Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-09-2009, 11:48 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Amp Wattage
I have these 10's and wanted to know what size amp I should go with. It will be the only thing that will be ran off the amp.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 02-10-2009, 02:59 PM   #2
tommyd241
tommyd241's Avatar
Re: Amp Wattage
What model/voice coil configuration are they?
tommyd241 is offline   Reply With Quote
Old 02-10-2009, 04:03 PM   #3
AceX
>130dB Moderator
AceX's Avatar
Re: Amp Wattage
It looks like the absolute max power handling is 125w @ 4ohm each.
An amp that puts out 250-300wRMS @ 2ohm or @ 8ohm depending on how you want to wire them.
Pull one of the subs out and find the power hook ups. There should be something there that will tell us what ohm the voice coil is.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 02-10-2009, 06:45 PM   #4
5150
C10 Club Tennessee
5150's Avatar
Re: Amp Wattage
On the back of the sub it say 10 W O(with a line through it) and then 8. So I would assume they are 8 ohm.
Bryan
www.gmtruckshow.com
Old 02-11-2009, 05:52 AM   #5
AceX
>130dB Moderator
AceX's Avatar
Re: Amp Wattage
Yep, 8ohm. You can wire them in series which would bring it down to a 4ohm load. Most small monoblock amps can handle this no problem. just be careful not to give them tons of power. 300w total would be the MAX I would subject these woofers to.
Look at an Arc Audio KS125.2 Mini or KS500.1 Mini. Even the KS300.2 would work well.
I know you're going with other speakers, and I'm not sure if you have another amp yet, but the KS900.6 amp from Arc Audio would be ideal for your set-up.
Living Life @ 130dB
RIP El Jay
Old 02-11-2009, 11:59 AM   #6
5150
C10 Club Tennessee
5150's Avatar
Re: Amp Wattage
So just a 300W mono amp will take care of both of them?
Bryan
www.gmtruckshow.com
Old 02-11-2009, 03:39 PM   #7
tommyd241
tommyd241's Avatar
Re: Amp Wattage
Yep. That'll give you 150W RMS to each sub. Here is a nice amp. Just keep the gain down and you will be good. http://www.edesignaudio.com/product_...products_id=45
Old 02-23-2009, 11:04 PM   #8
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Amp Wattage
Don't you mean parallel?
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
