Old 07-10-2013, 08:51 PM   #1
seaglass
seaglass's Avatar
Steering Problems
On my way home i heard a POP and all of a sudden I had no steering.
Not sure how easy of a fix this is or what caused this to happen. PLEASE HELP!!!
seaglass is offline   Reply With Quote
Old 07-10-2013, 09:23 PM   #2
tinydb84
tinydb84's Avatar
Re: Steering Problems
Fairly easy fix. Buy a new pitman arm and replace that one. Check the rest of the steering parts for excessive wear
David
Instagram: myfabguy
Old 07-10-2013, 11:38 PM   #3
oldman3
oldman3's Avatar
Every good advise. Replace with Moog parts if possible, good stuff...Jim
oldman3 is offline   Reply With Quote
Old 07-11-2013, 05:09 AM   #4
JointTech
JointTech's Avatar
hows that even possible. There should have been a castle nut with a cotter pin on there. You should check the rest of your suspension. All your balljoints, tierods, spindles and anything that attaches to the drag link should have a castle nut and cotter pin.
I'm sure you had a severe case of monkey butt when that happened. lol, lucky you didnt wreck and kill yourself or somebody else.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-11-2013, 10:55 AM   #5
seaglass
seaglass's Avatar
So should I get a new pitman arm or just find a cotter pin and a nut?
Old 07-11-2013, 10:57 AM   #6
seaglass
seaglass's Avatar
And no thank God I wasnt on the road I heard a pop about a mile before i got home and pulled over into a parking complex when i pulled out one tire went one way the other stayed straight.
Old 07-11-2013, 02:07 PM   #7
JointTech
JointTech's Avatar
personally I would replace the pitman. Go to autozone or whereever and borrow a pitman puller.
then again unless you are changing everything does it really matter? you could just get the nut and cotter pin. the arm itself doesnt look broken to me.
and then on the other hand, pitman is cheap and the puller rental should be free.
lol not very helpful huh...
72 C20 Long Bed
Old 07-11-2013, 03:00 PM   #8
Rufton
PA nut should be torqued to spec.
66 PA nut isn't castle (no cotter pin).
Rufton is offline   Reply With Quote
Old 07-11-2013, 03:02 PM   #9
JointTech
JointTech's Avatar
ah i forgot this part of the forum has you weird non 67-72 guys
72 C20 Long Bed
Old 07-11-2013, 05:04 PM   #10
seaglass
seaglass's Avatar
Yeah I checked with advanced auto parts and the the only way to get a pin and bolt is to order a new pitman. So im going to get that and just use the pin and bolt from the new one to put it on ( I figure 20 bucks is going to be an inferior pitman arm and hopefully the bolt is better quality then the one i dont have lol) I have a buddy who can see if the pitman arm needs to be replaced as well. I live in an apartment complex that frowns upon working on cars
Old 07-11-2013, 11:21 PM   #11
JointTech
JointTech's Avatar
yea mine as well. it sucks but it would look like a dump if they allowed it. I do all my work at my office in the parking lot lol
72 C20 Long Bed
Old 07-12-2013, 01:15 AM   #12
seaglass
seaglass's Avatar
I would understand dropping a new motor in or somethin but to even change a flat they would rather you tow it out of the complex to get it fixed...
