6>8 Plugless........
![]() Join Date: Sep 2007
Cummins Part Numbers You may Need
This thread is for 5.9 Cummins part numbers to try to save some one some time and hassle. If you have some odd ball stuff that you searched for ever on your swap, post it. If you're looking for something, ask and I'll try to find it for you.
First, this is a front seal kit with a wear sleeve for your crankshaft. 90% of the front seals replaced out there need the wear sleeve because the original seal wore a groove in the end of the crank and most people just install a new seal and that's it. 3802820 Here is the rear seal with the wear sleeve. 3926126 Next is a front seal installer. Makes front seal installs so much nicer! 3824498 Here is a KDP tab. 3958017 This is a fuel filter for VE engines with out the water in fuel sensor. FS1251 These parts are what you need to put a tach drive on the injection pump/front cover. 2 62392 Washer 2 3027685 M6 1.00x12 Bolts 1 3903475 Rectangular Sealing Ring 1 3914132 Angle Drive Adapter 1 3917333 Tach Drive Hup Coupling 1 3915800 Seal, Rectangular Ring 1 3918215 Adapter Tach Take Off Drive Intake spacer to delete grid heater or for a P-pump 24v 3922484 Gaskets for Grid heater or Above Spacer 3931604
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 02-15-2013 at 09:06 PM. |
Re: Cummins Part Numbers You may Need
Hey diesel wrencher . Here you posted the kit to install a tach drive. What do you think the difference is between a mech tach and a speedo? The orriginal gm diesel tach to fit my truck ( you cant find anymore ) Looks just like the speedo beside it. The hr meter even has same num of digets as the odometer on the speedo. If to get a gauge face decal kit it comes with a tach decal that fits right on a speedo. What im getting at is if you hooked a speedo to a tach drive do you think you could ever make it measure close ??? Ie 2000 rpm showing as maby 20 or 30 mph on the speedo.
Have I made that sound confusing enuf?? Let me know your thoughts .
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
#3 | |
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
It deffinately lounds like its worth the try. i have a 3116 cat system around here somewhere . It drives off the crank. to the 90 deg then into the cable. going to see what bits a peices I can round up. you know how much the cummins parts cost ??
Thanks again .
I can find out for you. It's been a while since I got mine.
![]() Join Date: May 2009
Hey I was just wondering what you would have to do to run a stock electrical tach on a 1st gen 12 valve I saw you put part numbers for a mechanical tach so I was just wondering how to make a electrical tach to work. thanks
Posted via Mobile Device |
here's a right up I did to modify the 2nd gen dodge alternator for a tach lead. a 1st gen should be real similar.
http://www.4btswaps.com/forum/showth...dge-alternator |
Thanks to COS399 for this tip. The below description has a part number in it for an internal voltage regulator that will go inside a dodge cummins alternator so the ECM or an external voltage regulator isn't required on your conversion. I haven't used one yet but will on the next one I do.
The box is marked as being made by "TRANSPO" and the part number is "IN8315." Below the part number it reads "V R INSERT NIP/CHR." I am assuming it means, voltage regulator insert Nipondenso and Chrysler.???
I dont know what the local alt guy did with mine but I gave him my dirty old stocker and he gave me back a new looking one with 1 wire hook up and self exciting . When you start the truck just give the throttle a blip above 1000 or so and you see the lights go brighter and stay bright . I think he charged me $140 ? Works awsome . Maby this is what he used inside mine .
#10 | |
Dawna informed me that a Bosch alternator requires a "C8315" regulator. Not sure what year /s has the Bosch alternator. These thread will sure come in handy. |
For anyone looking online, I found this place below sells the IN8315 regulator.
http://www.aspwholesale.com/index.ph...productId=8416 They also have the C8315 as well. http://www.aspwholesale.com/index.ph...productId=2095
