Front suspension Handling Mods...?
I have an 84 that I'm in need of some advice for.
I have read the entire "make it Handle" thread and already searched.... I have CPP upper and lower arms. 2" drop modular spindles and 1" drop coil springs front tires will be 275/40R20's on 9.5" wide rims I'm looking to help center the front wheel slightly and get to the magic 7deg caster angle. It will be a static drop daily driver so good performance but plenty of suspension movement and clearance needed. I would buy a dropmember if they made one for coil springs....but since they don't... Should I: A. Cut the frame to raise the crossmember up 1" B. Pancake the crossmember 1" C. Move the lower control arms forward 1" D. switch to rack and pinion (I already have all new pieces for the current style and I don't want to change the box placement but am willing to change things to reduce bump steer) E. some combo of the above. I have read that the 73-87 trucks have more caster built in (5 deg) but have found multiple contradictions I haven't found any good threads detailing the newer body style crossmembers for performance Please help ![]() |
Re: Front suspension Handling Mods...?
I swapped to the CPP upper arms and retained my stock ones. I was able to get 7+ degrees of caster with those arms They have the additional built into them. I am afraid if you moved the lower forward without moving the upper you would end up with too much caster. That is based on mine now.
There are now a couple options for coil spring (coil over) front cross members. Scotts and Porterbuilt both do, I am not sure if No Limit has or not. Plus another out there is doing it.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
A day should have 30 hours.
Here is a link to a great front suspension setup (with coilovers)
http://www.porterbuiltfabrication.com/?p=453 Thats what I would run. |
I'm doing something similar to A and C.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#5 | |
I did notice that the holes in the CPP arms are sloppy/looser than I thought they should be on the stock studs One question - your truck is a 73-87 that you used the arms on and got 7 degs? |
#6 | |
![]() Quote:
#7 | |
This was done on a pre 73 crossmember though, and I haven't found any hard evidence on what the differences are. |
I'm doing a 2.5'' Z and I am sectioning the upper and lower control arms. I am moving the upper ball joint back a bit and the lowering one forward a bit. It solves my laying out problem, adds caster, and should help clear the fenders.
A bit of everything. Hopefully.
#9 | |
I didn't really notice the holes being too sloppy. but I hope once they are set they can be tightened up and will stay where they are put. I had startd a thread about moving the upper holes. My thought was to move them down slightly but I have not done the calculations on what that location should be so for now I will leave it stock until I can find the better location.
