Old 08-11-2012, 10:32 PM   #1
dhpenner
dhpenner's Avatar
LS1 in a 72 Wiring Harness Help Me If You've Done One Before?
I'm just laying out my stand alone harness for my LS. Can anyone tell me the best place to run the wires inside the cab? I don't need anymore holes in the firewall. If you've done a swap before please let me know. Pictures are always appreciated.
dhpenner is offline   Reply With Quote
Old 08-12-2012, 09:31 AM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: LS1 in a 72 Wiring Harness Help Me If You've Done One Before?
We have a special area of the board devoted to these swaps...moving you over there.
ETsC10 is offline   Reply With Quote
Old 08-12-2012, 10:00 AM   #3
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
I am installing a PSI stand alone harness right now and I routed mine into the cab like this...
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 08-12-2012, 12:54 PM   #4
mooseknuckles
mooseknuckles's Avatar
same here...used the stock wiring harnes hole in the firewall....
mooseknuckles is offline   Reply With Quote
Old 08-12-2012, 02:32 PM   #5
RocketKing
RocketKing's Avatar
I used the clutch linkage hole and mounted the ECM on the brake support.
Rex
RocketKing is offline   Reply With Quote
Old 08-13-2012, 11:48 PM   #6
ls1nova71
ls1nova71's Avatar
Are you putting the PCM inside the cab, or just a few wires for gauges and ALDL connector?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-14-2012, 04:47 PM   #7
dhpenner
dhpenner's Avatar
I want everything in the cab and tucked way up. The clutch linkage hole is a good idea. I had it marked for filling but it might finally serve a purpose. Thanks for all your input.
Old 08-15-2012, 09:13 PM   #8
1moretoy
Bucksss- Where did you get your grommet? I can't find one anywhere and where are you guys mounting your computers?
1moretoy is offline   Reply With Quote
Old 08-15-2012, 09:17 PM   #9
C10_ustacould
My grommet came on the PSI harness. I am currently building a mount that will be in the glove box area.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
1972, chevy, lsx, wiring harness
