Old 03-23-2010, 08:40 PM   #1
addicted2dunes
Insane In The Membrane
addicted2dunes's Avatar
Project: ALTER-K-TION ('57 GMC Quad Cab)
ALTER-K-TION
I think I have collected enough parts to begin this project so here it goes. This project will be based as:
'57 GMC 1.5 Ton Front Clip
Quad Cab
Longbed
Dually
4x4
Cummins Diesel
This will be a slow project as I usually have about three going at once. I picked up an '05 Dodge Ram 3500, dually, diesel, auto, 4x4, quad cab, so this is where it starts. I will be using the firewall, floor board, cab back, 35 gal. fuel tank, and complete rolling frame from this truck. I am starting on the cab grafting and will update as I can.
Pics (nothing exciting, just got rid of the Dodge bed and chopped the roof off the cab):
addicted2dunes is offline   Reply With Quote
Old 03-23-2010, 08:50 PM   #2
winchster
winchster's Avatar
Re: Project: ALTER-K-TION ('57 GMC Qad Cab)
Short bed, short bed, short bed. Just kidding, can't wait to see this thing come to life.
'49 AD 5 window deluxe cab sitting on a '78 K5 chassis
Support our troops, stand behind 'em or get in front of 'em.
What country can preserve its liberties if its rulers are not warned from time to time that their people preserve the spirit of resistance?
winchster is offline   Reply With Quote
Old 03-23-2010, 09:40 PM   #3
blackdiesel
blackdiesel's Avatar
CUMMINS
those common rails are sick nasty. Lots of wiring but make insane power
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-23-2010, 10:09 PM   #4
addicted2dunes
I can't do a shortbed and have dually! Unless I ran the fender flare dually fenders but those are just ugly in my opinion.
Old 03-23-2010, 10:10 PM   #5
addicted2dunes
Originally Posted by blackdiesel View Post
CUMMINS
Still on the hunt for a 97-98.5 12 valve Cummins, hard to come by though.
Old 03-23-2010, 10:14 PM   #6
addicted2dunes
Been drilling spotwelds all night trying to seperate the Dodge panels. Holy cr@p that's hard! All the panels are intertwined and they spotweld about every 1.5".
Old 03-23-2010, 10:33 PM   #7
winchster
winchster's Avatar
I know it's a '57 but this is kinda what I was thinking
Old 03-23-2010, 10:33 PM   #8
winchster
winchster's Avatar
You using one of them fancy spotweld drillers or a regular drill?
Old 03-23-2010, 10:35 PM   #9
addicted2dunes
I've got every spot weld drill bit there is, and the one that I think works the best is from Matco Tools.
Old 03-23-2010, 10:39 PM   #10
winchster
winchster's Avatar
Thanks for the tip. I think this is going to be a sweet sweet ride when you are done.
Old 03-27-2010, 12:07 AM   #11
addicted2dunes
After drilling 6.5 MILLION spotwelds this is how far I've gotten. After weaving panels out from one another I got the back driver's side cleaned up. Remember I will be using the Dodge cab back and floor. After removing the sheet metal mounting plate for the rear seat I made a huge discovery.... Some jackass at the junkyard stuck the forks of the loader through the floor. Anyone got patch panels for an '05 Dodge Ram Quad Cab?
Old 03-27-2010, 03:21 AM   #12
nuke1
nuke1's Avatar
Ouch!!!!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 03-28-2010, 01:33 AM   #13
addicted2dunes
Went and picked up the rear axle for this truck today. Hopefully have the rear rolling again shortly.
Old 03-28-2010, 01:35 AM   #14
addicted2dunes
Here's the Dodge when I originally picked it up:
Old 03-28-2010, 09:40 AM   #15
blackdiesel
I have a question. You may have answered it already, but i havent been able to locate it. I'm sure you have a good reason lol
Why are you using the dodge floor? There isnt any way its the right width. I think it would have been easier to get some flat steel, roll beads into it for strength (floorboard), and fuse two cabs together. JMO though.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 03-28-2010, 10:07 AM   #16
Restrorob
The One And Only !!!
Restrorob's Avatar
My guess would be easier to keep the Dodge floor/hump/firewall and cab mounts than to re-build/form the old Chevy floor/hump/firewall and mounts..... ?
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-28-2010, 11:23 AM   #17
eventytoo
Cool project. Major damage to the dodge before hand. I would question if the frame is still sraight.
eventytoo is offline   Reply With Quote
Old 03-28-2010, 12:29 PM   #18
addicted2dunes
I believe it is easier for me to graft the cab to the Dodge. Believe it or not the floor is the correct width, just modifying it where the GMC steps are. Which I am also changing the step design on the GMC. There were a lot of reasons for using the Dodge floor, firewall, and cab back.
No Rust
Body mount locations are correct.
Trans tunnel is correct for the Cummins
Firewall is correct for the Cummins
I can bolt in the Dodge interior (front & rear seats, carpet, etc.)
Newer floor = Better structure
And I love the challenge
I'm actually amazed at how well it's all fitting together. I cut here, cut there, measure here, measure there. And holy snaps Dodge = GMC
Old 03-28-2010, 03:22 PM   #19
addicted2dunes
The frame is straight (I had it checked) minus the front frame horns that go from front crossmember to the core support. Not that big of an issue, I could have it straightened or most likely I'll chop them off and rebuild the tip of the frame to accommodate the GMC core support.
Old 03-28-2010, 03:23 PM   #20
addicted2dunes
This truck actually looks worse than it is. Most of the damage was caused by the junk yard with the forklift. The truck went through 1 fence and 2 brick walls, well almost, got stuck in the second brick wall.
Old 03-28-2010, 07:54 PM   #21
addicted2dunes
Got the passenger side of the Dodge cab cut up today and started on the lower back section of the '57 GMC. It's getting there, little by little. The cabs are just stuffed together in the picture, I have to trim the Dodge back and alter the cab back bracing on the two cabs. The GMC cab will still drop down about another 6".
Old 03-28-2010, 08:05 PM   #22
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
I like what your plans are with this thing. Should turn out sweet! Subscribed!
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 03-28-2010, 08:13 PM   #23
Restrorob
Restrorob's Avatar
addicted2dunes,
This is quite a undertaking right here and you are moving right along with it, This WILL be a awesome rig when you get-r-done !!!
Just had to buckle up and subscribe for the ride.....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 03-28-2010, 08:32 PM   #24
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Cannot wait to see this thing finished ...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-28-2010, 09:14 PM   #25
winchster
winchster's Avatar
Saw this on the board, thought you'd like it.
