Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 08-28-2013, 10:48 PM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
New to me 2008 Sierra RCSB
So I just picked up a Sierra tonight... Needs a little attention and a good cleaning... Cruise control isn't working and the rear is whirring a little... 122K miles... Here are the pics from CL...
Rich
1972 K5 Blazer CST Click HERE
Old 08-30-2013, 08:56 PM   #2
mcmlxix
mcmlxix's Avatar
Re: New to me 08 Sierra RCSB
step one, new (to me) wheels and tires... Enkie RT6 in 20x9 .... Going to get some low mile takeoff Goodyear Eagle LS2 in 275/55/R20.
Rich
Old 08-30-2013, 09:19 PM   #3
mcmlxix
mcmlxix's Avatar
OK, so the rear is making noise ... I would like to replace GM unit rather then rebuild it... what are my options... best solution without costing a million bucks... needs to be done in the next week or so....
I think I want a Detroit Truetrac ... not sure about the part number. I got a list of RPO codes from the dealer and I didn't see the G80 posi unit listed and it doesn't have the HD tow package...
I think this is the one.... GM 8.5 Detroit Truetrac Posi Differential 30 Spline: P/N 913A481
Rich
Old 08-31-2013, 09:18 AM   #4
redracer95
nice truck. what motor do you have in it?
redracer95 is offline   Reply With Quote
Old 09-01-2013, 12:45 AM   #5
mcmlxix
mcmlxix's Avatar
4.8L / 4L60e ... I'll drop in a 6.0L when it dies...
Rich
Old 09-01-2013, 10:12 PM   #6
mcmlxix
mcmlxix's Avatar
Here's a pic with the wheels installed... Just ordered 2" rear lowering shackles... That's it for now because I need to have the rear rebuilt... Detroit Truetrac? Yes Please.
Rich
Old 09-04-2013, 08:30 AM   #7
468BIGBLOCK
MEMBER OF THE JUNK MAN CLUB
468BIGBLOCK's Avatar
nice truck. and i love white.
I LIKE 67-72 CHEVYS, I HAVE OWNED OVER 150 OF THEM IN THE LAST 25 YEARS..
468BIGBLOCK is offline   Reply With Quote
Old 09-08-2013, 09:54 PM   #8
mike1971c10
mike1971c10's Avatar
Here's my new to me 2008. Got a good price on it because it has 93,000 miles on it needed a few things fixed but good overall
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68
mike1971c10 is offline   Reply With Quote
Old 10-21-2013, 04:38 PM   #9
KEL
72 GMC
KEL's Avatar
Ever get an answer to this ?
Thanks.
KEL is offline   Reply With Quote
Old 10-22-2013, 01:38 AM   #10
mcmlxix
mcmlxix's Avatar
Thanks.
Yes... Detroit Locker 913A481 Trutrac Differential is the correct one... it needs the correct bearing set for the late model trucks....
2x Timken LM603049
2x Timken LM603012
Rich
Old 10-22-2013, 07:53 AM   #11
KEL
72 GMC
KEL's Avatar
Thank you.
My G80 quit and I need to do something before the snow falls.
Guess you dont have that problem in Vegas.
Old 01-13-2014, 06:14 PM   #12
redracer95
did you get you cruise control fixed? I ask because I just got a 2008 Seirra rcsb 4X4 4.8l and the cruise control is not working either. Any help would be greatly appreciated.
Old 01-13-2014, 06:40 PM   #13
mcmlxix
mcmlxix's Avatar
I did. As long as the light on the steering wheel comes on, its most likely the brake switch attached to brake pedal arm. A/C Delco# D1586H, GM# 15861245. All you need is a 10mm wrench and a small screwdriver to pry the clip apart. It's a ten minute job to swap the switch. * If the light on the steering wheel doesn't come on, you may have other issues such as a bad fuse.
Rich
Old 01-15-2014, 07:08 AM   #14
redracer95
sweet. yes the light on the steering wheel does come on. thanks for the reply and part numbers. i'll give it a try.
Old 01-15-2014, 08:50 AM   #15
redracer95
stop lamp switch is ordered. i'll let you know what happens.
Old 01-17-2014, 10:43 AM   #16
GMCJOE
GMCJOE's Avatar
Just pull your stop switch off the pedal, pull it apart, clean it, put it back together. It will work after that. Most of the time the connections just need cleaned up on the inside.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 01-17-2014, 05:34 PM   #17
redracer95
cool! thanks i'll try that tomarrow when I get home in the morning.
Old 01-17-2014, 06:19 PM   #18
GMCJOE
GMCJOE's Avatar
No problem. I read about it while I was researching my speaker issue. If it doesn't work, then you will have the new one.
Joseph
Joe's 69 GMC
Old 01-29-2014, 04:49 PM   #19
redracer95
I finally got the stop light switch replaced when I got home this morning. And whadda you know the cruise control works!!!! WOOHOOO! thanks for all the help you guys!
I did notice that for the last week and a half that when I pressed the brake pedal the brake lights would light up but not stay on unless I pressed hard on the pedal. Since the switch is replaced now the problem is gone.
Old 01-30-2014, 11:15 AM   #20
Low Elco
Thanks, Joe! Having the same problem, need to get on it.
Low Elco is offline   Reply With Quote
Old 01-30-2014, 05:54 PM   #21
Woogeroo
mcmlxix,
nice ride.
I like the GMC front end a lot better than the Chevy on that body style.
-W
Woogeroo is offline   Reply With Quote
Old 02-11-2014, 01:54 AM   #22
mcmlxix
mcmlxix's Avatar
Thanks W -
I need to wash the truck... but I added white mirror caps and white door handles... Sill need to remove the 1" rear block and install the rear drop shackles... that should at least level the truck out... but it still looks live a 4x4....
Rich
Old 02-11-2014, 06:48 AM   #23
Woogeroo
We of course, require new photos.
*smIrk*
-W
Old 05-09-2014, 02:13 AM   #24
mcmlxix
mcmlxix's Avatar
When I got the truck the front chrome bumper had a good little dent in it... I bought a cheap aftermarket replacement and then had the three pieces covered in color matched and UV coated Line-X..... heres the shot at dusk just afer I finished bolting everything back up... I left the two hooks off and had some aluminum plates cut to cover the holes and mount some LED running lights. (you can also see the white mirror caps in this pic)
I also picked up a set of McGhaugys 2" drop spindles off CL that I haven't had the chance to install yet and a new set of rear U bolts to remove the 1" lift block. That will gove me 2" drop in fron and 3" in the rear... that still leaves the rear too high to be level ... oh well...
Once I get my 72 Blazer done, I'm going to sell the Sierra and restore a 1973 Mercedes-Benz 280SEL I have waiting patiently... so I REALLY can't spend more money....
Rich
Old 05-15-2014, 03:40 PM   #25
Addictuned GMC
How did your Line-X dealer get the product to stick to the chrome?
Addictuned GMC is offline   Reply With Quote
