Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-08-2011, 09:37 PM   #1
Ironhorse
Ironhorse's Avatar
Corner Speaker Install for 67-72 Pickup ?
Anyone have pictures and some tips for installing 6x9 speakers in the cab corner on a 67-72 pickup? I moved the tank to under the bed couple years ago and am now thinking I need to take advantage of the space and install some decent speakers. Don't want to go the sub boxes route, want to have the available space behind the seat for storage so am thinking of mounting speakers in the corner, just not sure what would work best.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 02-09-2011, 03:37 PM   #2
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Re: Corner Speaker Install for 67-72 Pickup ?
I came across this post a while back, and bookmarked it, so I could try to come up with something like it for my daughters truck, and ultimately for my truck.
It might give you some ideas.
http://67-72chevytrucks.com/vboard/s...d.php?t=287987
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 02-09-2011, 05:05 PM   #3
jimmydean
jimmydean's Avatar
I would do it just like that, only out of wood. I am putting a pair of 6.5" mids just above that location, but I am doing a full rack across the back.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-10-2011, 10:58 AM   #4
Ironhorse
Ironhorse's Avatar
chevy_man5, I contacted bigblock73 about those cab corner mounts but as produced they will not fit a 67-72 cab. Gives me an idea about building some of my own using MDF chip board or such. Just looking for other options. Thanks for the reply.
Wellington, Ks
Old 02-10-2011, 11:27 AM   #5
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
No problem Ironhorse.
I was planning on using them as an idea base, for making our own as well, either out of metal or MDF.
I was thinking I would put them in the bottom of the corner, and angle them up, towards the center of the cab for better sound, instead of facing straight out. Then make some kind of filler to go above them to seal off the opening.
We are a ways from that point, but there are SOOOOO many ideas flying around in my head.
Good Luck!! Make sure to post pictures of what you come up with, maybe inspire someone else too!
Jason
Old 03-12-2011, 07:12 PM   #6
bigblock73
yeller
bigblock73's Avatar
I will have 67-72 brackets ready to go by spring, if you guys are still interested. I can make them with 6x9 cutouts, or leave them blank so the owner can cut for whatever size he or she wishes.
bigblock73 is offline   Reply With Quote
Old 03-12-2011, 07:49 PM   #7
Jparks
Jparks's Avatar
subscribed, like to see those for the 67-72
72 SWB - Porterbuilt Front/Rear, 22's, 496bbc - "Outkast"
68 Stepside - Porterbuilt Coilover Chassis, 22's, LS3 - "Badfinger"
Jparks is offline   Reply With Quote
Old 03-14-2011, 05:58 PM   #8
Ironhorse
Ironhorse's Avatar
Jeff, I would be interested in your 67-72 corner brackets. Do you plan on making them to mount at the upper or lower portion of the corner opening? I moved my in-the-cab tank a couple years ago to under the bed and think that along with a good pair of speakers mounted to the factory front speaker area would be a good set up. Keep us posted on your progress.
Wellington, Ks
Old 03-18-2011, 02:55 PM   #9
Lemield
Lemield's Avatar
Subscribed. Might be interested as well.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 03-19-2011, 12:51 AM   #10
bigblock73
yeller
bigblock73's Avatar
They will run from the floor up to about were the door latch assembly is bolted to the cab...so they will be taller than the 73-87 style. They need to run to the floor for mounting purposes...not many places to bolt them to on the 67-72's. They will clean up the corner of the cab nicely...and the speaker itself will be up towards the top.
Old 03-20-2011, 06:54 AM   #11
Ironhorse
Ironhorse's Avatar
Will be looking forward to seeing them when you get them built. Sounds good.
Wellington, Ks
Old 03-21-2011, 10:28 AM   #12
raider65
raider65's Avatar
I will be interested in them! fo sho!
It's not rust...It's character!
raider65 is offline   Reply With Quote
Old 03-23-2011, 12:54 AM   #13
Spoof
Spoof's Avatar
me too
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 03-28-2011, 08:04 AM   #14
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Subscribed as well for the 67-72's
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 04-09-2011, 04:34 PM   #15
gringoloco
A guy with a truck
gringoloco's Avatar
In. Any Progress? It's spring
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is online now   Reply With Quote
Old 04-10-2011, 11:06 PM   #16
bigblock73
yeller
bigblock73's Avatar
Yes and no, sold a spare cab I had in the shop, now I have room for the 67-72 cab. I should have it moved in this week so I can finish up the design work, then I'll get it in CAD, cut, bent and mocked up.
Old 04-17-2011, 10:47 PM   #17
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
subscribed, sounds cool
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 04-18-2011, 01:48 AM   #18
C10CORIE
C10CORIE's Avatar
C10CORIE is offline   Reply With Quote
Old 04-27-2011, 08:39 AM   #19
Ironhorse
Ironhorse's Avatar
Just checking in for a progress report.
Wellington, Ks
Old 05-02-2011, 11:04 AM   #20
wildrib
I like those corner brackets.I used rod doors back panel cover covered it in vinyl and cut out speaker holes.
wildrib is offline   Reply With Quote
Old 05-05-2011, 12:50 PM   #21
bigblock73
yeller
bigblock73's Avatar
Sorry guys, been tied up with a house project...please be patient, I will get them done soon, I promise.
Old 05-06-2011, 10:15 AM   #22
greystoke
Interested and subscribed
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 06-06-2011, 01:24 PM   #23
POPO1984
POPO1984's Avatar
Interested
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 06-11-2011, 06:37 PM   #24
blkcorvair
blkcorvair's Avatar
suscribed
blkcorvair is offline   Reply With Quote
Old 06-23-2011, 03:37 AM   #25
brak
brak's Avatar
subscribed
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
