Old 09-09-2011, 07:36 PM   #1
crispo-71
bag tip bag help????
70 c10 short step side.. all stock, c notch at rear, plate and 2 in cup for lower arm in front.. what is the best air bag 2 get. what do you recomend ive never had bags before..
crispo-71 is offline   Reply With Quote
Old 09-09-2011, 08:00 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: bag tip bag help????
Slam Specialties.
SS-7's up front.
SS-6's or SS-7's in the rear.
http://www.slamspecialties.com/home.html.
Many board vendors sell them.
Contact Nathan Porter (aka Porterbulit) on here.
He will take care of you.
Keith
Convert to disc brakes.
Old 09-09-2011, 08:13 PM   #3
crispo-71
Slam Specialties.
SS-7's up front.
ok thanx and question.. why is it some people do ss-7s in front and 6s in rear???
Old 09-09-2011, 08:39 PM   #4
SCOTI
SCOTI's Avatar
The 6's will require slightly more air pressure to achieve similar heights compared to a 7.
If you achieved your desired ride height @ 25psi using the 7" bag, it might not have enough air pressure to support the weight &/or offer the best ride (the ride might be 'bouncy'). Swap the 6" bag in place, it will require more air psi to achieve that same desired ride height (lets say 35psi). Now you have the same overall ride height, but w/slightly greater air pressure in the bag, the ride is improved & smooth because the greater air pressure increases the 'spring rate'.
This can also work in the opposite direction.... if there's too harsh of a ride using the 6" bag because you have to utilize greater operating pressures, the 7" bag could achieve the same height while using less pressure.
Another possibility is the amount of space available.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-09-2011, 08:41 PM   #5
lolife99
lolife99's Avatar
SS-7's up front to handle the weight of the engine.
Some like a smaller bag in the rear since there isn't much weight there.
(for a better ride)
I have the old version,... RE-7's on all four corners of my blazer.
EDIT: I type to slow.
Plus SCOTI explaiined it much better than me.
Keith
Old 09-09-2011, 10:39 PM   #6
crispo-71
ok ok i get it now.. thanx guys.. what those that bag run for.. about 150?
Old 09-09-2011, 10:56 PM   #7
lolife99
lolife99's Avatar
Usually about $75 each.
Keith
Old 09-10-2011, 09:59 AM   #8
crispo-71
whats the diff between RE and SS bags??
Old 09-10-2011, 01:11 PM   #9
lolife99
lolife99's Avatar
Supposedly the SS version has about 1" more lift.
They are cheaper also.
Keith
Old 09-10-2011, 01:23 PM   #10
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
are dominator bags good stuff?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-10-2011, 01:32 PM   #11
lolife99
lolife99's Avatar
Member tcb-1, confirmed they ballooned more than the Slams,... on his '60 Cadillac.
This created a rubbing issue.
He sold them and bought Slams.
If you have a ton of room around the bag they will be fine.
(the quality of the Air Lift bag is fine also)
With bumpstop brackets and sway bars, mounted to the a-arm, on these old trucks,... I'd rather use the Slam Specialties bag.
Keith
Old 09-10-2011, 02:15 PM   #12
Clyde65
Clyde65's Avatar
OK, would a rear sway bar be needed with bags?
Clyde65
Rebuild of Clyde
support our troops!
Old 09-10-2011, 02:21 PM   #13
lolife99
lolife99's Avatar
I don't think it's neccessary.
I don't have one on my blazer.
But you need to have seperate air lines to control each bag individually.
(don't "T" them together)
This will cause air to transfer between the bags as you go around corners.
(creating more body roll)
Keith
