Old 12-27-2013, 11:18 PM   #1
papsoldblue72
papsoldblue72's Avatar
LS 5.3 Stroker???
Does anyone know if there is a rotating assembly you can buy to make a 5.3 into a 5.7 ??? the 5.3 I got has a broken crank shaft...
It's been a long time coming... It's time to get it done..
papsoldblue72 is offline   Reply With Quote
Old 12-27-2013, 11:43 PM   #2
WIDE LOAD C-30
Re: LS 5.3 Stroker???
A 5.3 has the same crank as a 5.7.
You can bore a 5.3 out to a 5.7.
'55 3100 1st Series
WIDE LOAD C-30 is offline   Reply With Quote
Old 12-28-2013, 02:31 AM   #3
storm9c1
*** That's interesting ***
storm9c1's Avatar
Yes, a 4.00" stroke crank is available. Lots of guys make 383s with them (and no, I'm not confusing it with a SBC of the same displacement).
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 12-28-2013, 10:58 AM   #4
papsoldblue72
Where can I find these kits??
Old 12-28-2013, 05:53 PM   #5
tinydb84
tinydb84's Avatar
http://www.truckinweb.com/tech/engin...d/viewall.html
David
Instagram: myfabguy
Old 12-28-2013, 06:48 PM   #6
crazy longhorn
Fabricate till you "puke"
Just my thoughts....you might think about a 6 .0, vs the boring & stroking (dollar wise)? The 6.0, will make 370 cubes, on a .030 overbore, & handle larger valves, for the power upstairs Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-28-2013, 07:05 PM   #7
71K20chevy
71K20chevy's Avatar
Or, better yet, a bored/stroked 6.0
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 12-28-2013, 07:41 PM   #8
crazy longhorn
Yes, bigger is better You can poke any 4.8 or 5.3 block 3 mm (LS1, 5.7 bore spec). Mucho money on the bore, & the stroker parts are expensive! I have to agree...if you want to play, poke & stroke the big one. Longhorn
350, 5.3, 5.7, ls1
