Old 12-23-2012, 10:07 PM   #1
xpickup
xpickup's Avatar
1951 Chevy / C4
Well here is the newest project. It is 48 GMC BURB's and his sons truck. It is getting C4 corvette suspension front and back along with a boxed frame and a tubular trans crossmember, plus a bunch of other things. Then there is a spare frame that is getting the same, but it is for his suburban. I had meet Ken on the forum and he is a great guy and then we meet at the nats east this past summer. It was great finally meeting someone from here. Here is the first picture of it and there will be many more.
Shannon
xpickup is offline   Reply With Quote
Old 12-23-2012, 10:54 PM   #2
69CST-V
69CST-V's Avatar
Re: 1951 Chevy / C4
Can't wait to see you work your magic.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 12-24-2012, 12:32 AM   #3
itstheshu
Re: 1951 Chevy / C4
Are you going to buy kits for the suspension or make your own?
itstheshu is offline   Reply With Quote
Old 12-24-2012, 12:32 AM   #4
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Shannon, I'm all plugged in and ready for your magic to begin...Jim Almost forget have a Merry Christmas and Happy New Year..
oldman3 is offline   Reply With Quote
Old 12-24-2012, 06:29 PM   #5
reaper71
reaper71's Avatar
Re: 1951 Chevy / C4
sounds like a cool project!! good luck
Mark...
reaper71 is offline   Reply With Quote
Old 12-25-2012, 10:11 PM   #6
Atommik
Atommik's Avatar
Re: 1951 Chevy / C4
Hey Shannon,
Looks like a great project!! Will you ever get any time on your own trucks??!! Ha Ha!
Atommik is offline   Reply With Quote
Old 12-27-2012, 04:49 PM   #7
98layinframe
98layinframe's Avatar
Re: 1951 Chevy / C4
Interested to see this build... since it sounds and looks like my trucks twin.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 01-07-2013, 09:39 PM   #8
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
69CST-V, thank you.
itstheshu, the front cross member is a flat out one and I am going to make the rear set up.
oldman3, Thank you. It has been a while. Hope you had a great Christmas and New Years also. I did, but it is good to back to working on things again. I did take a short break.
reaper71, Thank you
Atommik, Thank you. I know mine is waiting again , but you know how things are. At least it is driveable.
98layinframe, Good another twin. I can not wait to get into the suspension.
Well it has been a while. With the holidays and a few little jobs completed. I am starting on the pickup. I am waiting for my plate steel so I am working on some of the sheet metal things. So I am going on a smoothing spree. The gas fill is gone, along with the door handles, all the lights on the fenders,the emblem on the front of the hood, the cowl vent, and a few other odds and ends. Tonight I peaked the hood. the hood was tacked together at the seam and then I formed a 5/16 rod to the profile of the hood and tacked it every inch or so. Then ground the ends to a nice pointy profile. Then I will use some ALL METAL filler to fill up to the top of the radius of the rod. Then use a little regular filler for the final fill. I should have my steel by the weekend and I am getting the 1 5/8 tube for the tranny crossmember also. Here are some pictures.
Shannon
Old 01-07-2013, 09:40 PM   #9
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
Here are a couple of the hood.
Shannon
Old 01-08-2013, 12:31 AM   #10
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Glad to see some progress, looking forward to the suspension work...Jim
Old 01-08-2013, 10:59 AM   #11
Coach529
Coach529's Avatar
Re: 1951 Chevy / C4
Looks great so far.....subscribed.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-09-2013, 06:14 AM   #12
48 GMC BURB
48 GMC BURB's Avatar
Re: 1951 Chevy / C4
Shannon
Your work as usual looks sweet, I'm a little sad to be out of the country not working on it myself ,but at least I won't have to do it twice to get it right !!
Keep up the good work !
Ken
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 01-16-2013, 07:30 AM   #13
48 GMC BURB
Re: 1951 Chevy / C4
Hi Shannon
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 01-27-2013, 10:40 PM   #14
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
It has been awhile since I posted. While I was waiting on my flat metal and tubing I worked on filling some things. Like the clearance lights on the roof, The drivers door handle and some other odds and ends. The chassis that was under the truck ended up being out of square by 3/8". So we decided to use the spare chassis and transfer the sheet metal over to it. I then stated on boxing the frame in the front. I cut out for the Flat Out c4 cross member. Fit it and welded it in, I still have to do the rack cut out and make some fillers pieces that I cut out getting it up in the frame. I put in some temporary braces on the top and bottom of the frame for when I took out the factory cross members. I took all the rivets out and removed them. Then figured out what holes I need to weld nuts to the inside of the frame because of boxing it. I then fit the boxing plates and welded them in. Then ground them all up. Next is to start on the 1 5/8 tubular x member for the transmission. Then onto the rear suspension after that. Then the fun will begin.
Shannon
Old 01-27-2013, 10:42 PM   #15
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
more
Shannon
Old 01-27-2013, 10:44 PM   #16
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
a few more.
Shannon
Old 01-27-2013, 11:10 PM   #17
69CST-V
69CST-V's Avatar
Re: 1951 Chevy / C4
Looks good. Nice progress.
Bryce
Company Trucks
Old 01-27-2013, 11:25 PM   #18
chev3600
chev3600's Avatar
Re: 1951 Chevy / C4
Coming along nicely, keep it up.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 01-28-2013, 12:28 AM   #19
oldman3
oldman3's Avatar
Re: 1951 Chevy / C4
Shannon, as usual you work is top notch. That was a good hunk taken from the frame to install the crossmember, welds look super, nice work buddy....Jim
Old 01-28-2013, 12:55 AM   #20
4544speed
4544speed's Avatar
Re: 1951 Chevy / C4
Shannon,
Looks great. Really clean.
4544speed is offline   Reply With Quote
Old 01-28-2013, 05:04 AM   #21
48 GMC BURB
Thumbs up Re: 1951 Chevy / C4
Shannon
You are & will continue to be my Hero !!
KC
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 01-28-2013, 09:38 AM   #22
98layinframe
Re: 1951 Chevy / C4
Lookin good, very interested to see the suspension build up! Which style of c4 setup you running on these? The 84-87 or the wider 88-96 setup?
Old 01-28-2013, 11:29 PM   #23
xpickup
xpickup's Avatar
Re: 1951 Chevy / C4
69CST-V, chev3600, oldman3, 4544speed, Thank you all
48 GMC BURB. Thank you, and glad you are pleased.
98layinframe, Thank you. I think it is the narrower style. I will try to throw the front wheels on for you and give you some measurements.
I gave my roll cage bender a good work out tonight. I started to rough in the upper transmission x member. I welded in the new cross brace and have have to fit and cope the tubes to it. then I will bend up the lower one, it will be all one peice. The lower one will be angle down a few degrees to get a little extra room for the exhaust and the brake booster and master cylinder.
Shannon
Old 01-29-2013, 08:06 AM   #24
48 GMC BURB
Re: 1951 Chevy / C4
Shannon
I'm VERY PLEASED
The front you have on is the 84-87
The rear 's I dropped off you have one of each
48 GMC Burb
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
Old 01-29-2013, 09:21 AM   #25
98layinframe
Re: 1951 Chevy / C4
Man I'd love to have a bender! Think thats gonna be my next larger purchase.
I noticed in couple of your pics theres a slot cut into the frame.. I'm assuming thats to clear the upper arm mount sliding the crossmember into place? Did you have to do this on both sides?
