Old 04-17-2011, 01:56 PM   #1
taank
Door pins and bushings
Are they serviceable seperate from the hinges ? Or do I need new hinges? What about the door checks?
taank is offline   Reply With Quote
Old 04-17-2011, 02:13 PM   #2
67swb72klb
67swb72klb's Avatar
Re: Door pins and bushings
i dont know if anybody makes a kit a lot of people say the repops are not too good maybe somebody will chime in
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 04-17-2011, 02:51 PM   #3
Fldawg
Fldawg's Avatar
you can change the pins and bushings in them any parts store has them
Fldawg is offline   Reply With Quote
Old 04-17-2011, 04:14 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Im pretty sure the last set I got was from shucks in the help section..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-17-2011, 04:24 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
You can replace bushings and pins with the hinges on the truck. Much easier. I heated the hinges a little with a propane torch and tapped out the pins with an air hammer. Supported the door with some jack stands.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-17-2011, 09:26 PM   #6
mbgmike
Its just a bolt and a bushing. they all can be fixed. no offense but hinges are easy to fix. they make all kinds of bushings stock and oversized and pins to fit. or any shop can fab pins. give the size of your opening and we can fit the bushing for an off the shelf pin.
mbgmike is offline   Reply With Quote
Old 04-17-2011, 09:41 PM   #7
Sammy
Auto zone and most parts stores have the pins n bushings. The friction door checks are a different story. No parts for those. A few have tried making something that worked. I have no idea if they were successful.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-18-2011, 05:30 PM   #8
mbgmike
You can get the door hinges with the check built in but not seperate for around 30 dollars each
apedrape, bushings, door, hinge, sagging
