09-14-2011, 10:23 AM | #1 |
2001 burb oil leak. help!
Hey fellas,
Never posted on this side before, im usually on the 55-59 or 73-87 areas. Got a question about my wifes 01 burb,(5.3) this sucker has been leaking oil for about 6mths. It leaks out the rear of the block. Im thinkin maybe a sensor back there somewhere? I used the search on the board but nothing useful comes up. Help! Im just a dumb ol 1st gen small block guy im thinking if i gotta pay to get this engine pulled to replace gaskets its gonna be $$$$. Posted via Mobile Device Posted via Mobile Device |
09-14-2011, 10:34 AM | #2 |
Has more rust than truck...
Re: 2001 burb oil leak. help!
Oil Press sensor is located directly behind the intake at the back of the motor. Right next to it is the cam sensor. It could be one of those, but if it isnt it could be valve covers, rear main seal, oil pan or there is a block off cover directly above the oil filter I have seen leak.
09-14-2011, 01:26 PM | #3 | |
Seems to be coming from the passenger side near the top. Probably the sensors. Guess im looking at ana engine pull for a 100$ part btw i see your in biloxi. Im from destin. Left 13 yrs ago. Miss the biloxi-n.o. Cajun coast. Particularly the drive thru crawfish joints Posted via Mobile Device |
09-14-2011, 03:54 PM | #4 |
you shouldn;t have to pull the engine for that sensor
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
09-14-2011, 11:21 PM | #5 |
You know, my Mom's Suburban is doing the same. Loses about a quart maybe between oil changes an its been babied all of its life. The one thing I've seen is that the 2001 trucks seem to have an oil leak than most other newer years for some reason. IDK? I've thought it was the main seal but I prolly should check those sensors again just to make sure maybe. Its also a 2001.
BTW to the OP: Saw in a earlier post of yours that your from gulf states, i'm from Mississippi actually too. |
09-14-2011, 11:33 PM | #6 | |
09-15-2011, 06:44 AM | #7 |
If its not the sensor there is a rear main cap that is prone to leaking
07-17-2013, 09:23 PM | #8 |
laying low
Bump up to the top. I'm curious what the fix was.
My 2000 GMC is leaking out the rear right now. I suspected the oil pressure switch and replaced it but it was not the cause of the leak. And had to buy a special socket to install it. I've not heard before the cam position sensor could cause the leak. It's real tight back there.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
07-17-2013, 09:50 PM | #9 |
First off, on a Torsion Bar Truck/SUV....Never pull a Gen III engine to fix oil leaks. The Oil pan comes right off, Transmissions come out easier if need a rear seal or rear cover seal.
Remove the intake if Oil pressure switch or Cam sensor need changed. |
