Old 08-20-2013, 09:31 PM   #1
eray92
eray92's Avatar
73-87 pics wanted: cut coils and flip kit
hey guys, I have an 82 chevy custom deluxe. I want to drop it down using the flip kit c bracket and cut a coil-coil and half off. anyone have pics of this set up? and the c bracket has a hole in it for the spring pin. how does this go on?
[ o ] or [ o ]
rear <- front ->
thanks in advance
eray92 is offline   Reply With Quote
Old 08-21-2013, 02:43 PM   #2
epon
epon's Avatar
Re: 73-87 pics wanted: cut coils and flip kit
pretty sure thats what this 81 has - http://farm8.staticflickr.com/7444/9...9c966bfe_b.jpg
epon is offline   Reply With Quote
Old 08-21-2013, 05:20 PM   #3
bdiamond
The hole is to move the axle back so the driveshaft doesn't bottom out in the transmission. The hole should be in the front.
bdiamond is offline   Reply With Quote
Old 08-22-2013, 04:33 AM   #4
eray92
eray92's Avatar
I need my d/s to be about 1" further into my transmission. Will doing the flip help my out any?
Old 08-22-2013, 10:18 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
No its not going to help. The flip moves the axle farther away from the tranny. The off center plates move it back again so essentially your axle position stays the same.
BTW- I do not recommend cutting more than 1 coil before you fit and check. If your springs are sagging 1.5 coils on the first cut will bottom out easily.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-22-2013, 04:13 PM   #6
eray92
eray92's Avatar
My coils are pretty healthy but I was going to cut 1 and re-install to see what it does. Thanks for the advice and help, it's very appreciated!
Old 09-15-2013, 05:26 PM   #7
eray92
eray92's Avatar
For the rear I'm having my friend weld on new perches at the right angle and was wondering about shock extenders. I found some on summit that are western chassis. Summit part number WST-2074. Would these be good?
Old 09-15-2013, 06:44 PM   #8
cory d
cory d's Avatar
1.5 coils cut and flipped
cory d is offline   Reply With Quote
Old 09-15-2013, 06:47 PM   #9
cory d
cory d's Avatar
i am now running GM's big block "dooley"coils with 2 coils cut. discontinued part but moog has the same thing for cheap
Old 09-15-2013, 08:03 PM   #10
eray92
eray92's Avatar
I have looked at your threads a lot, you sir have a nice truck
Old 09-15-2013, 09:23 PM   #11
eray92
eray92's Avatar
So any one have any info on the shock extenders?
Old 09-16-2013, 08:42 AM   #12
Hertzdaddy
That's what I used. They work fine if you have the straight shock mounts on your axle. Some of the axles have a shock mount with a little bend in the tabs that doesn't work with these extenders.
Hertzdaddy is offline   Reply With Quote
Old 09-16-2013, 08:52 AM   #13
Hertzdaddy
Are you sure about this? I always read that the flip moves the axle closer to the trans. Doesn't the forward hole location on the relo bracket move the axle further back on the leaf, thus to the rear of the truck, to compensate? That's the way it worked on mine at least.
Old 09-16-2013, 01:29 PM   #14
eray92
eray92's Avatar
That's what I thought. I will find out today when I go over to my buddies.
Old 09-16-2013, 08:46 PM   #15
bdiamond
The rear of the spring is higher than the front. the center pin is at an angle like this \. so going from below the axle to above will move it forward. Correct? The hole goes to the front to move the axle back to the original location.
Old 09-16-2013, 08:50 PM   #16
eray92
eray92's Avatar
That is the correct theory. I didn't find out today, couple problems came up
Old 09-26-2013, 05:26 PM   #17
eray92
eray92's Avatar
Re: 73-87 pics wanted: cut coils and flip kit, updated
Flip kit with 1.5 coils cut
Old 09-26-2013, 11:04 PM   #18
BenfromTruro
When you cut the front coils, how do you address the camber change? The previous owner
of my truck cut the front springs, I dont know how many coils but probably too much as it sits on the bumpstops with the new engine I'm putting in it. The thing has a crap load of shims already installed, and I dont think there is enough room left to shim all the camber out.
Last edited by BenfromTruro; 09-26-2013 at 11:05 PM. Reason: Edited for more info!
BenfromTruro is offline   Reply With Quote
Old 09-26-2013, 11:07 PM   #19
eray92
eray92's Avatar
I cut the bump stops out but my camber didn't change. But to adjust it you have to shim the upper control arm
Old 09-26-2013, 11:09 PM   #20
eray92
eray92's Avatar
Oh and flipping the axle with new perches does move the drive shaft further into the transmission
Old 09-26-2013, 11:11 PM   #21
BenfromTruro
my 74 is cambered bad, and there is only about an inch or so of shim room left.
Old 09-26-2013, 11:19 PM   #22
eray92
eray92's Avatar
3 options
1. Buy new grade 8 bolts and replace them
2. Buy spindles and springs
3. Buy stock springs and cut 1-1.5 coils off max
