Old 03-29-2011, 09:22 AM   #1
es67chevy
es67chevy's Avatar
Starter turns when shifting from Park
Need some help to determine what is going on with the starter and my wiring. I have a brand new painless 18 circuit kit installed. I don't have the truck running yet, but I have it hooked up to starter, etc. When I turn the key to the 'on' position, I'm able to test lights, blinkers, air, etc without the truck actually running. However, when I shift the truck from park through reverse and neutral, it activates the starter briefly (auto on the column - van tilt column). I have a new neutral safety switch but suspect it may be the problem. I'm having a hard time figuring out how just moving the gear shift lever through the range of the neutral safety switch would activate the starter, but I'm definitely not a wiring expert. Currently, the column is not hooked up to the transmission. The rod is disconnected that goes to the trans. So its definitely related to something on or around the column. Anyone have any experience with a similar issue or have any thoughts to why power would be sent to the starter just by moving the shift lever through its range of motion? BTW, I did confirm I can turn the key all the way to start and it works as expected. If the column is down in drive position, the starter will not turn. If up in park, it will turn the motor over. Let me know if you need any additional details as well. Not sure what is relevant to my situation. Thanks!!!
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 03-29-2011, 10:23 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Starter turns when shifting from Park
Sounds like you might have a wrong wire to the starting circuit. I guess the first thing I would do is to unplug the connector to the neutral safety switch and see what it does. I wouldn't necessarily blame the switch, I think it's a wiring issue.
LockDoc
Leon
Old 03-29-2011, 03:46 PM   #3
Wrenchbender Ret
If the backup light is hooked up its possible it is feeding to the starter circuit through a defective neutral switch.
Wrenchbender Ret is offline   Reply With Quote
Old 03-29-2011, 04:06 PM   #4
es67chevy
es67chevy's Avatar
Very interesting. I unplugged one of the backup light connections to the safety switch and now it doesn't try to turn over the starter. Plug it back in and then it tries to start the truck shifting past reverse. Argh. Brand new safety switch too. Guess I need to try another one?
Thanks for the tip, Wrenchbender Ret!
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 03-29-2011, 08:56 PM   #5
BOZO
Old School
BOZO's Avatar
I'm glad I read this thread, as my truck has been known to occasionally do this very same thing. Sometimes when I would put my running truck up into park, you would hear the starter momentarily engage as the selector moved past reverse. I can understand how a faulty neutral safety switch would cause this problem.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
Old 03-29-2011, 11:36 PM   #6
es67chevy
es67chevy's Avatar
Awesome. Glad you were able to learn something from this one too. No sense in reinventing the wheel! That's why I usually ask before getting too flustered over things like this. Gonna pick up another neutral safety switch over the next couple of days and see if that fixes the issue.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
neutral safety switch, starter
