Old 03-16-2013, 11:58 AM   #1
rcrahn
rcrahn's Avatar
Gauges used for LSx swaps
I'm at the point where it's time to decide on gauges to get for our project with a 6.0/4L80E. I've searched around here. Sure would be nice if there was a dedicated sticky to just this subject. Swappers, please take a moment to explain what gauges you used, how they were to install, how they are working and the cost. Much appreciated.
rcrahn is offline   Reply With Quote
Old 03-16-2013, 02:07 PM   #2
Robznob11
Robznob11's Avatar
Re: Gauges used for LSx swaps
well I have sun pro mechanical gauges. I used a hose connector in my top radiator hose to put the temp sender, got it off ebay cheap and already was tapped for sender. I broke off the oe oil sender at the back of the manifold and tapped it for the oil gauge hose, and the super sunpro super tach is a programmable model that will work for 2 4 6 or 8 cyl so you can set it and hook it directly to the puter ouput. no speedo or fuel gauge yet but im thinking I may go with a gps speedo for easy no wire hook up and im still trying to figure out the fuel. well I really have not messed with it much but I know that you can use an ohm meter and check the range of the stock sender then just buy a gauge for that range.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-16-2013, 02:13 PM   #3
67swb72klb
67swb72klb's Avatar
try this
http://67-72chevytrucks.com/vboard/s...d.php?t=512751
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-16-2013, 03:04 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
built a new gauge cluster,An hour of cutting and trimming stainless followed by 15 minutes of wiring connections and slapping a scangaugeII on it. Doesn't get much simpler.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-16-2013, 05:06 PM   #5
rcrahn
rcrahn's Avatar
Thanks for the input. I should have explained it's a 67-72 dash cluster I'm interested in. It seems there's plenty of choices. I'd like to take the KISS approach.
Old 03-17-2013, 02:37 PM   #6
ls1nova71
ls1nova71's Avatar
Keeping it simple usually means the cost goes up and keeping the cost down makes the simple part goes away, at least for me. These are pretty nice and I would think simple, but they're proud of them. http://www.dreamershotrods.com/class...dgmctruck.aspx Or you can do what I have done, (what 67swb72klb posted) it's way cheaper, but definitley not the simplest way. But I just do not like the look of most aftermarket gauges, it's just my opinion, but I like the original look better, so that's why I use the original stuff.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-17-2013, 11:55 PM   #7
rcrahn
rcrahn's Avatar
I like what you did. It shows some real ingenuity. I appreciate the link you posted too. I'm still hunting around. Speedhut gauges are interesting to me with the use of microprocessors and the way you can personalize the appearance. Very cool.
What I'm going to say might offend some but I think the original style dash with all those gauges is too busy. Speedhut has a 2 gauge custom set - 4" dual speedometer and tach along with 4" quad gauge - oil, water, fuel volts. They are selling the set currently for $531.
I think these will make for a very clean looking dash.
If I purchase a 3 hole dash bezel and make a thin bezel sheet to hold these it should work okay.
Old 03-18-2013, 01:38 PM   #8
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Autometer has 5" quad gauges and 5" speedo's including a small tach across the bottom.
They also have 3 3/8" dual gauges. I have the dual fuel/oil pressure one as shown below. I also have Aeroforce Interceptor on the dash for info off OBDII diagnostic port, but may move it to replace trans or a/f gauge.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-18-2013, 02:07 PM   #9
jorgensensc
jorgensensc's Avatar
I've got some speed hut gauges on thier way to my house. We will see how they turn out.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 03-18-2013, 02:12 PM   #10
rcrahn
rcrahn's Avatar
Which gauges did you select? I'm interested in your feedback once you get them. Thanks
Old 03-18-2013, 02:45 PM   #11
jorgensensc
They should be here in a couple of days. I used the 4 1/2" tach and speedo, and the 2 1/16"
Can bus oil pressure, tranny temp, water temp, and volt gauge. They also made me a custom 3 3/8 can bus gauge. I'll post pics when I get it all put together!
Old 03-18-2013, 02:56 PM   #12
Billett
Billett's Avatar
sub'd for my swap
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 03-18-2013, 07:04 PM   #13
TchncnDen
I used gauges out of a Silverado ($40) and later upgraded to Escalade gauges ($100). The Escalade gauges have a more vintage look to them and fit the look of the truck as well as the added trans temp gauge.
