03-14-2009, 06:20 PM | #1 |
proportioning valve question for disk conv
i have a 70 c10 i bought a performance online disk brake conversion kit and a booster and mastercylinder from autozone to save some money. i bought both a proportioning valve made for disk conversions, and a adjustable valve for the rear lines. problem im having is the proportioning valve i bought haves 5 holes for lines to go in. but i only have 4 lines to plug into it. i pulled this picture from the faqs ive been reading to answer my problem and noticed this small piece on top that i dont have. any help on this? thanks
03-14-2009, 06:31 PM | #2 |
Nothing to see here.....
Re: proportioning valve question for disk conv
on some of the aftermarket prop valves (talking CPP part# PV-1), you will have 2 line connections for the front. you will only use 1 of those. you will need to plug the one you are pointing to in the picture above.
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
03-14-2009, 06:35 PM | #3 |
thank you sir, that was my first tought but wanted to make sure, will i be fine if i only run the proportioning valve w/o the adjustable one for the rear brakes?
03-14-2009, 06:45 PM | #4 |
I don't have an adjustable valve on my rears. I never had a problem, but many people will tell you it makes the system much better.
03-14-2009, 06:48 PM | #5 |
right on ill get these installed tomorrow and get the beast back on the road, thanks
03-14-2009, 06:59 PM | #6 |
This is my set up on my '72 3/4 ton.....
'72 GMC custom camper 350/350 |
03-14-2009, 10:21 PM | #7 |
Old member
This is my 71 1/2 ton. The only time I have ever had a issue with the backs locking up is in a emergancy stop in the rain. On dry pavement they have never been a problem.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 03-14-2009 at 10:22 PM. |
03-14-2009, 10:49 PM | #8 |
Black 72 Chevy
Bleeder.
72 Chevy, SWB, 350engine, TH400 |
03-15-2009, 09:47 PM | #9 |
one more question, on the bottom of the proportioning valve the line for the front brakes the fitting that goes in there is 1/8 and i can only fit a 1/8" line all the other lines are 1/4" is this the same on yall?
03-15-2009, 10:56 PM | #10 |
Firefighter
That line is 3/16" and the thing in your first pic is a bleeder screw.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
03-15-2009, 11:21 PM | #11 |
Not sure what size the brake line has, it is a stock '72 3/4 ton. The proportioning valve is from CCP. They also sell refurbished stock proportioning valves, but they cost more than their inhouse brand.
03-16-2009, 06:54 PM | #12 |
I also have a question on this subject my truck came with 4 wheel drums . I changed it to 4 wheel disc will the orignal proportioning valve work.
03-16-2009, 07:22 PM | #13 |
4wheel drums to 4wheel discs you need to change both the master cyl and the prop valve for proper operation
03-16-2009, 07:23 PM | #14 | |
no. you should go with a front disc/rear drum prop valve with an adjustable valve governing the rear. I don't think a specifc disc/disc valve is offered.
03-16-2009, 07:42 PM | #15 | |
67-72 parts collector,…
I got mine at the local ACE Hardware store. They are specialty fittings. (Inverted flare adapters)
03-16-2009, 07:57 PM | #16 |
all silverados made in the past 6-7years have 4wheel disc master cyl and proportioning valves thats what i'd be looking at to use for 4wheel disc brakes on a chevy truck
01-07-2016, 09:11 PM | #17 | |
Thanks for your help
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
01-07-2016, 10:34 PM | #18 |
Corvettes of the era offered a disc/disc master, I believe. I don't know what was used in the JL8 Camaros, but I assume the same unit. Parts-store cheap, either way.
Don't forget that on 3/4T the front is the rear line and vice versa, at least as I recall it was backwards from that 1/2 tons.
01-07-2016, 10:42 PM | #19 |
[QUOTE=davepl;7439153]Corvettes of the era offered a disc/disc master, I believe. I don't know what was used in the JL8 Camaros, but I assume the same unit. Parts-store cheap, either way.
Don't forget that on 3/4T the front is the rear line and vice versa, at least as I recall it was backwards from that 1/2 tons.[/QUOTE It is a corvette style master cylinder with a pol proportion valve. Just want to make sure I have everything I need when I go to hook it up. Thanks. Posted via Mobile Device |
