Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 01-30-2014, 02:06 PM   #1
Pacific Fabrication
Pacific Fabrication's Avatar
'67-'72 GM Truck LS Engine Crossmembers
If you're swapping an LSx motor into your '67-'72 GM truck, you probably see that the factory crossmember just doesn't fit. To ease your install we have a bolt in replacement piece we've developed.
This unit was developed using computer aided design and is cut out on a CNC plasma table for great fit and finish every time. The crossmember is made from 1/4" mild steel plate and is welded in house. It ships with all the grade 8 hardware needed for installation as well as a new set of rubber motor mounts and adapter plate to mate to your new LSx engine.
$399
Pacific Fabrication is offline
Old 02-04-2014, 02:22 PM   #2
Pacific Fabrication
Re: '67-'72 GM Truck LS Engine Crossmembers
In stock and ready to ship!
Old 02-04-2014, 03:56 PM   #3
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
How does this work with your front suspension? I dont see a spot to bolt on upper and lower control arms?
chevyguy_72 is offline
Old 02-04-2014, 04:07 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
I believe that crossmember is 4wd only...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline
Old 02-28-2014, 06:51 PM   #5
Pacific Fabrication
That is correct. It is only needed on 4wd models.
Old 03-06-2014, 04:53 PM   #6
Pacific Fabrication
Our crossmember kit comes fully loaded with engine mounts, adapter plates and hardware. The crossmember is 100% made in America with high quality steel, and fully welded in house. It was designed with clearance and adjustability in mind. Don't be fooled by the competition's wider, stripped down version that looks like an erector set. It just can't compare to the quality, design, and versatility of our kit. And to make our kit just that much better we have decided to drop the price.
It is now $359! It's the same great kit just $40 less!
Order yours today!
Old 03-18-2014, 02:55 PM   #7
Pacific Fabrication
Old 03-24-2014, 05:03 PM   #8
Pacific Fabrication
Old 04-02-2014, 03:53 PM   #9
Pacific Fabrication
Thanks for the orders!
Old 04-22-2014, 01:55 PM   #10
Pacific Fabrication
Have a question? Don't hesitate to ask!
Old 04-29-2014, 07:37 PM   #11
Pacific Fabrication
Old 06-23-2014, 02:59 PM   #12
Pacific Fabrication
Kits are in stock and ready to ship!
Old 07-06-2014, 03:43 PM   #13
70ptta
any coupon codes coming up? i need one of these cross members for my k10.
70ptta is offline
Old 07-14-2014, 06:41 PM   #14
Pacific Fabrication
There may be another one in August...
Old 07-23-2014, 04:17 PM   #15
Pacific Fabrication
Old 08-14-2014, 07:45 PM   #16
Pacific Fabrication
Old 08-27-2014, 02:29 PM   #17
Pacific Fabrication
Old 09-11-2014, 04:35 PM   #18
67-72trucks
Payment Sent! Thank you
67-72trucks is offline
Old 10-15-2014, 02:39 PM   #19
Pacific Fabrication
Thanks for the orders! More ready to ship today!
Old 11-14-2014, 06:14 PM   #20
Pacific Fabrication
Thanks for the orders and don't forget to check us out on the latest episode of Dirt Every Day!
Dirt Every Day
Old 11-19-2014, 03:43 PM   #21
Pacific Fabrication
Old 11-26-2014, 07:55 PM   #22
70ptta
any black friday deals on this?
70ptta is offline
Old 11-26-2014, 08:04 PM   #23
Pacific Fabrication
There sure is! Give me a call 408-600-0122.
-Walter
Old 12-01-2014, 03:30 PM   #24
Pacific Fabrication
Old 12-04-2014, 04:01 PM   #25
Pacific Fabrication
Closed Thread
