Old 06-27-2012, 05:28 PM   #1
gregbr
Senoir Member
gregbr's Avatar
Help- Can't get the glove box open
It's my 2 year old ground up restoration truck, the 70 GMC shortbed factory 402. During the resto, I put in a brand new glove box latch (non locking). Now pushing the latch button only hurts your thumb, button does not move. Is there a way to get it open?? Keep in mind the nice paint & the plastic glove box liner that came with the vintage air kit. Thanks
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 06-27-2012, 05:53 PM   #2
Lee H
Lee H's Avatar
Re: Help- Can't get the glove box open
Can you push in slightly on the door and try to push the botton, maybe take some pressure off the latch??
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 06-27-2012, 06:28 PM   #3
sir_talk_alot
sir_talk_alot's Avatar
Well, a bfh is a bit overkill, so use a can of pb blaster and a sfh.
-Mike-
'94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s
sir_talk_alot is offline   Reply With Quote
Old 06-27-2012, 07:30 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
See if you can turn the button clockwise with your fingers. Even though these are non locking latches, if the button is inserted into the housing incorrectly at the factory they will be in the locked position. Would the lock bolt retract when you pushed the button before you installed it?
LockDoc
Leon
Old 07-11-2012, 02:10 PM   #5
gregbr
Senoir Member
gregbr's Avatar
Thanks for the advice. Have tried pushing on the door & using spary lube, no help. Will try turning the button. Thanks again.
Old 07-11-2012, 03:07 PM   #6
68gmsee
Active Member
68gmsee's Avatar
If I remember correctly the button pushes on a slanted part of the spring loaded latch. I don't think you can turn the button though.
With the glove door open see if you can assist it by pushing the button at the same time you push on the latch piece. If the latch retracts but won't retract when using the button by itself you have a very rough or uneven slanted surface on the spring loaded latch or spring is too stiff. Try lubing it and working it up to see if it will loosen up.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-11-2012, 03:51 PM   #7
LockDoc
LockDoc's Avatar
The button pushes a pivot piece or "cam". The cam then retracts the latch (lock bolt). There is a small spring loaded wafer located in the push button that normally keeps it from turning. There are two positions that the push button can be inserted into the housing, locked and unlocked. If it was put together wrong at the factory you would be able to push the lock bolt down and insert it into the glove box door and then shut the door but you would not be able to push the button to unlatch it.
The problem is, he can't get the glove box door open.
There is no easy way to get it open without some kind of damage to either the lock, door or liner...
LockDoc
Leon
Old 07-11-2012, 05:47 PM   #8
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by LockDoc View Post
The button pushes a pivot piece or "cam". The cam then retracts the latch (lock bolt). ...
There is no easy way to get it open without some kind of damage to either the lock, door or liner... LockDoc
I remember it was a 50's car that my dad had. Memory is faded but I seem to recall a ramp of some sort. Pushing on it moved the slide back and the spring restored it. Maybe I dreamed it.
"can't get the glove box door open."
I think if that's the case, I would cut the liner out and with a small flash light and screwdriver remove the latch asm on the door or the dash. It's would be the least destructive and can be easily replaced.
06 Trailblazer
Old 07-12-2012, 04:47 PM   #9
gregbr
Senoir Member
gregbr's Avatar
Will mess with it this weekend and see what happens. After I installed the new latch on the freshly painted door, it worked for about six months, then one day....nothing.
Thanks, Will update soon.
Old 07-12-2012, 04:54 PM   #10
CC69Rat
CC69Rat's Avatar
Little stuff like that happens to me all the time... I prob would have already taken a crow bar to it.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 07-21-2012, 02:28 PM   #11
gregbr
Senoir Member
gregbr's Avatar
No luck with pushing, turning or sorta beating on the latch. Will dig into it more when it cools off outside.
Old 05-26-2024, 06:22 AM   #12
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Old thread but I'm having the same problem. I've had the truck 10 years now and the original glove box door and push button intermittently worked sometime it would latch and sometimes when I hit a bump the door would flop down. Other times had a hell of time getting it to open but by pushing on the door and pushing the button sometimes it would open. After 3/4 years of that my buddy sold me a keyed one, and he might have got it from LockDoc but not 100% on that, and again worked intermittently and one time would not open after I locked it and thought the keyed lock was the problem so put the original back in and its been on and of working since. So I bought a chrome glove box door and painted the main part ( see picture) with wrinkle paint to match gauge surround and transferred the the original latch button to it. It did open again and sometimes had to fight it and lately it wont open and had a buddy in the passenger seat push and pull on it while I pushed the button but she won't open. From LockDoc post I'm thinking I got a button the was assembled back wards from the factory but if so why did the lock button act the same way. Does anyone know if it could be the non adjustable metal clip the button latches on to is not in the right place.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 05-26-2024, 11:09 AM   #13
LockDoc
LockDoc's Avatar
Sometimes the latch/lock bolt will get a notch worn in it from movement and vibration of the door. That is why pushing in on the door will sometimes work. If the latch/lock bolt cam is broken nothing will make it work. Pushing hard or pounding on the button is what breaks the cam.
Here are pictures of GB locks with worn latch bolts. The first one the door would not stay closed. The second picture is what a bolt should look like minus the small notch. You can see why the one in the third picture would not retract unless you pushed in hard on the glove box door before pushing on the button.
Leon
Old 05-26-2024, 05:40 PM   #14
Already Gone
Thanks for the info. I'm hoping I can get it open one more time without have to destry something to get it open .
Old 05-26-2024, 05:54 PM   #15
Rust_never_sleeps
Rust_never_sleeps's Avatar
maybe probe around with a feeler gauge in case the plastic liner(or sum'n else) has slipped and is blocking the spring latch from moving to the open position
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 05-27-2024, 06:30 PM   #16
Already Gone
Okay next day. Temps in the night here are still real cool so took my truck to work last night and left in open air parkade all night. Metal does different things cold and warm/hot. This morning thought I'd try to open the gb door and pushed on it above the latch and pushed the button and it opened. When closing it woudnt latch completly so a sligt tug and it opened without pushing button. My question for LockDoc is my latch looks like the one u posted in the second picture and I'm figuring mine looks like it is supposed to, right ?
Old 05-27-2024, 08:25 PM   #17
best view
Work ? How many times have you retired
best view is offline   Reply With Quote
Old 05-27-2024, 09:57 PM   #18
LockDoc
LockDoc's Avatar
It looks like there is a little wear at the very end of the bolt, if so, the bolt is probably not going up into the striker very far. That is why you can pop it open without pushing on the button. Also it looks like the lock cylinder case is bent out a little bit behind the bolt which might let the bolt bind a little when it is retracting. The back of the case behind the bolt should be perfectly flat like the first picture. Pictures 2 & 3 show what the lock bolt looks like on a new case.
I would try shimming the striker down about a 1/16 of an inch and file the very top edge of the lock bolt a little bit just to remove the sharp edge.
Leon
Old 05-28-2024, 03:55 AM   #19
Already Gone
Thanks, I'll mess with it tomorrow.
Old 05-28-2024, 07:42 AM   #20
Jim Boy
Now that you have it open, I would remove the box liner until the problem is solved WITHOUT QUESTION, leaving you the access needed to work on it. Good luck.
Jim Boy is offline   Reply With Quote
