Old 04-18-2011, 11:01 AM   #1
es67chevy
es67chevy's Avatar
Metallic-Sounding Drag In Tilt Steering Column When Turning Wheel
I just noticed that there is a slight drag in my steering wheel when I turn it. I don't have to be driving to notice this. In fact, I probably wouldn't notice it with the truck running. I'm wondering if this is a sign of a bearing problem. If so or potentially so, is my only option to disassemble column and lube or replace bearings? Or can I just ignore it and go on? It's hard to describe, but seems to be metallic in nature. Just a little resistance when rocking steering wheel left or right, even before the point of actually turning the wheels.
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 04-19-2011, 09:24 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Metallic-Sounding Drag In Tilt Steering Column When Turning Wheel
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-19-2011, 10:00 AM   #3
DT1
DT1's Avatar
I have the same thing happening with mine. It's not a tilt but it sounds like the bearing. I replaced my bearing and it didn't solve the problem.
DT1 is offline   Reply With Quote
Old 04-19-2011, 10:15 PM   #4
es67chevy
es67chevy's Avatar
Bummer. Anyone else have any ideas? Especially those that have rebuilt columns
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 04-19-2011, 11:00 PM   #5
1972RedNeck
1972RedNeck's Avatar
It could be the horn contacts rubbing. My truck made that noise also so I took it apart and put dielectric grease on the contacts. It fixed it for about 3 months and then it made the noise again.
1972RedNeck is offline   Reply With Quote
Old 04-19-2011, 11:09 PM   #6
es67chevy
es67chevy's Avatar
Ah, I appreciate the tip. I'll try that before removing the bearing assembly. I just replaced the turn signal switch too. I hope that is it! Specifically, where did you need to add the grease? I'm still trying to figure out what makes the horn work.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 04-20-2011, 12:42 AM   #7
onebadbowtie
onebadbowtie's Avatar
my steering column has this too. mine is dragging where the black after market steering wheel adapter cover from grant meets the original steering column. if your running an after market grant steering wheel and adapter i bet that is what it is.
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 04-20-2011, 04:14 PM   #8
es67chevy
es67chevy's Avatar
Thanks, James. I just went out and checked this along with horn switch. I removed the turn signal switch and the column sleeve covering the bearing so no interference. I have definitely narrowed it down to the bearing itself. Now if I could just figure out how to get those two pins out to remove the bearing assembly.
One board member mentioned using a socket and screw, but I haven't figured out how to execute that successfully. And someone else mentioned a special tool (something like a slide hammer), but I haven't found that tool yet either. Just not sure what to search for.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
bearing, tilt column
