Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 10-12-2008, 09:15 PM   #1
69ChevyRazorback
what size subs can we fit behind a 69 c10?
I haven't pulled out the gas tank yet, but im thinking I can get a sub with around a 7" mounting depth pretty comfortably. am i pretty close on this guess>?
69ChevyRazorback is offline   Reply With Quote
Old 10-12-2008, 10:07 PM   #2
dirtyd_nd
Re: what size subs can we fit behind a 69 c10?
JL Audio 10w3's will fit. I'm not sure of the 12s. And depending on how much bass you want. The 8w7 will fit at 6.83. And don't laugh about it being an 8" sub. These things are amazing. I would go for a set if they weren't $450 each. Oh I'm a fan of JL, but there are many others out there that will fit too. Just depends on what you want and how much you are willing to spend.
Dale
dirtyd_nd is offline   Reply With Quote
Old 10-12-2008, 10:58 PM   #3
nrb's70gmc
nrb's70gmc's Avatar
i have 2 mtx 4000 10 inch subs behind the seat thay were around $200 a piece i believe and thay sound great for the price i have them set up with a 440watt amp the subs are 200watts a piece if i remember
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 10-13-2008, 07:00 PM   #4
70short
Talking Re: what size subs can we fit behind a 69 c10?
This is what I have with 3-10's. MTX I have had them for along time.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 10-14-2008, 02:08 AM   #5
mine4now
I saw this JL Audio setup this weekend. Three 10" subs and it hit hard.
mine4now is offline   Reply With Quote
Old 10-14-2008, 06:18 AM   #6
AceX
>130dB Moderator
AceX's Avatar
A 10" sub (or several of them) are your best bet. You can't just factor in the depth of the sub, you also have to consider the space that the enclosure's materials will consume.
A 6" mounting depth + a 3/4" MDF enclosure + cosmetic materials (carpet, firberglass, etc.) = ~7"
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 04-01-2009, 10:22 PM   #7
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
The JL audio 12" sub, will fit under any 67-72 bench seat if done right. I just had one put in last week and my tank is still behind the seat.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 04-02-2009, 12:49 AM   #8
nrb's70gmc
nrb's70gmc's Avatar
i just picked up a spare cab so i am going to use it to mold (fitted)fiberglass boxes (ware the sock gas take goes) after i get a few done maybe i will start selling them
Old 04-09-2009, 09:42 PM   #9
Riveted1
Tasty Cakes!
Riveted1's Avatar
You can put pretty much anything except for the absolute deepest of subwoofers, as long as you are willing to give up leg room. Budget, sound level requirements, amp power, seat position, etc. all come into play. Based on your question, it's hard to give you an exact answer.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
