Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 12-04-2009, 08:17 PM   #1
nutsforchevys
nutsforchevys's Avatar
How do I remove wax from black plastic?
I was waxing my truck the other day and I got wax on the black plastic fender wells. What can I remove it with?
72 Super Cheyenne lwb 4X4 Ocra / White
88 Chevy 1 ton Dumptruck
88 Chevy 1ton Flat bed 4X4 white
nutsforchevys is offline   Reply With Quote
Old 12-04-2009, 08:35 PM   #2
Twisted Elegance
Twisted Elegance's Avatar
Re: How do I remove wax from black plastic?
i have heard that a Mr. Clean magic Eraser takes wax off of plastic body moldings. try it and let us know
Twisted Elegance is offline   Reply With Quote
Old 12-04-2009, 09:56 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Mr. Clean Magic Eraser's are awesome!!! I have used them for several different truck related projects, and they are a hidden gem.
As far as removing wax though... I haven't used them for this process. I'd be interested to know how they work.
IIRC... Mother's has a cleaner/protectant (Back to Black, I think) that will restore the black to faded/waxed black trim.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-04-2009, 10:27 PM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
X2 on the magic erasers .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-05-2009, 02:07 AM   #5
POPO1984
POPO1984's Avatar
peanut butter with a tooth brush
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 12-05-2009, 04:38 PM   #6
nutsforchevys
Thanks for the info. I think my wife has some of the majic erasers. I will try that.
Old 12-05-2009, 10:25 PM   #7
cdowns
cdowns's Avatar
grease andwax remover a commonly sold product in autoparts stores
Old 12-09-2009, 08:04 AM   #8
Restrorob
The One And Only !!!
Restrorob's Avatar
Apply a little Fluid Film on a soft rag and wipe it on, It not only removes wax from black plastic/rubber but makes it look shiny new again.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 12-18-2009, 10:20 AM   #9
Deenice21
Deenice21's Avatar
there is a product called Black Wow that works clean the wax off with soap first then use it
1971 LWB C10 - 5.3/350
1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet
1964 malibu ss - ls1/4l60
http://67-72chevytrucks.com/vboard/s...d.php?t=382403
Deenice21 is offline   Reply With Quote
Old 01-18-2010, 04:36 PM   #10
Beuford
Beuford's Avatar
If you use Armour All or whatever you use on the black trim first then wax your truck you can wipe it off .... no white stuff.
Beuford is offline   Reply With Quote
Old 01-30-2010, 05:12 PM   #11
JOHNNY-CLEAN
JOHNNY-CLEAN's Avatar
A trick I've used in the detail shops for years is get a small nylon detail (paint brush). Take electrical tape and wrap around the bristles so there is only about 1inch of brush hanging out of the bottom so its stiff and flat. Be sure surface is cool and wet with water. Get a mild all-purpose cleaner (409, simple green, ect) and mix 50/50 with water. Spray cleaner on a small area and softly and slowly rub the detail brush back and fourth onto the pours of the plastic. The small tight bristles will work into the wax and agitate it loose. Wipe dry with a clean cloth.
If you don't like Armor-All or dressings. There is a product called "Engine Blackout" made by Clean Cycle Products. That is put on with a sponge detail brush and will make it look new for about 3 months with regular washing. It's usually used for the black engines of Harleys but works well on plastic. You can usually find it at all Harley dealerships or online. About $15.00 a bottle and will last a good year or so.
There is also a product called "Armidillo" used in the CHEVY dealerships for the fading plastics on the Avalanche models. It's a bit expensive but if you sneak back to the detail guys they may hook you up! Bring'em a 12 pack or something.
GOOD LUCK!
JUST CUZ YOU POUR SYRUP ON S*%T DON'T MAKE IT PANCAKES!
JOHNNY-CLEAN is offline   Reply With Quote
Old 01-30-2010, 05:53 PM   #12
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Hand sanitizer...it kicks AZZ on removing tree sap...I have pines in the yard
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-05-2010, 12:55 PM   #13
leddzepp
Moderator
leddzepp's Avatar
Thumbs up Re: How do I remove wax from black plastic?
goo-gone
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 02-05-2010, 03:20 PM   #14
longhorn396
S.D.M.F.
longhorn396's Avatar
Did u know armor all leaves a thin layer of something that u can only clean off with lacquer thinner? I learned that the other day at work. just sayin
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline   Reply With Quote
Old 02-14-2010, 01:09 PM   #15
badriv455
'67 Chevy C-50
badriv455's Avatar
a white rubber pencil eraser the square kind you used to use in school, with some elbow grease takes it off of black trim
badriv455 is offline   Reply With Quote
Old 02-23-2010, 10:14 AM   #16
Houston54
WD-40 on a rag removes dried on buffing compound residue and wax smears on flat black roof rack components, trim moldings, bumper covers, etc. A tooth brush used with WD-40 will get into the creases, cracks and corners.
Houston54 is offline   Reply With Quote