TchncnDen is offline   Reply With Quote
Old 03-24-2013, 02:30 PM   #14
eagleuh1
eagleuh1's Avatar
Tchncndan, can you post a better pic of the 2nd set of guages, the Escalade ones. That sounds interesting and somewhat inexpensive..Thanks. Jim
eagleuh1 is offline   Reply With Quote
Old 03-25-2013, 12:26 AM   #15
rmvlt1100
rmvlt1100's Avatar
I placed a piece of sheet metal in place of the old gauge cluster then used autometer sport comp. gauges with electric sending units. The speedometer and tach are also electronic that hook up directly to the CPU. Did a little body work smooth out the edges, painted then had it hydro dipped. Everything works good.
Good luck with your setup.
This is my Build A 5.3L 1965 C-10 Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=502100
rmvlt1100 is offline   Reply With Quote
Old 03-25-2013, 11:10 AM   #16
Daaaanz67
That's nice, where did you get that turn signal lever with the cruise. Also is it a three wire or four cruise
Daaaanz67 is offline   Reply With Quote
Old 03-25-2013, 08:13 PM   #17
Crash_OK
Crash_OK's Avatar
Dakota Digital VHX with their PCM interface. The speed, RPM, Water Temp, etc are feed to the gauges via the PCM.
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 03-25-2013, 08:18 PM   #18
TchncnDen
Between my crappy camera and limited space it's hard to get a good picture, but these are a little better. I think I am going to redo my plexiglass face and bring the mask in a little tighter, but other than that I'm very happy with these. Here is a pinout on how to wire them up.
Pin color use
A1-2-not used
A3---pink------fused ignition feed
A4---not used
A5---tan/wht--brake warning indicator lamp input NOT USED
A6-7-not used
A8---brwn/wht-SES light
A9---not used
A10--orn-------fused battery feed
A11--not used
A12--lt blu------left turn input
A13--ppl/wht---seat belt indicator NOT USED
A14-16-not used
A17--lt grn------high beam indicator
B1---brn--------park lamp feed
B2---not used
B3---gry--------security indicator input
B4---not used
B5---ppl/wht----fused ignition feed
B6---gry--------Class 2 Serial Data ***********
B7---orn/blk-----rear compartment lid ajar indicator NOT USED
B8---dk grn/wht--vehicle speed signal
B9---gry---------instrument cluster lamp feed
B10--dk blu------right turn indicator input
B11--blk----ground
B12-13--not used
B14--tan---------oil pressure gauge input
B15--blk wht------ground
B16-17- not used
I unplugged the ribbon cable to the message center otherwise the security light will always flash when on. The oil pressure switch is different for 99-02 and 03-06 so you have to use the switch of the same year as the cluster. The 03-06 gets its oil pressure from the PCM and the 99-02 is wired direct as above.
Old 03-26-2013, 12:36 AM   #19
ramega
ramega's Avatar
that looks somewhat clean.
ramega is offline   Reply With Quote
Old 03-26-2013, 10:24 PM   #20
rmvlt1100
rmvlt1100's Avatar
Thank you. Sorry I didn't see the post till today. It is a 4 wire lever. I will look for the part number.
Robert
Old 03-27-2013, 04:34 PM   #21
eagleuh1
eagleuh1's Avatar
Thanks TchnchDen, pretty cool idea. Does look more Classic than the other too. Lots of cool ideas floating around here. Jim
Old 03-28-2013, 03:32 PM   #22
mooseknuckles
mooseknuckles's Avatar
I'm in the middle of swapping a '65 c10 dash into my '86 c10 lq4/4l80....all electric autometer american muscle gauges, and a boese engineering gauge panel...I dont have them wired up yet, but should work awesome...
mooseknuckles is offline   Reply With Quote
Old 03-29-2013, 10:08 AM   #23
eagleuh1
eagleuh1's Avatar
Mooseknuckles, that is one sweet looking guage panel. The American Muscle guages look very nice.
Old 03-29-2013, 01:34 PM   #24
faribran
TechncnDen, i sure like the way you did your dash.... might have to borrow that idea... thanks for sharing.
faribran is offline   Reply With Quote
Old 03-29-2013, 04:16 PM   #25
mooseknuckles
thanks!....I've been wanting those gauges since they first came out....
