03-19-2012, 09:45 PM | #1 |
Will these fit?
I found a sweet deal on a set of 15x8 6 lug steelies. I was wondering if they will fit my 69 2wd C10?
I have a Dropmember with spindles and stock arms. The rear is notched to lay with the factory rearend. I also plan on doing a 1" body drop. Just wondering if they will clear without rubbing the fenders. |
03-27-2012, 11:27 PM | #2 |
67-72 parts collector,…
Re: Will these fit?
Nate usually recommends a 8.5" wheel with a 5.25" bs.
Your 8" steelies would need a 4.75" bs to be a compareable wheel. I bet your wheels only have a 3.5"-4" bs. (which means they would be too close to the fenders)
03-27-2012, 11:51 PM | #3 | |
Re: Will these fit?
That 8.5" w/5.25"bs recommendation for the fronts is most likely when using 17" or larger diameter wheels. 15" diameter front wheels will be back-space limited because of a-arm & spindle interference as a result of the smaller diameter wheel hoop. A 15x7 w/4"bs would prob fit. The common 15x8 rears would prob work out back pending actual back-space.
