07-08-2013, 11:22 AM | #1 |
spindle choices
Hi all, I am in the market for some new front spindles. While on the power tour I lost an outer wheel bearing which in turn trashed my spindle. It was fixed and away we went but now I have torn it down and figure it better be replaced.
Currently I have CPP modular ones. I have the bracket and am using the D52 Wilwood replacement brakes so I don't know that I will ever upgrade to a larger brake so these modular ones are really not as important to me. These are only 2 inch drop and I can always use another 1/2 or so... These appear to be good spindles but would you look elsewhere? Or stick with these? With my wheel choice I ended up with spacers so if the spindles widened my track it would not hurt I would just ditch the spindles. This is on my 68. Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
07-08-2013, 12:01 PM | #2 |
Re: spindle choices
Excuse my ignorance, but are you running factory size rotors or a larger size? What I assume is that you are running modular spindles with a bracket to run D52's and stock 5 lug rotors, is that right? If so then I would think you could run any C10 specific spindle and bolt up the D52's. I run ECE spindles FWIW.
07-08-2013, 12:12 PM | #3 |
Re: spindle choices
I probably was not clear. I am running stock size rotors. They are 6 lug.
Yes I can run any C10 specific spindle I had just read on here there are some cheap ones and I drive this think so I wanted to get a good quality spindle. I will be autocrossing so again I wanted strong. I have heard good things about the ECE stuff. Thanks Dave
07-08-2013, 12:59 PM | #4 |
67-72 parts collector,…
Re: spindle choices
ECE, Belltech, Western Chassis or McGaughys.
