Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 08-18-2009, 06:37 PM   #1
cajun chevy
cajun chevy's Avatar
Unhappy removing wax that is too dry?
I waxed my truck and left the wax to dry too long. I am having a hard time removing the wax.
Any tips.
Thanks.
cajun chevy is offline   Reply With Quote
Old 08-18-2009, 10:19 PM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: removing wax that is too dry?
Purchase a quality detail spray and use it to wet the wax and then wipe it off. If you are not in the same proximity of a parts store, get a spray bottle and fill it wilth water and use it. Kind of like spit-shining a pair of shoes. The detail spray has some oils mixed in the fluid to help with lubricating the paint as you wipe it off.
piecesparts is offline   Reply With Quote
Old 08-19-2009, 12:15 AM   #3
sangermike
sangermike's Avatar
just wash it off with car wash soap. it will still be waxed.
sangermike is offline   Reply With Quote
Old 08-19-2009, 09:23 AM   #4
dammitmitchell
the pollock
dammitmitchell's Avatar
lightly moist microfiber spongy...
or a microfiber towel and spray detailer..
spray small sections of wax with the detailer.. and "wax off" that crap....
good luck
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 08-19-2009, 01:44 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
The wax should eventually begin to lift off if you use any of the ideas presented above. I'm still removing wax I've found from my PO of my truck. No telling how long that's been there.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-19-2009, 03:02 PM   #6
cajun chevy
Thanks for the tips guys.
Old 08-20-2009, 08:04 AM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Keep us posted on which step worked the best.
-Nate
Old 08-20-2009, 03:50 PM   #8
cajun chevy
I used pledge and it seemed to work very well. I haven't taken the truck out in the daylight yet but I will keep you posted.
Old 08-20-2009, 04:58 PM   #9
big_al_71
big_al_71's Avatar
Eagle one spray mist and a good microfiber will take it right off...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-22-2009, 08:06 AM   #10
cdowns
cdowns's Avatar
another way is to just put a new coat of wax on/ it will loosen and remove the old as long as you buff it out properly this time
Old 03-09-2010, 02:17 AM   #11
lewisaric
lewisaric's Avatar
How long is too long. I used to wax my entire truck then go back to wipe it off, and it wasnt hard to get off. The only problem I had was getting wax off of the window rubber that I accidently went over.
lewisaric is offline   Reply With Quote
Old 03-09-2010, 09:32 PM   #12
ed2552
ed2552's Avatar
FWIW, if you want to remove wax, use some simple green or dawn dish soap in your bucket along with your car shampoo. But, this leaves the paint bare, so you need to apply a fresh coat to protect the paint. But, if you want to get down to clean paint and work from there, that's the best solution.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
