gotta do...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-02-2007, 05:14 PM | #10 | |
Re: *SHELL GAME*
Kevin LFD Inc. |
09-03-2007, 09:18 AM | #11 |
Tot Roddin'
Re: *SHELL GAME*
Looks great!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-03-2007, 10:31 AM | #12 |
Re: *SHELL GAME*
My week end was cut short in the shop but I got some more father and son time in so it was a good trade. I did get the exhaust cobled together for now and I will have my exhaust guy clean it up once it is on the road. I have almost all the new A/C installed and lines made up. I need to get the heater lines hooked up then on to the engine wiring. That should only take an hour or two and most of that time will be pulling the old system making room for the computer and relays. Then I will get the driveshaft shortened next friday and it should be almost ready to hit the road again. It's first time out of the shop should be pulling the Trazer to the blasters.
Kevin LFD Inc. |
09-03-2007, 03:23 PM | #13 |
Re: *SHELL GAME*
Here are the rest of the pics from this weekend. Elect fans are mounted, A/C lines are rough'd in and it is starting to look like somthing.
See you next weekend! Kevin LFD Inc. |
09-15-2007, 12:22 AM | #14 |
Re: *SHELL GAME*
Well it's a live! Went for the first test drive today and our trucks mixed with Vett parts is a good combo. This thing has tons of power and the 700r4 just plane rocks! Lights them up in first gear right to 5k RPM, barks second, chirps third and by the time you hit fourth you are well over 100 and it just keeps on going. The install turned out real clean and I tried to give it a factory type look. I had to convert it from linkage to a cable pedal in order to use a factory cable for a 96 Impala then I had to shorten the cable down about 5-6" for it to fit and look right. I will get the exhaust done in a few weeks when I have a chance to head over and get duels put on it. The single worked well for a 200HP motor but with 360+HP now and good headers I feel it is a little restricted. I still have a few wires to address and wrap then it is time to get back on the Trazer. So what do you think?
Kevin LFD Inc. |
09-15-2007, 08:56 AM | #15 |
Re: *SHELL GAME*
Looks great. I bet it is a blast to drive.
Cheers, Tony A day without sunshine is like, you know, night. 1970 Chevy CST10 (Green) 2005 Silverado Z71 2000 Pontiac Bonneville |
09-15-2007, 09:28 AM | #16 |
Re: *SHELL GAME*
is that a trans crossmember in one of those pics? if so did you build that or can i purchase that from somewhere? i know you have an lt but would that work for an ls series motor? nice build so far though.
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife: 71 cab for sale in parts classifieds! 2004 black chevy 1500 "finish your beer, theres sober kids in india!" |
09-15-2007, 10:00 AM | #17 | |
Re: *SHELL GAME*
Yes that is my cross member that I built about 8yrs ago and when I was having Sanderson's build some one off headers they ceramic coated it at the same time for me. It was built for a 700R4 but that style would work for any tranny if the bolts are set right. It is also designed for high mounted exhaust for extra clearance. Kevin LFD Inc. |
09-19-2007, 06:43 PM | #18 |
2wd FTW!!!!
Re: *SHELL GAME*
So Are You Going To Start On Your Blazer Soon?????
09-19-2007, 08:58 PM | #19 |
Retired Air Force 87-09
Re: *SHELL GAME*
Looks great. Nice install. Good move with the projects.
Hope it all works for you and thanks taking the time to put this out. Rich |
09-21-2007, 11:33 PM | #20 |
Life, Be In It.....
Re: *SHELL GAME*
That looks really nice in there Kevin. I can't wait to see it and how the rest of the shell game is going.
09-22-2007, 10:32 PM | #21 |
Re: *SHELL GAME*
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
09-28-2007, 09:25 AM | #22 |
Re: *SHELL GAME*
Well I drove the truck to work this week (304miles round trip per day) and it did flawlessly. I had her opened up most of the time between 70 and 90mph (that was keeping up with trafic on I-5 and I-99) and still got about 16MPG out of it. The only thing I want to look into doing in the next few months before paint is streaching the pedab out abit. I am 6' and getting older and my legs don't like being bent for long periods of time. What I would like to do it two fold, first move the brake and gass pedal about 3" tward the fire wall for more leg room and second is have a nice bench seat built that is only about half as thick in the back as the stock seat. This will give me 6" of extra leg room and should make a world of differance in driving commfort.
Kevin LFD Inc. |
09-28-2007, 06:30 PM | #23 | |
A guy with a truck
Re: *SHELL GAME*
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-28-2007, 08:15 PM | #24 |
Re: *SHELL GAME*
10-05-2007, 07:20 PM | #25 |
Re: *SHELL GAME*
I wanted to keep track of my new tranny temp but also wanted to clean up the interior abit. For me that ment getting rid of the funky 2 gauge clusted that is mounted below the A/C controls. So my oil psi is hooked back up to the factory dash cluster gauge and soon so will be the water temp.
The trans temp I wanted in a not so visible place for all to see but I needed to be able to see it while driving So I made a gauge pod to fit along side the stock set up between the door and cluster. It turned our pretty good for my first fiberglass project in over 15yrs. It will end up getting painted the same color as the dash once the truck gets painted. Kevin LFD Inc. |
