Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 07-13-2013, 07:09 PM   #1
Touchdown67
Touchdown67's Avatar
Air conditioner smell...
I have a 2009 Tahoe. I have noticed that the A/C air seems to have a dirty/moldy smell. I looked to see if there is a cabin filter but I guess they do not use a cabin filter any longer. Has anyone had this problem and figured out what can be done without taking it to the dealer for a $$$ repair?
Touchdown67 is offline   Reply With Quote
Old 07-19-2013, 11:03 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Air conditioner smell...
I have used Fabreeze with some success. It worked well on the last truck I sold but my 09 is being a bit more stubborn. I just spray it down the vents and let it sit.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-30-2013, 06:56 PM   #3
MadManAndrew
My dad's Suburban is the same way. I can't stand it.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 08-25-2013, 01:14 AM   #4
MUDSLT
MUDSLT's Avatar
They should have a filter under the dash on the passenger side?
MUDSLT is offline   Reply With Quote
Old 08-31-2013, 01:05 AM   #5
mcmlxix
Collector of Projects
mcmlxix's Avatar
I think there was a TSB for this....
TECHNICAL
Bulletin No.: 99-01-39-004D
Date: August 10, 2011
Subject: Air Conditioning Odor (Install Evaporator Core Dryer Kit and Apply Cooling Coil Coating)
Models:
2012 and Prior GM Passenger Cars and Trucks
All Equipped with Air Conditioning
Supercede:
This bulletin is being revised to add the 2011 and 2012 model years. Please discard Corporate Bulletin Number 99-01-39-004C (Section 01 - HVAC).
Condition
Some customers may comment about musty odors emitted from the Heating, Ventilation and Air Conditioning (HVAC) system at vehicle start-up in hot, humid conditions.
Cause
This condition may be caused by condensate build-up on the evaporator core, which does not evaporate by itself in high humidity conditions. The odor may be the result of microbial growth on the evaporator core. When the blower motor fan is turned on, the microbial growth may release an unpleasant musty odor into the passenger compartment.
There are several other possible sources of a musty odor in a vehicle. A common source is a water leak into the interior of the vehicle or foreign material in the HVAC air distribution system. Follow the procedures in SI for identifying and correcting water leaks and air inlet inspection.
The procedure contained in this bulletin is only applicable if the odor source has been determined to be microbial growth on the evaporator core inside the HVAC module.
Correction
Many vehicles currently incorporate an afterblow function within the HVAC control module software.
Rich
1972 K5 Blazer CST Click HERE
Old 10-24-2013, 10:07 PM   #6
trendkill
The AC on my '11 extended cab sucks all together. I think it freezes up and makes a loud noise in the passenger vents, and blows a fog or something from the vent. Need to take it to the dealer while its under warranty still.
trendkill is offline   Reply With Quote
Old 10-27-2013, 03:10 AM   #7
cedens
cedens's Avatar
They took out cabin air filters several years ago IIRC, something with the newer a/c system they are not needed?
cedens is offline   Reply With Quote
