Old 08-01-2010, 11:22 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Speedo adapter? Doc's blocks a/c adapter? gauge adapters?
What are you guys with 4l60's and 80's using for speedo adapters? Who was using the Doc's Blocks for the a/c compressor, will it clear the frame with them? I dont know if I want to get new gauges or adapters. Autometer or just use some brass adapters from NAPA?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 08-02-2010, 09:28 AM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Speedo adapter? Doc's blocks a/c adapter? gauge adapters?
Here is one speedo adapter I had bookmarked:
http://www.abbott-tach.com/cablex.htm
I am using the Docs Blocks manifolds on my 85 and they clear the frame easily. Member 68 short step has also used them on several 67-72 swaps as well.
If you want to stick with the stock gauges you can use the speedo adapter, use the stock oil psi sending unit, and for the temp either use an adapter in the pass head or drill and tap it for the stock sender.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-02-2010, 01:20 PM   #3
Ackattack
Ackattack's Avatar
I used docs blocks for my A/C also (corvette accessories) and they clear the frame, though it is a tight fit with the block, AC lines, frame, and header pipe but it will work.
I used an electric programable speedo from Autometer
Ackattack is offline   Reply With Quote
Old 08-04-2010, 10:11 PM   #4
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Are you using the AA2209 and AA2210? I received mine today and they dont look like they will fit my compressor. 01 6.0 LQ4. 2 seperate fittings and only the center bolt to hold them down?
