06-13-2009, 02:32 AM | #1 |
Bag install for 69 front
Hi Guys just fitted up bags as coil replacements on rear , ride height is a lot better , any help or advice ( pictures) on fitting front bags thanks in advance Ray
06-13-2009, 09:56 PM | #2 |
67-72 parts collector,…
Re: Bag install for 69 front
Nice truck!
I suggest you search around in the suspension section. There are quite a few members on here that are running bags.
06-13-2009, 11:53 PM | #3 |
Tot Roddin'
Ray, what drop did the '69 have before the rear bags?
Search through several of the threads in the suspension section as lolife99 mentioned and you will be set. Even in some of the build pages (sub forum under the 67-72 Message Board) will have several install threads for you to read through as well.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-14-2009, 09:48 AM | #4 |
Happy to be here
Are you keeping the drums up front? I suggest you upgrade to a later front suspension that includes disc brakes.
As far as adding bags, it's pretty simple. You remove the coils and ad mounting plates up top. You can use cups on bottom, or explore other options if you want to get lower.
06-15-2009, 04:49 AM | #5 |
Laid Lo
N2TRUX-
Are those plates from *****************? Looks like a good fit. Did you just use drop shocks or are you running different brackets too? Thanks
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
06-18-2009, 02:21 AM | #6 |
Thanks N2Trux running drums and gonna stay that way at the moment
cheers Ray |
06-18-2009, 02:28 AM | #7 | |
Cheers Ray |
06-18-2009, 09:15 AM | #8 |
Happy to be here
Everything on my truck is from Air Ride Technologies. The shocks are shorter heavy duty fluid shocks with stock brackets.
06-18-2009, 02:40 PM | #9 |
good lookin truck!! the rear looks a lot better....
06-18-2009, 03:34 PM | #10 | |
Señor Member
edit: oops... should have read further in the post. What N2TRUX said.
06-18-2009, 03:35 PM | #11 |
Redefining LowBudget
I just went though this and the best way is to cup the lower A arms 2 3/4" works perfect and gives a great ride and stance...
spraybomb has a great post on how to do it but it's basicly a 8"X23/4" piece of pipe a piece of flat stock and you cut out the lower spring pocket and weld in the pipe.... and the monroe 5257 works great for the drop
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
