Old 11-14-2011, 05:06 PM   #1
northerngmc
northerngmc's Avatar
Noise when slowing down in 4WD
Winter has arrived and I had my truck in 4WD high. I noticed a noise when I let of the accelerator pedal. I put the truck into 2WD and the noise disappeared.
Any suggestions or where to start looking?
My plan is to check the transfer case and front diff fluid.
I did a quick check on the front shafts going out to the wheel and when I gave them a good shake both seemed fine.
Would front wheel bearings only be in use during 4WD?
Truck in a 2004 2500HD lly with 170 000 kms.
I have changed fluid in both the transfer case and front diff in the past 12 months.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 11-15-2011, 03:44 PM   #2
biggsteve97
Re: Noise when slowing down in 4WD
Where you on dry pavement when this happened? What kind of a noise? A bang, clunk, rattle, or a grinding type noise. The wheel bearings are in use at all times no matter what. Id start by checking the t-case fluid level if it is a grinding noise. If it is a bang or a clunk Id check the front driveshaft u-joints since it seems to only happen in 4hI. What type of fluid did you put in the t-case when you changed the fluid?
biggsteve97 is offline   Reply With Quote
Old 11-15-2011, 04:19 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Prabably not your problem, but everytime someone mentions a T case problem in a 2500-3500 I think of this:
http://www.thedieselpage.com/reviews/tcase.htm
I would check the front diff, front drive shaft U joints and T case. CV shafts will start popping if bad and wheel bearings are in use all of the time, most noticable going around a slight curve at slower speeds.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 11-15-2011, 06:29 PM   #4
northerngmc
The roads up here are now covered with snow, so I was on a snow covered road in 4WD when I first noticed the noticed the noise. I had sped up to 50 km/h and then let off to make a turn. While still going straight forward the truck made a constant noise that was a rattle/grinding noise. The noise goes away if I get back on the power. And the noise does not happen at all in 2WD.
I used GM Transfer case fluid, not the auto trac fluid, but the blue transfer case fluid.
Blaine
Old 11-21-2011, 04:11 PM   #5
northerngmc
Well crawled under the truck this weekend.
First a correction to above, I am using GM manual transmission/transfer case fluid in my transfer case which is red.
It appear that I do have the dreaded 'pump rub' happening and I have ordered a new back half to the case and the update kit from Merchant Automotive.
Blaine
