Old 12-25-2011, 04:08 PM   #1
gotchamel
VDO cluster
Here is the VDO gauge cluster I put together.I went from a 3 hole dummy light to this.I used Cole Hearse green lights for turn indicators and a blue led for high beams.It is wired to a 12 pin male/female quick disconnect{painless}for ease of removal.I used the factory wires but cut the factory plug then color matched the wiring.
gotchamel is offline   Reply With Quote
Old 12-25-2011, 04:13 PM   #2
gotchamel
Re: VDO cluster
And the 12 pin connector.If anyone is interested in doing something like this but is intimidated by wiring{I am/was}it was quite simple thanks to some good advise and the search buttom on this forum.
Old 12-25-2011, 04:30 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: VDO cluster
Suh-weet! Nicely done!
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-25-2011, 04:39 PM   #4
shawno72
C/10 junkie
shawno72's Avatar
Re: VDO cluster
I have always liked the VDO gauges since the days of owning volkswagens. What is the chrome ring lookin things around all the gauges? Looks great.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-25-2011, 04:44 PM   #5
Mac Arnold
Mac Arnold's Avatar
Re: VDO cluster
That looks very nicely done. I would really like to work on mine, which was originally a three hole as well, but was later cut into to add the bottom 4 gauges, unfortunately it wasnt done very nicely. So I will have to decide to go brand new, or just fix it the way I want it.
Mac Arnold is offline   Reply With Quote
Old 12-25-2011, 05:04 PM   #6
gotchamel
Re: VDO cluster
They are a real quality gauge/sender if you like electrical.I have used them in the marine industry for 20+ years in a much harsher enviourment than the dash of a truck.
The chrome is the bezel itself,there is a small chrome{plastic}trim ring around each hole.
Old 12-25-2011, 07:38 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: VDO cluster
Very nice those guages seem to fit the dash bezel really well.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-25-2011, 09:37 PM   #8
gotchamel
Re: VDO cluster
The 2 1/16"fit perfect,the 4"were alittle small so I had to reduce the bezel holes by a 1/2" with a piece of 1/4" pvc epoxyed to the back then drilled 2 4" holes.
Old 12-26-2011, 12:53 PM   #9
72gmcshorty
72gmcshorty's Avatar
Re: VDO cluster
i'm guessing the vdo gauges are cheaper than the autometers? Where do you find VDO's anyways. I also know them from my old VW's
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 12-26-2011, 01:18 PM   #10
FRENCHBLUE72
PROJECT 7DEUCE
Re: VDO cluster
You can get vdo at summit or jegs...
MEMBER #6377
Project "7DEUCE"
Old 12-26-2011, 06:27 PM   #11
gotchamel
Re: VDO cluster
These came from Summit.They are a real quality gauge/sender.Not sure how they compare to others in price.They dont use a bracket system for mounting,there is a large plastic ring{like a nut}that threads onto the whole gauge housing.Its all I have used for awhile now and not sure how everything else is mounted.The speedometer is pretty slick the way its calabrated,you just hit a reset button go a true measured mile,hit the button again and you are calabrated{checked with gps,its right on}.
