07-31-2012, 10:33 PM | #1 |
Red Rocker 72 GMC Jimmy
This is my dads 72 Jimmy that he got arround 16 years ago and has been sitting in the garage since. After we restored my 68 GMC step side long box for my high school graduation hes been wanting to get at it and with my help we started it today. It had a 305 small block and a 350 trans that will be uprgaded to a 496 big block and a 400 turbo. Today we put new body mounts and heavy duty leaf springs in the front axle.
07-31-2012, 10:53 PM | #2 |
Re: Red Rocker 72 GMC Jimmy
Nice solid tub. This should be a really nice ride when finished!
Posted via Mobile Device |
08-08-2012, 09:45 AM | #3 |
Well we had a productive weekend and got the front clip on. As well as getting the doors all welded up and every thing is fiting nice. When we replaced the front leaf springs last week we found that the left bolt that holds the springs together at the axle was broke. And now we cant get the core support to fit right with the mounts in. It sits up too high. So we figure that the truck has been jumped before. So before we take it back appart we willl have to put it on the frame rac and get the frame straightend. For the people who notice the right fender is for a chevy and we are just useing it untill we get a gmc fender.
08-14-2012, 09:10 PM | #4 |
Looks good. Keep up the good work.
08-16-2012, 08:42 PM | #5 |
Unfortunately my dad either has tennis elbow or has a torn something. So not much progress has been made lately. We did get the new wheels and tires today that will be on the Jimmy. They are Cooper AT3's 315-75-R16. Which is like a 35-12.5-R16.
08-16-2012, 09:03 PM | #6 |
Gotta love that chevy orange on the motor!
08-17-2012, 05:20 PM | #7 |
Good choice on the rims
08-26-2012, 07:30 PM | #8 |
Last week we got the fender on the passenger side that we will be using. And we put the new tires and rims on it. Then we pulled the front clip and bolted the 496 big block, 350 trans and transfer case together. We put the assembly in the jimmy and found out that it didn't fit....
08-26-2012, 07:43 PM | #9 |
We started cutting the firewall this weekend and got the motor to fit. We still have to finish the firewall off but it's close. Had some other issues with the a/c compressor but we have that problem almost fixed. We will just have to get a longer belt.
10-03-2012, 12:38 PM | #10 |
Finally got some time to work on the jimmy. We got the doors fitting well and the front clip is also. We pulled the body and put it on a rotisorry and powerwashed the frame and put that on our frame rac.
10-04-2012, 01:40 PM | #11 |
What motor mounts did you use?
10-06-2012, 02:26 PM | #12 |
Factory style. Parts Master #2282. Car Quest # 31-2239HD. We are going to cable the motor to the frame also. Here are pictures of the old ones.
10-07-2012, 05:45 PM | #13 |
Went throu a LOT of sand this weekend. Frame, crossmembers, axles and trailer hitch all clean and in the spray booth.
10-08-2012, 11:18 AM | #14 |
I apologize for asking my question the wrong way. Did you use the truck big block frame stands or the small block frame stands?
10-08-2012, 05:47 PM | #15 |
I believe the small block frame stands. We were unaware of there being a difference. It had a 305 small block originally.
10-08-2012, 05:54 PM | #16 |
Dad got the frame all painted today. Found a broken leaf in the right rear spring. So we will go to our local spring shop and see about getting just the one leaf replaced and doing the same one on the other side.
10-13-2012, 09:16 PM | #17 |
Rolling chassis.
10-14-2012, 11:55 AM | #18 |
Looking real nice.
1969 C10 LWB GMC. 1970 K5 Blazer 1971 K10 Burb Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=529970 Shawn |
10-14-2012, 08:54 PM | #19 |
We got the t-case painted and put the motor, trans and t-case on the frame
11-23-2012, 08:37 PM | #20 |
Painted fire wall and got the frame back from the guy that did the exhaust. 3 in. stainless steel.
11-23-2012, 08:45 PM | #21 |
Good stuff. Keep up the great work!
11-30-2012, 12:01 PM | #22 |
GEARHEAD
That is one of the prettiest exhaust systems I've ever seen. This is going to be a nice truck. Will you have any problems with the under dash heater box with the firewall modifications you made? Or with the gas pedal installation?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
12-08-2012, 03:02 PM | #23 |
Sorry this took so long. Been really busy. Thank you for the complament. The gas pedal will be about an inch closer. And the heater/ac box wont have any issues. We mocked it up when we were cutting so we knew how far we could go. And the center of the fire wall wasnt cut so that part is still at the factiory location.
12-08-2012, 03:12 PM | #24 |
The body is back on the frame and we got the motor runnig. It sounds so goood.
12-08-2012, 05:52 PM | #25 |
Ridin' Dirty
Looks sweet!
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
