Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 03-12-2010, 03:57 PM   #1
cheyenne20
cheyenne20's Avatar
Heavy oxidization on alluminum rims....
I went out and got some mothers aluminum polish and a power ball. the first rim I did started to clean up nicely but it takes a long time. I was hoping that with everyone's infinite wisdom that you would have some easy cheap ticks to get it all off with out so much of a fight. Maybe coke?.. if the pictures come out well you will see what im talking about. thanks
cheyenne20 is offline   Reply With Quote
Old 03-12-2010, 05:08 PM   #2
cdowns
cdowns's Avatar
Re: Heavy oxidization on alluminum rims....
i'd start with a brillo soap pad cheap easy to use and does a good job for the first step
Old 03-12-2010, 05:29 PM   #3
cheyenne20
cheyenne20's Avatar
will the brillo pad scuff it uf really bad?
Old 03-12-2010, 06:00 PM   #4
cdowns
cdowns's Avatar
ask your mom she's probally been using them since b4 you were born
Old 03-12-2010, 06:06 PM   #5
my67chevytruck
Under Construction
my67chevytruck's Avatar
use this 1st
http://www.californiacustom.com/alum...eoxidizer.html
then this
http://www.californiacustom.com/purp...al_polish.html
those rims may be clearcoated... which means they would probably have to be stripped to be cleaned up really well...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-12-2010, 07:07 PM   #6
82chevy350
82chevy350's Avatar
steel wool use the real fine stuff it will shine it right up
Drive It Like Ya Stole It
'82 Primer White c10 2wd LWB 350 sbc t350
(Hot Rod)
'90 2wd LWB Silverado 350 tbi 700R4
(Daily Driver)
'53 m38a1 Willys Jeep
(Toy)
82chevy350 is offline   Reply With Quote
Old 03-13-2010, 01:30 AM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
The statement above about the California Custom aluminum deoxidizer is a good one. That stuff works real well. However it has limitations just like many other things. If all fails get a die grinder (electric or air driven) and put a tapered spindle in it and use some small "Razor Buffs" and a set of polishing bricks. I use a black rouge to cut the nasty stuff first, then a green rouge to polish and white rouge to give the metal a final color. A lot of that stuff can be found at the Eastwood website or even go to your local truckstop---they usually sell it to the drivers for their trucks. Sears or harbor freight has small bricks, also.
Razor buffs are a little harder to find but they are out there. Try this outlet for what I am toalking about. http://www.woodworkingshop.com/cgi-b...adItem=FO33906
Get the 4" or smaller ones so that the die grinder works them easy and it lets you get into tight places. Do the owrk with a different buff for each type of rouge. Put very little pressure on the buff as you use it. Try it on your fingernail first---that is as hard as you need to apply it ot the wheel. You can clean four wheels in an afternoon.
Frank
piecesparts is offline   Reply With Quote
Old 05-07-2010, 07:54 PM   #8
Cole Trickle
C-10 Club Member
Cole Trickle's Avatar
This stuff is supposed to work amazing.....
I know alot of guys in the west coast boat community that swear by it.
http://www.metalwax.com/
I am going to order up there starter kit shortly
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels
1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold
Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910
Cole Trickle is offline   Reply With Quote
Old 05-08-2010, 08:29 AM   #9
dauntless_powered
dauntless_powered's Avatar
There is some stuff that I got at my local parts guy that is called "Colonel Brassy" it is some damn amazing stuff that works on all metals. I took an antique Fire Extinguisher that looked horrible and within a couple hours it is in show room quality. Just my .02
Erik
1967 K10 SWB Big Window - Bone Stock
1955 JEEP CJ5 13K orig miles (Resto waiting patiently in the garage)
dauntless_powered is offline   Reply With Quote
Old 06-03-2010, 05:50 PM   #10
Jonboy
Slots go on anything!
I have had good luck with the Meguires "hot wheels" aluminum polish also.
1974 Jimmy- 5.3/4L80e/NP241
Old 06-03-2010, 11:38 PM   #11
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
hit it with eagle 1 etching mag cleaner THEN mothers! worked on my slots pics in thread
John
1999 Toyota Tacoma 4x4
Old 06-05-2010, 03:20 AM   #12
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
I have used a bunch of stuff in my day and the two that said California custom are 100% correct. I have never seen anything that works as well as this product. I use it on my weld wheels.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 06-05-2010, 03:59 PM   #13
Mudder
Mudder's Avatar
California Customs blows Mothers away. When you get your wheels looking nice you don't have to use the oxidizer. I may use it once a year.
Mudder is offline   Reply With Quote
Old 06-13-2010, 02:17 PM   #14
dammitmitchell
the pollock
dammitmitchell's Avatar
the steps are as follows. i have a awrite up in the "how to section" also..
i think ill do one for rims one day step by step.
FIRST
remove rim from truck
and scrub with soap and water, then scrub with a medium brillo pad to remove all the surface dirt and grime. that will be your biggest improvement.
(the DIRT and crap will stay in your mothers ball if you use that first.. and will destroy it)
NOW, if the rims need any touch ups dont use below 400 grit, i recommend a 800 1000 1500 g step up (only if the rims NEED a severe corrosion removal)
if there are creases you can get the filt and dirt out of use a new brass brush soap and water to get in there BRASS BRUSH (steel brushes will marr the rim)
now you can either use your mothers ball or a DA witha cutting or finishing pad with some 3M rubbing compound
buff the whole rim with that this will remove any residual filth and what not the brillos diddnt get.
now the rim is prepped for final polishing, use your mothers aluminum polish and FOLLOW the DIRECTIONS.....
it's a messy dirty dirty process so wear shoes you dont like and dont do it near stuff you want to keep clean
and GOOD LUCK! PM me if you want anything more specific.
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
