Old 11-21-2011, 05:06 PM   #1
big_al_71
big_al_71's Avatar
Wheel/tire picture thread
I saw a similar thread on another forum and I thought I should post it on here for everyone to share. There are alot of threads asking about backspacing, tire size etc, so this is a chance to share what you have as well as inform others
things you need to post if you can:
    • wheel size front/rear
    • - tire size front/rear
    • - make/model of tire
    • - make/model of wheel
    • - backspace
    • - picture of the truck/blazer/suburban open to all years
Go ahead and post what you have.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 11-21-2011, 05:06 PM   #2
big_al_71
big_al_71's Avatar
Re: Wheel/tire picture thread
Reserved for when I get my new wheels......in the next few weeks...
Old 11-21-2011, 05:09 PM   #3
big_al_71
big_al_71's Avatar
My old wheels
18x8 f 20x10 rear
255.50.18 front 295.45.20 rear
continental contact
coys c5
- backspace
5.25 front and 5.5 rear
Old 11-21-2011, 05:26 PM   #4
JWall
Frequent Flyer
JWall's Avatar
20” Billet Specialties Roulette Wheels with BFG G-Force T/A Tires
20x8.5 with 4 3/4" BS front with 265/50/20s
20x10 with 5" BS in rear with 295/45/20s
- Justin
1 Owner 1976 SWB
Old 11-21-2011, 07:27 PM   #5
Sicklajoie
The Niner
Sicklajoie's Avatar
Wheels -
F*rd steel wheels 16 X 7 all the way around. 4.5" backspacing.
Tires -
Michelin LTX M/S2 265/75/16 all the way around.
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 11-21-2011, 11:46 PM   #6
Indyuke
^^^ I have to ask, Sicklajoie, do you still have the six lug setup on your truck? And out of what ford did you get those wheels? I like the look.
Indyuke is offline   Reply With Quote
Old 11-22-2011, 03:33 AM   #7
bajaracing
bajaracing's Avatar
I just picked up some rallys and tires, and thanks to this forum found alot of usefull info. Even with all the measurments, I was still unsure I was picking the right tires.
Fronts 15x8 stock BS on BFG 245/60/15, Rears 15x10 5.25 BS on BFG 275/60/15
72 C/10, stock rearend width. Tires: Paid 110ea for rears, and 103ea fronts..
I'll be taking these home tomorrow to see how they fit/look.
Waiting on new shoes, sanding flames off, new solid matt finish coming soon..
One side is about .25 closer to edge, than other side..
bajaracing is offline   Reply With Quote
Old 11-22-2011, 07:05 AM   #8
Sicklajoie
The Niner
Sicklajoie's Avatar
Thanks.
It's a C/20 so it's an 8 lugger.
By 16 X 7 wheels I meant they're 7 inches wide.
The F*rd wheels are from pretty much any 3/4 ton pickup or van up until the late 90's.
Old 11-22-2011, 07:36 AM   #9
68Stepbed
68Stepbed's Avatar
Al I think it would also be a good idea to state what drop and suspension mods have been done.
Here's what I have.
68 Stepside. 3.5/5 drop 15x8 (3.75"bs) on all four corners. Tires: BFGoodrich T/A Radials 275/60/15 rear, 255/60/15 steer
Same 3.5/5 drop but with 17x9.5(5.5"bs and 7/16" spacers) 275/55/17 rear, 17x8(4"bs) 255/50/17 front. Tires are Hankook Ventus ST RH06
Same wheel/tire combo as above but with 3/4" drop block in rear for 3.5/5.75 drop.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-22-2011, 10:20 AM   #10
gcburdic
Restoration Virgin!
gcburdic's Avatar
I have a CPP Grand Slam 2"/4"....these are 6 lug rally's...15x8 fronts (235/60/15) 15x10 rears (275/60/15) Uniroyal Tiger Paw's
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 11-22-2011, 02:09 PM   #11
72Bob
72Bob's Avatar
Stock 6 Lug Rallys 275/60/15
Stock 1969 C10 with 8" Rallye's 275/60/15 BFG Radial Drag TA's Front / Rear.
If I did again, would go a size or two smaller on the front.
1971 GMC Sierra 3/4 Ton 4x4
1972 Chevrolet SWB 4x4
RIP LeRoy
72Bob is offline   Reply With Quote
Old 11-22-2011, 09:12 PM   #12
CC69Rat
CC69Rat's Avatar
Truck is a 69, 68 clip. 84 front suspension swap. 2.5" McGaughys drop spindles and one turn cut from the stock small block springs. (could change soon, PO cut the springs)
I had the engine in my truck this spring and had a problem. It had to come back out. The pics you see with the new wheels are more current, the pics with truck rallys are to show how much the big block will bring the front end down once I get it back in. The tires on the rallyes are 215/65 I think, ..
4.5" drop in the front with 1.25 HD rotors. (I gained about .5 in track width) .. and a big block with iron heads.
6" drop springs in the back, no wood in the bed, not much gas in it, bumper, or driver's step fender on it. It may come down another 2" when I get my notch in place. .. or bags..
The wheels are Billet Specialties Dagger.
F 20x8.5 5.5" BS 255/40/20 Nitto 420s
R 20x8.5 4.75" BS 255/45/20 Nitto 420s
I have the earlier rear end housing. 55.5" plate to plate.
These wheels were measured 316,543 times with a Percy's wheelrite. I'm confident I can tell you .. you can't get much more than this under a stepper without cutting something somewhere. I have heard 22x9 with 5" BS will work with minor trimming. I just offset mine to keep from having to cut my fenders. My tires will tuck completely into the wheel wells, no rubbing with about 3/8" clearance on either side in the back.
You just can't get as much tire under a stepper !! I know, people have more under theirs .. I just didn't want to cut anything.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 11-22-2011, 10:03 PM   #13
Mayo
Cool Truck
Mayo's Avatar
16x8 all the way around
Michelin LTX M/S2
ION Alloy 171
- backspace
4.25
Love your set up Sicklajoie, I might have to get some of them rims, paint them black, and get a set of caps to use in the winter.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 11-22-2011, 10:14 PM   #14
Southcity
Southcity's Avatar
- wheel size front/rear:
Front = Stockers - 15x6.5
Rear = Custom made - 15x8
Front = 225x75
Rear = 255x70
Make = Khumo
Model = Road Venture
Front = Stock
Rear = Wheel Vintiques 15x8
- backspace
Front = Stock
Rear = 4 1/2 inch backspace
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 11-22-2011, 11:39 PM   #15
bajaracing
bajaracing's Avatar
Next, sanding flames off, new solid matt finish..
Old 11-22-2011, 11:49 PM   #16
Boog
laying low
Boog's Avatar
That's lookin goooood.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
backspace, backspacing, tires, wheels
