Old 06-19-2010, 05:01 PM   #1
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
New Holley 600cfm carb
New Holley 600cfm carb. Manual choke, mech secondaries. $150 SHIPPED in the lower 48 sold pending payment
Numbers are 4776-7 2182
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 06-19-2010, 05:10 PM   #2
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Re: New Holley 600cfm carb
Could we work out something if I bought both the carb and the intake?
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 06-19-2010, 05:26 PM   #3
usmcchevy
usmcchevy's Avatar
$340 Shipped for both the intake and carb.
Build thread
LSx Swap FAQ index
Old 06-20-2010, 02:51 AM   #4
*Dylan
*Dylan's Avatar
Argh, I'll have to pass. As moving out is more of a priority at the moment. Bump for a good deal.
1967 C10 SWB
Dylan
Old 06-20-2010, 07:58 PM   #5
usmcchevy
usmcchevy's Avatar
TTT still have it!
Build thread
LSx Swap FAQ index
Old 06-21-2010, 05:51 PM   #6
usmcchevy
usmcchevy's Avatar
UP! lower price
Build thread
LSx Swap FAQ index
Old 06-22-2010, 12:08 PM   #7
peleni
peleni's Avatar
Is that a spreadbore?
peleni is offline   Reply With Quote
Old 06-22-2010, 12:40 PM   #8
usmcchevy
usmcchevy's Avatar
Square bore, Adapters are available from summit or pretty much any place though.
Build thread
LSx Swap FAQ index
Old 06-22-2010, 03:27 PM   #9
peleni
peleni's Avatar
Am looking for a 4175 650 cfm manual choke, thanks for the reply though
Old 06-22-2010, 11:03 PM   #10
CCCC
CCCC's Avatar
May be interested but do not know much about this carb or its applications. Please pardon the inquiries - and if this is more than you want to deal with, I understand.
s it a dependable type (free from a lot of tinkering and adjustments) and does the 600 CFM rating make it applicable to standard 350 SB and 402 BB applications (compared to Q-jet of same apps)?
Looks like it requires a fuel line setup that will feed two inlets - correct?
May I assume that the mechanical secondaries are activated my an extended position of the same control rod that operates the primaries, and is this an easy bolt-up fit for the fuel feet rods for engine types noted above?
Does any manual control choke fitting/cable come with it?
Thanks for any info.
CCCC
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 06-22-2010, 11:57 PM   #11
usmcchevy
usmcchevy's Avatar
No problem, I will answer any and all questions to the best of my knowledge. Be fore warned though, some people are very opinionated about their carb choices and applications.
s it a dependable type (free from a lot of tinkering and adjustments) and does the 600 CFM rating make it applicable to standard 350 SB and 402 BB applications (compared to Q-jet of same apps)? It is a Holley mechanical secondary carb, which in my experience is about as dependable as carbs get. In general 600cfm is enough for a warmed over 350 or a mild 402. If you are looking to tow, some like a smaller 2 barrel carb better for more torque. For street driving and strip duty 600 is about right.
Looks like it requires a fuel line setup that will feed two inlets - correct? Yes, you need something like this to hook it up.
http://www.summitracing.com/parts/SUM-G3110/
May I assume that the mechanical secondaries are activated my an extended position of the same control rod that operates the primaries, and is this an easy bolt-up fit for the fuel feet rods for engine types noted above? Yes, the mechanical secondarys start opening about 1/2 throttle and all four barrels are fully open at full throttle. You can use your factory fuel line from your fuel pump or make a new one to go to the part i linked to above.
Does any manual control choke fitting/cable come with it? No, you would need to use your factory one or get another.
Let me know if you have any more questions.
Build thread
LSx Swap FAQ index
Old 06-24-2010, 09:05 PM   #12
usmcchevy
usmcchevy's Avatar
TTT
This thing is $340 from summit!
http://www.summitracing.com/parts/HLY-0-4776C/
Willing to trade for 67-68 hood.
Build thread
LSx Swap FAQ index
Old 08-05-2010, 02:55 PM   #13
usmcchevy
usmcchevy's Avatar
Still have this, offers?
Build thread
LSx Swap FAQ index
Old 08-05-2010, 03:12 PM   #14
ScottH
ScottH's Avatar
$120 shipped?
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 08-05-2010, 06:51 PM   #15
usmcchevy
usmcchevy's Avatar
Originally Posted by ScottH View Post
$120 shipped?
Sure, sending PM with payment info.
Build thread
LSx Swap FAQ index
