Old 01-02-2012, 02:48 PM   #1
burbluv
burbluv's Avatar
What are these holes in my Suburban door for?
Can anyone help me figure what these extra holes are for? Going to remove these monster side mirrors and going with originals that I just got but I am also getting ready to get started on the body soon and wondering if I should be covering these up.
Notice that it is only on the driver side.
Any ideas?
Thanks,
AJ
burbluv is offline   Reply With Quote
Old 01-02-2012, 02:53 PM   #2
joedoh
joedoh's Avatar
Re: What are these holes in my Suburban door for?
I think thats so you can be in the cab and still look outside, they I believe are called "windows" :P
just kidding. the three screw holes on the drives door are for the factory mirrors. I have a brand new set of stainless rectangular ones from LMC that I will be using. my passenger side doesnt have the mounting holes though, I will have to drill.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=47
I wish they were the round ones but they came free with a parts truck so beggars cant be choosers.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 01-02-2012, 02:59 PM   #3
burbluv
burbluv's Avatar
So you are saying the mirrors I have now were drilled after and the original is further up on the door. Meaning my new mirrors should go in the 3 screw holes which I need to match and drill on the other side and then fill the holes left from the ones I will be removing right?
Old 01-02-2012, 04:34 PM   #4
krazy_texan
krazy_texan's Avatar
yup yup thats what he is saying alot of trucks especially lower optioned trucks only came with one mirror.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-02-2012, 04:36 PM   #5
joedoh
joedoh's Avatar
yeah, if you look at the link I posted you will see the mirror mounts match that pattern on your door.
I would only change the mirrors if you care about originality, the ones you have look like they have good visibility. you can look around at some of the trucks on here to see what the stock ones look like.
Old 01-02-2012, 04:38 PM   #6
rbar
rbar's Avatar
Yep, your current mirrors are in the "wrong spot" and the other three are factory. Mine doesn't have any mirror mounting spots on the passenger side either. I am thinking about using nutserts for that instead of trying to put nuts on the back side. They work really well and were a great fix for my cowl vent holes where you can't get to the backside. We use them at work all of the time. The flange is really thin and they hold strong. You do have to have the install tool with it.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 01-02-2012, 06:08 PM   #7
derail
derail's Avatar
That's the exact same thing I used on my passenger door and it worked awesome! If you can look inside of the door, I think most of the passenger doors have the backing plate already in the correct position with holes pre-drilled.
derail is offline   Reply With Quote
Old 01-02-2012, 09:12 PM   #8
'63GENIII
'63GENIII's Avatar
All the ones that I have looked at had the plate predrilled on the inside of the door skin. I like the nut sert idea. I used regular nuts and screws and it was a pain!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-02-2012, 10:02 PM   #9
MusicMan70
MusicMan70's Avatar
I changed out the West Coast Style to go stock.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 01-03-2012, 01:08 PM   #10
RoyL
RoyL's Avatar
Is there enough room in there (inside the door) to mark or drill a small pilot hole to get them in the correct factory location?
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 01-03-2012, 05:02 PM   #11
rbar
rbar's Avatar
I have a 63 door that has nothing behind the outside sheet metal where the mirror mounts and I have two 64 and up doors that have a piece of sheet metal spaced about 3/8" of an inch away from the door. On those three doors I am confident I could drill the holes to put the nutserts in and have them work well, all being done from the outside, which is the beauty of the nutserts.
1965 Chevy swb 383
Old 01-03-2012, 05:18 PM   #12
oem4me
I couldn't tell you if there is room enough to mark the hole locations from the inside without looking, but it would be simple enough to make a paper template from the drivers side exterior, and then use it inside-out to mark the passenger side. That should get you pretty close.
Old 01-03-2012, 06:03 PM   #13
MusicMan70
MusicMan70's Avatar
I did what oem4me suggested, and that worked for me. Make that template and flip it over for the other side.
MusicMan70
1961 GMC Suburban
Old 01-03-2012, 08:05 PM   #14
derail
derail's Avatar
I don't think so. It might be possible with a right angle drill, but I doubt it. I did the same thing that the other guys did and just made a template from the drivers side.
Old 01-03-2012, 08:28 PM   #15
Ledslinger
I know that if you have no mirror or filler screws in these holes, the bottom of the door will rust out directly below.
Ledslinger is offline   Reply With Quote
Old 01-15-2012, 01:51 PM   #16
dugvera@gmail.com
dugvera@gmail.com's Avatar
Doug
66 4x4 GMC Suburban
76 4x4 Chevy Shortbed
dugvera@gmail.com is offline   Reply With Quote
Old 04-16-2012, 10:12 PM   #17
RoyL
RoyL's Avatar
Went to Fastenal, they had 5/16" and 3/8" sizes of the "nutserts" but the $100+ for the tool was a deal killer. I asked if they had anything else that might work. They have these, Auveco PN 12995, 1/4 by 20 thread size. They are called Jack Nuts, says for mirror mounting. I'm gonna try them. Only thing I don't like about any of these type, is the size of the hole you gotta drill in the sheet metal . . . about 7/16" or so.
1965 Suburban
Old 04-16-2012, 10:43 PM   #18
padresag
I believe that on 60-63 that on the passenger side the mirror mounts farther forward and the angle of the base of the mirror is diff from 64-66. there was a session on this just in the last little while. it has to be mounted forward , otherwise the w/s post is in the way
ron
padresag is offline   Reply With Quote
Old 04-20-2012, 07:10 PM   #19
dthela
dthela's Avatar
I have 2 new polished stainless mirrors if interested pm me. (no brkts though)
dthela is offline   Reply With Quote
Old 04-21-2012, 06:34 AM   #20
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Old 09-05-2013, 06:52 AM   #21
RoyL
RoyL's Avatar
Finally getting around to doing this... My driver's side door mirror mounting holes have been bondo'd over and still trying to see if I can get in from the inside to drill out the bondo in the nut and thru the bondo on the door >> "carefully" without making a big mess to repair/paint. Maybe a Dremel with a flexible extension piece might fit in there. If I knew exactly where to drill from the outside, I would, but can't tell where the holes are.
Roy
1965 Suburban
Old 09-05-2013, 07:40 AM   #22
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
ask for someone with a door without the mirrors and do what OEM4Me said, use a template.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-05-2013, 10:25 AM   #23
bmur66
You don't need that $100 tool. This is all you need. Works fine on the aluminum rivet nuts. The steel ones are probably much harder to expand but I don't think you would want to use them anyways. http://www.rivetsonline.com/to-aa184.html
No Weak Links
bmur66 is offline   Reply With Quote
Old 09-05-2013, 09:53 PM   #24
Trsmotrhed
Trsmotrhed's Avatar
This is what's behind the door skin to mount the mirrors.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 09-07-2013, 09:44 AM   #25
RoyL
RoyL's Avatar
Good idea, I forget I know a couple folks with 64-66 trucks ...
I was able to get the passenger side done, I used a spring loaded center punch from the inside to locate the center of the backing plate holes (2 of them) and drilled from the outside.
On the driver's side, that wouldn't work, couldn't get enough access thru the nutplates... Thanks.
1965 Suburban
1962, 4x4, burbluv, chevrolet, suburban
