Old 09-21-2013, 03:03 PM   #1
timberwolfgirl
Confused about drop spindles vs lowering coils
After asking 6 different people this same question, Ive gotten 6 different answers!! SO that leaves us very confused. We are new to the project and restoration community so sorry if some questions seem dumb to you veterans I was told that for a 2" drop I needed to buy 2 "drop springs and 2 1/2" drop spindles for the front. (WE will worry about the back later). So now that I have ordered and received them our friend putting them on said we only want one or the other. Meaning stock springs with drop spindles, or stock spindles with drop springs!!!!! I guess its really how low we want it to be in the end. Not stock but not completely slammed, somewhere in the middle......
Any help with this will be much appreciated
timberwolfgirl is offline   Reply With Quote
Old 09-21-2013, 03:23 PM   #2
Terry Crist
Re: Confused about drop spindles vs lowering coils
Drop spindles with stock springs is the best way as far as I am concerned. You still get the same ride, just a lower truck.
The way you did it you get a 5 1/2" drop.
Terry Crist is offline   Reply With Quote
Old 09-21-2013, 03:25 PM   #3
Half-Fast
2-1/2 + 2 = 4. I would go with the 2-1/2" drop spindles and stock springs.
edit: LOL, I was typing as Terry was posting.
Half-Fast is offline   Reply With Quote
Old 09-21-2013, 03:32 PM   #4
sxtrail2
Yes 2 + 2.5=4.5..thats what mine is and lovin it...
sxtrail2 is offline   Reply With Quote
Old 09-21-2013, 03:43 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Originally Posted by sxtrail2 View Post
Yes 2 + 2.5=4.5
x2
I was beginning to wonder if you guys ever took math in school.
Ha.
Keith
Convert to disc brakes.
Old 09-21-2013, 03:46 PM   #6
mixermike
mixermike's Avatar
Put both in now....if you don't do it now you will later I promise you that!! Once you go low you will always want to go lower!!!!!!! 4 1/2" in the front is not all that low
mixermike is offline   Reply With Quote
Old 09-21-2013, 04:12 PM   #7
Terry Crist
Boy, I can't add worth a crap!!!!!!
Old 09-21-2013, 04:57 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
How much $ u wanna spend? how low u wanna go
John
1999 Toyota Tacoma 4x4
Old 09-21-2013, 06:43 PM   #9
jpnh
jpnh's Avatar
i used 2 1/2 drop spindles and stock springs in the front. not too low. roads arnt as flat round here. still made it on the wrecker without dragging even with the air deflector on the front bumper. what are you usin for wheels? the size of the wheel/ back spacing/tire size come into play dont wanna be rubbn on the inner fender well over the smallest bump. in the rear i did a spring under the axle conversion had to remove the shackles n rebolt them remove the rubber snubbers n run the spring under the axle stead of over it still had enough space so it didnt bottom out. any lower and youll have to c notch the frame depends on the look your goin for. some people like more of a rake. take a look at some trucks in the forums and figure out what your goin for ask and find out what they had to do to achieve the height.-jeff
jpnh is offline   Reply With Quote
Old 09-21-2013, 06:50 PM   #10
71swb4x4
71swb4x4's Avatar
2 + 2.5 certainly = 4.5", but chances are that is not the drop you will get. Generally that is the drop from the factory specified stock height. After 40+ years your stock springs are sagging. So if you have original springs, I would guess you are sagging an inch already, so those springs and drop spindles will likely give you 3.5" of drop from where you are today.
I would start with the spindles. You can always add the springs if it isn't low enough.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-23-2013, 07:03 AM   #11
wraprail
wraprail's Avatar
I would just be aware of your lower control arm bushings in relation to the ground. I had 2.5 spindles and 3" drop springs (5.5" total?) and scraped the washers flat (74 c10). Also with 15" wheels the lower arm pivot point was lower than the bottom of the rims, illegal in most states. 20" wheels cured that and made it a lot safer on the hwy.
wraprail is offline   Reply With Quote
